Author Topic: Cheapest TKL?  (Read 5802 times)
Offline f/64
Cheapest TKL?
« on: Sat, 08 September 2012, 22:59:58 »
From my research, I understand the HPE to be the cheapest TKL. I was just wondering if anybody knew of one cheaper. I don't want to spend a ton as I plan on getting another around Q4, but my nephews destroyed my rapoo v7 with rootbeer. I'm tired of the $10 mini Siig rubber dome I'm using. I would prefer red or even brown, but if it was a PCB mount, I could harvest the springs from the rapoo and drop 'em in instead.
Work your magic GeekHackers.  ;D
Re: Cheapest TKL?
« Reply #1 on: Sat, 08 September 2012, 23:14:36 »
By my understanding, the Quickfire Rapid sometimes goes on a sale that drives the price way low.  Better quality than a HPE or Keycool, too.
Offline WhiteFireDragon
    • youtube
Re: Cheapest TKL?
« Reply #2 on: Sat, 08 September 2012, 23:18:41 »
CoolerMaster quickfire rapid MX blues. Same quality as filco for $64 shipped:
http://www.amazon.com/gp/product/B0068INSUM
Offline f/64
Re: Cheapest TKL?
« Reply #3 on: Sat, 08 September 2012, 23:23:23 »
I know, I know, but...Blues...Blegh. I wish their red board was that cheap.
Offline The_Beast
  • I like wood ಠ_๏
Re: Cheapest TKL?
« Reply #4 on: Sat, 08 September 2012, 23:26:06 »
Get one with browns :D
Offline f/64
Re: Cheapest TKL?
« Reply #5 on: Sat, 08 September 2012, 23:30:48 »
The brown is $104 on Amazon.
    • youtube
Re: Cheapest TKL?
« Reply #6 on: Sun, 09 September 2012, 00:29:49 »
Well for the mx reds, $90 shipped is pretty much the lowest non-sale price. Only other place that even has them available is directly from CM website for $90 + shipping + tax.
And also in the realm of mechanical keyboards, $25 difference between the reds and blues is not a whole lot of difference, especially if you're going to consider getting replacement caps or other accessories for the keyboard. This keyboard hobby will burn a hole in your wallet.
Offline f/64
Re: Cheapest TKL?
« Reply #7 on: Sun, 09 September 2012, 00:39:02 »
I know. I'm already in on the Sanctuary group buy, but I'm just too cheap to spend ~$100 now when I know I'll be spending that much or more in a few months on another one. Especially when I can only use one keyboard at a time.
Offline ih8
Re: Cheapest TKL?
« Reply #8 on: Sun, 09 September 2012, 00:51:44 »
use the discount code carter provided on CM stores website, 30% off plus free shipping
storm_keyboard30
Offline f/64
Re: Cheapest TKL?
« Reply #9 on: Sun, 09 September 2012, 01:02:28 »
Bummer that they're out of the reds.  :(
And plate mounted so I can't just switch the springs on a black.
