Author Topic: keycap DIY  (Read 50092 times)
Offline __red__
Re: keycap DIY
« Reply #50 on: Wed, 03 October 2012, 15:06:38 »
A requested, photo of my mold.
Offline neeb
Re: keycap DIY
« Reply #51 on: Wed, 03 October 2012, 15:43:04 »
Awesome work Red!
Offline __red__
Re: keycap DIY
« Reply #52 on: Thu, 04 October 2012, 19:10:57 »
I have 30 minuets to my next Dee-mold time.  If the spilt plastic is anything to go by we're about to start an obsession :-)
Offline __red__
Re: keycap DIY
« Reply #53 on: Thu, 04 October 2012, 20:20:07 »
Tah dah!
Offline jeroplane
Re: keycap DIY
« Reply #54 on: Thu, 04 October 2012, 20:49:53 »
 :eek: Imagine those on a backlit keyboard. Great colour, and the molds are looking neat!
My signature hasn't changed since 2012. I should really update it.
Offline jwaz
  • * based mod
  • #geekhack on freenode
Re: keycap DIY
« Reply #55 on: Thu, 04 October 2012, 20:56:17 »
Woah that raspberry color is great, are the stems firm enough to take a beating?
Offline neeb
Re: keycap DIY
« Reply #56 on: Thu, 04 October 2012, 21:29:20 »
Red: Wow, that's effing awesome! I would love to see some more videos (if possible) when you have some free time man, epic work so far! How many keycaps are you making at a time? It looks like there's quite a few on the 2nd attached image of your last post. Also, have you tried anything for MX yet?
Matt3o: Anything new in your efforts? I know you were waiting for a better keycap to arrive to make a mold from; I'd love to see how your little gems are coming along :D!
Computer-Lab in Basement: Have you punched out any keys yet with your new supplies?
Really awesome work all of you, and anyone else that's been trying this and hasn't posted/posted in another thread/I forgot about. I think this is probably the most interesting post on GH atm, I would really love to give this a try (and plan to) when I have some extra money :D!
Edit: Btw, what is a Model F? Lol. Sorry, I'm still learning when it comes to all of this. The one that you made, is that like the switch/keycap for an IBM Model F or what exactly?
« Last Edit: Thu, 04 October 2012, 21:37:50 by neeb »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
Re: keycap DIY
« Reply #57 on: Fri, 05 October 2012, 01:30:59 »
I received the keycaps a couple of days ago, now to the mold!
Actually the next step would be... CNC :) I can get one at a very reasonable price (€500) and I'm seriously considering it.
Offline neeb
Re: keycap DIY
« Reply #58 on: Fri, 05 October 2012, 01:57:33 »
I really don't know much about modeling or anything crafty lol. Can you give a link to something you're considering that would work well for this?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
Re: keycap DIY
« Reply #59 on: Fri, 05 October 2012, 03:13:46 »
It's a machine controlled mill to build 3D prototypes (from a 3d computer model). The one I should get is similar to this http://www.bluemelon.org/index.php/Products/BM0502_CNC_Mill
Offline neeb
Re: keycap DIY
« Reply #60 on: Fri, 05 October 2012, 04:20:26 »
So you would create a keycap in the software that goes with that bad boy and then it pops em out?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
Re: keycap DIY
« Reply #61 on: Fri, 05 October 2012, 04:32:42 »
yes, I could sculpt a prototype I could build a mold from. Would be nice to be able to design any kind of 3D keycap :)
It would be also possible to build wooden keyboards for example.
Offline neeb
Re: keycap DIY
« Reply #62 on: Fri, 05 October 2012, 05:06:56 »
Would you be able to do different colors/designs or would this just mold the keycaps and you'd need something different for 3D printing or w/e you wanna call it?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
Re: keycap DIY
« Reply #63 on: Fri, 05 October 2012, 05:29:42 »
multiple colors on the same key is extremely complex. The easiest would be to mask and spray color. There's a product called Mr.Masking (by Mr.Hobby) that makes masking pretty easy.
