Author Topic: USB Hub  (Read 4368 times)
Offline mistakemistake
  • Global Loveinator
USB Hub
« on: Tue, 04 September 2012, 16:13:23 »
Can anyone recommend a 2-4 port USB hub that's inexpensive/reliable?
anyone have personal experience with: http://www.amazon.com/Belkin-USB-2-0-4-Port-White/dp/B000NB05MO/ref=sr_1_10?ie=UTF8&qid=1346792947&sr=8-10&keywords=usb+hub+2+port+belkin
Offline Appeac
Re: USB Hub
« Reply #1 on: Tue, 04 September 2012, 17:16:37 »
What are you needing it for? Most el-cheapo hubs will work fine if only using keyboards/mice/webcams/usb 2.0 flash sticks. If you're using it to charge a lot of things, or using high powered devices, you may want to spring for a unit that uses a mains power adapter.
FC660C
122 Terminal M w/ Soarer board
  • Global Loveinator
Re: USB Hub
« Reply #2 on: Tue, 04 September 2012, 17:22:03 »
Just easier access for flash drives... Maybe I'll just go with that belkin..  Thanks for the reply!
Offline TheProfosist
  • Custom Layouts Only!
Re: USB Hub
« Reply #3 on: Tue, 04 September 2012, 17:26:00 »
That belkin is actually pretty nice i have one but it doesnt have much weight to it so if it near the edge of the table the cables can pull it off.
  • Global Loveinator
Re: USB Hub
« Reply #4 on: Tue, 04 September 2012, 17:30:47 »
Hmm good to know, that would drive me crazy.
Re: USB Hub
« Reply #5 on: Tue, 04 September 2012, 17:33:06 »
There a bigger that the little one stacks on thats much weightier I have both and dont use them anymore. Interested in the set?
  • Global Loveinator
Re: USB Hub
« Reply #6 on: Tue, 04 September 2012, 17:35:15 »
pics and price for each and together shipped?
Re: USB Hub
« Reply #7 on: Tue, 04 September 2012, 17:38:33 »
sure thing ill do that asap hen i get home from work.
  • Global Loveinator
Re: USB Hub
« Reply #8 on: Tue, 04 September 2012, 17:40:20 »
awesome, thanks!
Re: USB Hub
« Reply #9 on: Tue, 04 September 2012, 20:48:25 »
awesome, thanks!
Here are some pics, sorry the hubs dont match.
How about $25? I would like to sell them both if possible.
Sorry it took so long to get the pics up Photobuckets page went down right when i uploaded the pics so i had to figure out the urls to everything i just uploaded.
« Last Edit: Tue, 04 September 2012, 20:53:46 by TheProfosist »
Offline SmallFry
Re: USB Hub
« Reply #10 on: Tue, 04 September 2012, 20:53:10 »
I always just use the Monoprice ones. Cheap, effective, and dispensable if they break, which I haven't had happen.
  • Global Loveinator
Re: USB Hub
« Reply #11 on: Tue, 04 September 2012, 21:06:05 »
Hm, it's a fair offer, but I will have to take a day to think about it?
Re: USB Hub
« Reply #12 on: Tue, 04 September 2012, 21:08:57 »
fine by me not like their going anywhere.
« Last Edit: Tue, 04 September 2012, 21:12:24 by TheProfosist »
Re: USB Hub
« Reply #13 on: Wed, 19 September 2012, 00:35:01 »
Still got these anyone interested?
