Author Topic: One question on Rit Dye  (Read 6798 times)
Offline kinruan
  • SWAG=Specially Weaponized Asian Grandma
« on: Sun, 16 September 2012, 10:57:14 »
what is the difference between the Rit liquid dye, powder dye and the professional line? seems like the professional line stuff is more expensive than the other two.  why it is better? thx,
If the world ends tomorrow, what should we have for dinner tonight?
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: One question on Rit Dye
« Reply #1 on: Sun, 16 September 2012, 11:00:39 »
Actually you want the cheap powder type for plastics. The other ones don't work very well or at all depending on color.
Offline kinruan
« Reply #2 on: Sun, 16 September 2012, 11:04:03 »
thx man. how about the liquid, since there are some colors such as cherry red that are not involved in the powder products.
« Reply #3 on: Sun, 16 September 2012, 11:15:28 »
I don't think anyone has had very good results with it. There are some other similar ones by different brands like Dylon too for other color choices.
Offline whiskerBox
« Reply #4 on: Sun, 16 September 2012, 11:36:35 »
you should really look for 02dazones or iMavs threads about this. The only people I have seen do this successfully have done it on HHKB keys (PBT) all of the abs keys looked pretty bad.
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline Lu_e
« Reply #5 on: Sun, 16 September 2012, 12:27:59 »
idk if he used rit dye but beast's dyed keys looked awesome in the giveaway thread; http://geekhack.org/index.php?topic=32966.msg629099#msg629099
Just say NO to ABS keycaps
Offline The_Beast
  • I like wood ಠ_๏
« Reply #6 on: Sun, 16 September 2012, 12:34:43 »
IDK how they were dyed, I just bought them from someone 2nd hand and they were that booger green
Offline Lu_e
« Reply #7 on: Sun, 16 September 2012, 12:58:51 »
o alright then. contrasts well with the purple I must say.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #8 on: Sun, 16 September 2012, 13:07:21 »
It does go really well with the purple, but I'm moving away from OEM profile and that set just happens to be OEM profile :(
« Reply #9 on: Sun, 16 September 2012, 14:30:39 »
Those mint green KBC caps came like that I think. They had some on taobao in a few pastel colors awhile back. Similar to the pastel rainbow sets but in single colors.
PBT and POM are possible to dye as the melting point is a lot higher. ABS is nearly impossible. I did have one somewhat successful experiment with printing ink though. Dyed a Cherry white on black doubleshot WASD keys magenta. Curious to see how they held up. Not sure who has them now as I believe they have been traded around a few times.
« Last Edit: Sun, 16 September 2012, 14:35:17 by lysol »
Offline kinruan
« Reply #10 on: Sun, 16 September 2012, 17:35:01 »
yeah, i do know some of the details since one of my friend  in China is making a bunch of rainbow pbt sets. i am actually looking for a better source of dye for him because all the dye in China is just suck.
« Reply #11 on: Mon, 17 September 2012, 12:31:36 »
Has anyone tried dying those "rainbow" POM keycaps? They are the only ones I know of that aren't black.
« Reply #12 on: Mon, 17 September 2012, 12:59:26 »
You can get full white pom set. I think they are Cherry profile too, been thinking of getting some myself.
Offline jkercado
  • Green XM clickclacker
« Reply #13 on: Mon, 17 September 2012, 21:15:58 »
Has anyone dyed Unicomp grays? I'd like to darken them to a nice anthracite gray...
Ducky 1087XM Green | Unicomp Ultra Classic Black | IBM M4 | 1989 IBM Model M | Genius i200 | Cherry G84-4100 | Microsoft Arc Keyboard
