Author Topic: Lorem ipsum  (Read 8691 times)
Offline davkol
  •  Post Editing Timeout
Lorem ipsum
« on: Thu, 13 September 2012, 18:43:52 »
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum
« Last Edit: Mon, 10 December 2018, 14:57:43 by davkol »
Offline The_Beast
  • I like wood ಠ_๏
Re: External numpad for hotkeys, while internal one stays untouched. Ideas?
« Reply #1 on: Thu, 13 September 2012, 18:55:22 »
I had the same idea but still haven't done anymore research on the idea
http://geekhack.org/index.php?topic=34713.msg642266#msg642266
Offline alaricljs
  • I be WOT'ing all day...
« Reply #2 on: Thu, 13 September 2012, 19:07:56 »
I read that there is a way with AutoHotKey using HID identifiers or some such.
Maybe this or maybe this at desko can help you figure out how to spawn AHK using HID macros and get features that way.
« Last Edit: Thu, 13 September 2012, 19:10:20 by alaricljs »
Filco w/ Imsto thick PBT
Offline sth
  • 2 girls 1 cuprubber
« Reply #3 on: Thu, 13 September 2012, 19:13:11 »
You could also potentially make an inline  converter  with a teensy.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Thu, 13 September 2012, 21:47:11 »
I would just look for some programmable keypad like a genovation, sometimes they are really cheap on ebay especially if you can use serial interface.
Offline CeeSA
« Reply #5 on: Sun, 16 September 2012, 15:52:54 »
Cherry G84 4700 PS/2 is programmable with more than one layer iirc. Select a different layer, the keypad did not react like a tenkey.
Offline ddot
  • Master of Suspense
« Reply #6 on: Wed, 19 September 2012, 18:06:37 »
I do a lot of drafting work with AutoCAD and a couple years ago I did a little research on different approaches to using a second keyboard in conjunction with macros to simulate multiple keystrokes with a single key press.
The best program I came across for distinguishing 2 different keyboards was HID macros (which you mentioned). I found a few vague references in how AutoHotkey could work with multiple devices, but I never got far enough in figuring it out.  I never tried to get HID macros to work with multiple windows, so I can’t comment on that.  For assigning standard keyboard shortcuts, I found it easy with the “wizard” interface.  More complicated stuff was possible with scripting languages.  The program wasn't 100% bug free (on the rare occasion the actual keystroke would get passed instead of the macro), but overall I was very pleased.
As time wore on, I lusted for more shortcuts than the number pad could provide.  Ultimately I dumped it for Logitech G13.  I've definitely made use of the additional keys and would have a hard time going back.  The G13 appears to have the ability to differentiate between multiple windows (again, not something that I’ve ever tried).  Notable downside is the price.  If you go that route, do a little research on the controller software.  Logitech has both the new ( version 8 ) and legacy ( version 3 ) software available for download.  Lots of people (including me) found the new software to be buggy and ended up going back to the legacy version.
Offline quake4mhg
« Reply #7 on: Thu, 20 September 2012, 23:43:03 »
Yes, as ddot & CeeSA mentioned above, I think the fastest way is to buy a Cherry G84 4700 or g13/g110/g510 logitech keyboard.
logitech macro software works really good. No need to learn the interface, just straight button logic. It saves me lots time everyday in the office (using g110). This can save you time to learn other scripts.
Personally, I'm using autothotkey on my filco numpad for firefox & web surfing shortcuts at home. It works too  :D
Offline davkol
Lorem ipsum
« Reply #8 on: Sun, 14 April 2013, 17:06:23 »
« Last Edit: Mon, 10 December 2018, 14:57:59 by davkol »
