Author Topic: RK-9000BR Keycap Edges  (Read 2308 times)
Offline melcron
« on: Sat, 15 September 2012, 23:41:46 »
I finally made the switch over to mechanical from a Logitech Illuminated. The high profile of the keys requires a bit of adjusting but one thing that keeps sticking in my mind when playing games is the angular keycap edges.
I'm using the RK-9000BR and was wondering if the Coolermaster Quickfire Rapid had smoother keycap edges... or is there a place I can buy replacement keycaps that have rounded edges?
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #1 on: Sat, 15 September 2012, 23:44:44 »
Get yourself some cherry or SP caps.  Those are OEM caps that come stock.
Offline The_Beast
  • I like wood ಠ_๏
Re: RK-9000BR Keycap Edges
« Reply #2 on: Sat, 15 September 2012, 23:45:49 »
SP/Cherry are lower profile but I think the OP is looking for something with rounded front edge
Offline melcron
« Reply #3 on: Sat, 15 September 2012, 23:54:23 »
I am indeed, although I'm glad someone told me the Cherry's are lower profile before I replaced only a few caps and realized my mistake.
After using a Lenovo U330 I grew fond of scissor-switch keyboards and went through an Apple Aluminum Keyboard (deceased) and a Logitech Illuminated Keyboard (missing keys) before moving over to this mechanical: When I am using the mechanical the high profile and cap edges bother... but when I attempt to go back to my scissor-switch keyboard the mushiness annoys me (didn't before!)  :))
I'll stick with it and adjust. Just to confirm the OEM caps on the Cooler Master are also higher profile then the Cherry's, correct?
  • techkeys.us
    • TechKeys
« Reply #4 on: Sat, 15 September 2012, 23:55:03 »
Perhaps someone can prove me wrong, but I feel like the space between key cap tops are further apart and rounder on SP/Cherry
Offline The_Beast
  • I like wood ಠ_๏
« Reply #5 on: Sat, 15 September 2012, 23:58:05 »
I think he's talking about just the front edge of the key cap being too sharp.