Offline neeb
Re: keycap DIY
« Reply #64 on: Fri, 05 October 2012, 05:39:34 »
No no I didn't mean different colors on the same keycap lol. I just meant if you're using one of these CNC mill machines, can you sculpt keycaps in any color you want or does it just sculpt them in some base color that you'd have to change using something else?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
Re: keycap DIY
« Reply #65 on: Fri, 05 October 2012, 05:44:50 »
oh well. usually the milling machine is used for the prototype. You can use the prototype to make a mold and cast it in any color. Anyway you could have the CNC milling the final product. In that case you can use any material/color, from wood to aluminum (with everything in between).
Offline neeb
Re: keycap DIY
« Reply #66 on: Fri, 05 October 2012, 05:49:07 »
So you would likely be using the mill to make some nice 3D keycap prototypes, then make a mold by hand, and then cast actual keycaps? If that's the case, what are the advantages of that vs using the mill to produce the end product? is it more expensive to use the mill or why exactly would you want to mold/cast by hand instead of the machine?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
Re: keycap DIY
« Reply #67 on: Fri, 05 October 2012, 06:10:39 »
depends on many factors. The number of keys you want to produce for example, or the material. If you want an aluminum key of course you have to mill it directly.
CNC is usually pretty slow. It might need 1 hour to make one side of the cap. So if you need a lot of keys you better make a mold. Also with a mold you have a wider range of colors you can choose from while you might not be able to find the prototyping plastic in the color you want.
Offline neeb
Re: keycap DIY
« Reply #68 on: Fri, 05 October 2012, 06:13:26 »
Ahhh I see now, thanks for clarifying all of that. I apologize for the 20 questions there, I just find all of this extremely fascinating xD
Offline __red__
Re: keycap DIY
« Reply #69 on: Fri, 05 October 2012, 08:57:23 »
Make sure you have deep pockets for the CNC.  The software chain is insanely expensive.
I'd start with casting an existing key / keycap.  Get that process down before you start milling wax.
Red
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
Re: keycap DIY
« Reply #70 on: Fri, 05 October 2012, 09:02:25 »
why you say so? most of the softwares are free.
Offline __red__
Re: keycap DIY
« Reply #71 on: Fri, 05 October 2012, 10:15:04 »
Not for three or four axis control.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
Re: keycap DIY
« Reply #72 on: Fri, 05 October 2012, 10:44:29 »
I have a license for Mach3 which is an up to 6-axis CNC controller and it wasn't expensive at all (I paid less than $100 at the time I believe). It's not probably the most sophisticated software around, but it works.
Also there's a linux distro dedicated to CNC that is completely free.
Offline __red__
Re: keycap DIY
« Reply #73 on: Fri, 05 October 2012, 11:02:48 »
The money isn't in the control software.  The money is in the G-Code generators.  CAM.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
Re: keycap DIY
« Reply #74 on: Fri, 05 October 2012, 11:10:38 »
don't remember what I have as g-code generator. I built a cnc many years ago and indeed ending up with a good g-code wasn't easy. Lots of tweaking is needed. But if the model is not horribly complicated shouldn't be a problem.
Offline alvinliang
Re: keycap DIY
« Reply #75 on: Fri, 05 October 2012, 13:19:45 »
it looks so cool, i wanna make my own key cap
iPhone sucks
Offline __red__
Re: keycap DIY
« Reply #76 on: Sat, 13 October 2012, 16:16:20 »
I have fully functional caps using the problematic plastic.
I did it with red dye because I wanted to see the difference between easy plastic and hard plastic with the dye.
Anyways, photos!
Offline smilertoo
Re: keycap DIY
« Reply #77 on: Sat, 23 May 2015, 13:56:33 »
Don't you get resins that you bake with UV lighting?
