Author Topic: keycap DIY  (Read 50741 times)
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
keycap DIY
« on: Thu, 13 September 2012, 12:42:25 »
I wanted to try to make my own keycaps, so I got some silicone and epoxy resin... and I must say that it's harder than it seems :)
1) I made the key a little thicker filling some resin into it
2) bi-adhesive tape on the key
3) the key positioned together with 3 reference pins
4) silicone... wait 24h
5) 24h later
6) coat with vaseline
7) mold ready!
8 ) end result
Unfortunately the stem is not perfect and I have to redo the male part of the mold, but I'm quite satisfied as a first try. I need to find a thicker keycap to make the mold, the one I have is too thin, not really good for molding.
Offline i3oilermaker
  • techkeys.us
    • TechKeys
Re: keycap DIY
« Reply #1 on: Thu, 13 September 2012, 12:53:05 »
Wow that looks awesome! Where did you get your materials?
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Re: keycap DIY
« Reply #2 on: Thu, 13 September 2012, 12:57:36 »
Nice. But where's the fill port?
-Enzo Ferrari
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
Re: keycap DIY
« Reply #3 on: Thu, 13 September 2012, 13:08:08 »
I've found everything in a local arts and crafts store.
There are many kinds of silicone for molding, being the key so small I took the smoothest one (it is called "10 shore" I believe). It has a very long dry out period (24h) but you don't have to worry about air bubbles since they mostly evaporate in the first couple of hours.
The epoxy resin is the clearest I've found, it is mixed with the reagent at 1/4 proportion and when wet it's smooth like baby oil.
I already ordered some thicker PBT keycaps to make a better mold. I must say it's a time consuming task and you have very little margin for error.
I tried without it. I just put the resin into the female and closed with the (resin coated) male mold.
Offline Mugen
  • O-Rings are the murderers of keyboard souls
Re: keycap DIY
« Reply #4 on: Thu, 13 September 2012, 13:14:07 »
Without the fill port you'll have a hard time getting a cap without air bubbles. also - from experience would recommend building a small vacuum chamber that will basically suck the air out of the cast. You can build one with ~30$, in the process of building one myself - waiting for my pump.
Boost did you use a vacuum chamber with your molds?
Offline __red__
Re: keycap DIY
« Reply #5 on: Thu, 13 September 2012, 13:14:14 »
You were far more successful than I.
My mold was perfect but my keys had bubbles, lots of bubbles.
Let us know how you progress!
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Re: Re: keycap DIY
« Reply #6 on: Thu, 13 September 2012, 14:53:06 »
Nope. Got a ****ton of bad keys. Lol.
-Enzo Ferrari
Offline funkymeeba
  • CRUMPULAR
  • WEST SHINJUKU PLANTING TUNE
Re: keycap DIY
« Reply #7 on: Thu, 13 September 2012, 15:04:28 »
What we really could use is a nice wiki page that details this whole process. It doesn't seem overly scientific, but does seem like something that will take some effort to do well.
17:15 < vun> these are the healthiest crisps I've ever come across
17:16 < vun> mostly because I can't get the bag open
meebcats - my bad music
Offline Mugen
Re: keycap DIY
« Reply #8 on: Thu, 13 September 2012, 15:07:58 »
That would definitely be helpful, but I think only someone like Clack can put something really good together as it seems he mastered the technique.
I dont know of anybody else who does it that consistently.
Offline funkymeeba
  • CRUMPULAR
Re: keycap DIY
« Reply #9 on: Thu, 13 September 2012, 15:11:18 »
Maybe with what the rest of us presently know, yes. However, there's plenty of smart people here. Someone's bound to come up with a good way to do it.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
Re: keycap DIY
« Reply #10 on: Thu, 13 September 2012, 16:15:09 »
I've found a vert good epoxy resin, if you put it into the stem before closing the mold it's close to impossible to have bubbles. As you can see from the picture the key turned out very clean. But I'm still a noob I probably have to trash a dozen molds before mastering the technique, next time I'll try with vents.
