Author Topic: Finding blank teal keycaps.  (Read 4085 times)
Offline Knight
« on: Sat, 15 September 2012, 13:42:57 »
Hey! I recently bought a Filco tenkeyless keyboard and I'm looking to customize it a bit and I need your help. I've spend the last couple hours on eBay, elitekeyboards, and qwertkeys and I couldn't find black keycaps of my favorite color, teal. I'm looking to get a 37 blank teal keycaps.
qwertkeys almost has what I'd like except they only have the color in function keys -> http://www.qwerkeys.co.uk/collections/frontpage/products/function-pack
Thanks so much.
« Last Edit: Sat, 15 September 2012, 13:45:28 by Knight »
Re: Finding blank teal keycaps.
« Reply #1 on: Sat, 15 September 2012, 14:31:28 »
http://www.qwerkeys.co.uk/collections/frontpage/products/ansi-37-pack
You can choose any colour for their 37 ANSI packs. Such as that teal, and a choice of infill as well I believe.
Oh, and Welcome to GeekHack!
Offline Knight
« Reply #2 on: Sat, 15 September 2012, 15:19:33 »
Ah, thanks so much! Is there anywhere in the US I can get them cheaper?
« Reply #3 on: Sat, 15 September 2012, 15:39:00 »
Not that I can think of in that colour. WASD keyboards has blue 37 cap sets in the US. And IMSTO has some lighter coloured blue thick caps, but would involved buying a full 104 set and shipping from China, and they are not too cheap. http://item.taobao.com/item.htm?spm=a1z10.3.17.18.26b9e5&id=17218012075&
Best bet would be just to buy from QWERkeys if those are the caps you really want.
Offline Knight
« Reply #4 on: Sat, 15 September 2012, 15:56:29 »
Thanks so much for your help. I'll probably end up getting them from qwertykeys :D
« Reply #5 on: Sun, 16 September 2012, 02:02:15 »
Welcome to Geekhack!
Good luck finding your ideal key caps :)
Offline Squiddy
« Reply #6 on: Sun, 23 September 2012, 15:01:25 »
I've been talking with the QWERKeys guys for a couple of days now - they're super friendly and helpful. If you don't see what you're looking for on their website drop them an email and I'm sure they'll help you out!
Offline longweight
  • philanthropist
« Reply #7 on: Sun, 23 September 2012, 15:19:43 »
Teal mods would be sick.
Offline whiteduck
« Reply #8 on: Wed, 03 October 2012, 13:05:12 »
WASD got their new keycap colors in so you could check out their new light blue color?
http://sphotos-a.xx.fbcdn.net/hphotos-snc7/301088_443915292314146_961485767_n.jpg
-wd