Offline SmallFry
Re: keycap DIY
« Reply #11 on: Thu, 13 September 2012, 16:24:36 »
That sir, was super cool! Congrats on the cap!
Offline Mugen
Re: keycap DIY
« Reply #12 on: Thu, 13 September 2012, 22:48:37 »
Can you post a picture of the Resin youre using? with standard caps everything goes well, but if you try to cast something with more complex details (like a face with eyes and a mouth) then the risk of bubbles greatly increases.
I should get my pump tomorrow after which i'll probably be spending the weekend putting together with a chamber and running some pressure tests, if its successful (and maybe if it isn't) i'll post the details here.
So far all the materials cost me ~35-40$ but im sure i'm forgetting something and will have to stop by homedepot or what not.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
Re: keycap DIY
« Reply #13 on: Fri, 14 September 2012, 00:53:54 »
you are right, I was not considering complex keys. Looking forward to seeing your report.
The resin is an Italian product called SIRIOEPOS 552 (http://www.archiproducts.com/en/products/52183/andromeda-chemical-anchor-sirioepos-552-proind.html). It's not properly for casting but it's really good.
They define it "superfluid" and it really is, it's almost watery for the first 5 minutes. When it is still fluid brush it into the mold taking care to fill all the holes, then fill the female mold and wait few minutes for the resin to become gelly, at that point you can close the mold. You shouldn't have any bubbles in this way.
« Last Edit: Fri, 14 September 2012, 03:35:45 by Matt3o »
Offline __red__
Re: keycap DIY
« Reply #14 on: Fri, 14 September 2012, 04:04:45 »
The resin I use is specifically designed for precision parts so is specifically designed to have no shrinkage.
Did your resin shrink during curing?
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
Re: keycap DIY
« Reply #15 on: Fri, 14 September 2012, 04:21:09 »
no shrinking whatsoever
Offline Paranoid
Re: keycap DIY
« Reply #16 on: Fri, 14 September 2012, 06:37:21 »
nicely done :) I'm gonna make some myself but still waiting for my materials to arrive. You definitely need a fill port and (at least) one to let the air out.
I don't own any vacuum equipment, nor do I have knowledge to build one myself, so hoping that some vibrating will get all the bubbles out.
Offline Mugen
Re: keycap DIY
« Reply #17 on: Fri, 14 September 2012, 08:50:25 »
What Resin is that?
If you have a laundry machine, you can just place your cast on that - it worked for me. problem is i live in an apartment building with a shared laundry room, so people were looking at me weird when I brought my Resin >_<
  • Live long and prosper
Re: keycap DIY
« Reply #18 on: Fri, 14 September 2012, 09:08:25 »
Would like to learn how to do this myself someday.  What kind of plastic did you use to make they key itself?
tp thread is tp thread
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
Re: keycap DIY
« Reply #19 on: Fri, 14 September 2012, 09:15:22 »
epoxide resin. it's a 2 components resin which solidify at room temperature. You can also color it by adding some pigment
Re: keycap DIY
« Reply #20 on: Fri, 14 September 2012, 09:29:21 »
Must find these materials... WANT TO MAKE MY OWN CAPZ!!!!
Any chance you could post some links to where I might be able to purchase said materials?
« Last Edit: Fri, 14 September 2012, 09:31:02 by Computer-Lab in Basement »
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
Re: keycap DIY
« Reply #21 on: Fri, 14 September 2012, 13:35:36 »
I took them from a local retailer (they do not sell online) but I believe you can find pretty much everything you need here http://www.smooth-on.com/Model-Making/c1290/index.html
The silicone I used is close to what they call "Mold Max 10". They don't seem to have the resin I used, anyway they have interesting howtos and faqs, I'm sure you'll find all you need.
Re: keycap DIY
« Reply #22 on: Fri, 14 September 2012, 13:58:23 »
Thanks, I'll look into that.  Hopefully I can make my own custom keycaps someday like this...
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
Re: keycap DIY
« Reply #23 on: Sun, 16 September 2012, 12:21:45 »
a quick update, while waiting for the new thicker keycaps to arrive I've found a local dealer which sells epoxy pigments in the following selection http://www.ralcolor.com/
Add 1% of pigment (which is a gel/paste) for a transparent effect, add 10% to get a solid color.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
Re: keycap DIY
« Reply #24 on: Mon, 17 September 2012, 01:26:46 »
Another very interesting find. Transparent silicone rubber so you can see if and where you have bubbles:
4351-0
More info http://www.prochima.com/public/eng/CRISTAL%20RUBBER%20ing.pdf
Offline Paranoid
Re: keycap DIY
« Reply #25 on: Mon, 17 September 2012, 13:57:29 »
Damn, why didn't I think of that :p I'll have to stand on a ladder for that though since the dryer is on top of the washer ^^
That's the silicone that I'm gonna use, and am comfortable with. That way you can also make easier cuts in difficult molds. I'm just curious how it's gonna go without a whole lab (like in college). Still waiting for it to arrive :)
Is the brand called ralcolor or are these just the color codes?
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
Re: keycap DIY
« Reply #26 on: Mon, 17 September 2012, 14:04:55 »
I think RAL is the color code.
Offline __red__
Re: keycap DIY
« Reply #27 on: Mon, 17 September 2012, 21:48:23 »
What Resin is that?
I use GI-1000 for my silicone and OC-7086 for my resin.
This is the kind of accuracy you can get with these resins:
Red
Offline __red__
Re: keycap DIY
« Reply #28 on: Tue, 18 September 2012, 08:08:32 »
I am currently casting a couple of Model M caps, a Model F barrel and a Model F full key.  I'll report back when I know how they come out.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
Re: keycap DIY
« Reply #29 on: Tue, 18 September 2012, 08:16:26 »
how long does it take to your resin to cure? I've found a resin that cures in 30 minutes (the one I used before takes 18h) and I'm temped to try it
Re: keycap DIY
« Reply #30 on: Tue, 18 September 2012, 08:51:01 »
I am going to order myself some of these materials later this week and will try to make myself some homemade keycaps.  I might try casting some of the small SiiG MiniTouch F keys, along with some MX keycaps, of course... can't wait to try this out!  Thanks for posting this thread, Matt3o!
Offline __red__
Re: keycap DIY
« Reply #31 on: Tue, 18 September 2012, 09:32:14 »
Sorry, let me give you a more specific answer:
GI-1000 (Used to create molds) -> 16-18 hours cure time.  I de-mold it usually in about 6-8 hours.
OC-7086 - (Water-clear urethane) -> You can remove it from the mold in 3 - 4 hours.  Strictly speaking it doesn't fully cure for a week but you likely wouldn't notice any difference between 24 hours and 1 week unless you had test equipment.
GI-1000 is expensive at $14.50 per lb (2lb quantity) or $10 per lb (10lb quantity).  It's so worth it.
Unless you are willing to invest in a lot of effort, vacuum chamber, pressure pot and incredible attention to detail I would not recommend OC-7086 as it is incredibly sensitive to everything and will form bubbles with the slightest excuse.
I'm currently testing other urethanes to look for a more practical for home use formulation.
EDIT:
After discussing my requirements with their chemist, I'm going for IE-3080 from innovative-polymers.com.
« Last Edit: Tue, 18 September 2012, 10:16:51 by __red__ »
Offline fl0w3n
Re: keycap DIY
« Reply #32 on: Thu, 20 September 2012, 13:37:38 »
Post more pictures of results!
I'd be interested in trying this as well.
Would doing some sort of small print out with some sort of special paper/ink, and then laying it in the mold give you the ability to make caps with images?
Offline __red__
Re: keycap DIY
« Reply #33 on: Sat, 22 September 2012, 12:07:02 »
Two different resins, no vacuum or pressure.
Mold release and patience will improve the quality.  Specifically, the bad habit I have of opening molds 12 hours too early.
« Last Edit: Sat, 22 September 2012, 12:08:50 by __red__ »
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
Re: keycap DIY
« Reply #34 on: Sat, 22 September 2012, 12:53:41 »
not bad at all. I agree patience is the key :)
I'm still waiting for the keycaps to make the new mold, at this point I believe they got lost in post office. Next week I'll order more, maybe from Europe this time, are qwerkeys keycaps thick?
Offline __red__
Re: keycap DIY
« Reply #35 on: Sat, 22 September 2012, 19:56:01 »
feature=youtu.be
Working Model F prototype.  Now to cast in clear-glass!
Offline Mugen
Re: keycap DIY
« Reply #36 on: Sun, 23 September 2012, 22:29:56 »
Where can i order this fast resin stuff? the resin that i have hardens in like 90 seconds but i get bubbles like a mofo. so far my attempt to build a chamber has not gone well, pump is not strong enough.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
Re: keycap DIY
« Reply #37 on: Mon, 24 September 2012, 01:08:07 »
feature=youtu.be
 :eek: :eek: :eek: :eek:
Re: keycap DIY
« Reply #38 on: Tue, 25 September 2012, 14:31:12 »
Just ordered all the stuff I need to make myself some homemade keycaps!  Can't wait to get them in the mail... will post my first attempts once I get them.  Thanks for the links, Matt3o!
Offline Mugen
Re: keycap DIY
« Reply #39 on: Tue, 25 September 2012, 18:40:11 »
Where did you make the order, the company i spoke to only did the orders by phone, same?
Re: keycap DIY
« Reply #40 on: Tue, 25 September 2012, 19:07:06 »
Re: keycap DIY
« Reply #41 on: Thu, 27 September 2012, 14:36:25 »
Just got these in the mail today:
5055-0
Time to try out this DIY keycap-making process...
« Last Edit: Thu, 27 September 2012, 14:40:27 by Computer-Lab in Basement »
Offline Wess
Re: keycap DIY
« Reply #42 on: Thu, 27 September 2012, 17:53:28 »
Looks great!! ... Now what will you make? Pics plz :P Would be great if you documented the whole process in a separate thread ;)
Re: keycap DIY
« Reply #43 on: Thu, 27 September 2012, 18:08:01 »
I'll be sure to do that when I make another mold.  I started making the first half of the mold about an hour ago, but it's gonna have to cure overnight before I can make the second half.  It's my first time doing this, so I'm not expecting anything great.  I'll post pics soon.
Re: keycap DIY
« Reply #44 on: Thu, 27 September 2012, 18:13:51 »
Take your time the first time around - once you are familiar with the process you will know when you can cut corners and when not.
"Because keyboards are accessories to PC makers, they focus on minimizing the manufacturing costs. But that�s incorrect. It�s in HHKB�s slogan, but when America�s cowboys were in the middle of a trip and their horse died, they would leave the horse there. But even if they were in the middle of a desert, they would take their saddle with them. The horse was a consumable good, but the saddle was an interface that their bodies had gotten used to. In the same vein, PCs are consumable goods, while keyboards are important interfaces." - Eiiti Wada
Re: keycap DIY
« Reply #45 on: Thu, 27 September 2012, 19:12:24 »
^This.  That's why I'll probably end up by letting the mold cure for a few extra hours so I don't end up my messing it up or something...
Offline __red__
Re: keycap DIY
« Reply #46 on: Fri, 28 September 2012, 07:03:43 »
It's counter-intuitive but the thinner the part, the longer the urethane takes to cure.
Offline neeb
Re: keycap DIY
« Reply #47 on: Sun, 30 September 2012, 20:08:41 »
Any update/new pics on this guys? Really awesome work so far! I want to give this a try when I have some extra money
Offline proest
Re: keycap DIY
« Reply #48 on: Sun, 30 September 2012, 22:55:02 »
Wow, this is awesome! I think I'll try this out...
Offline __red__
Re: keycap DIY
« Reply #49 on: Wed, 03 October 2012, 14:19:31 »
This it's using easy-cast.  I would recommend against it's use as it's too flexible.
