Author Topic: Post your G80-1800 pictures  (Read 718142 times)
Offline tinlong117
Re: Post your G80-1800 pictures
« Reply #150 on: Wed, 20 November 2013, 08:43:42 »
My first mechanical keyboard arrived today finally. For 10€ there is nothing to complain about and I´m already loving the layout  :thumb:
It features black MX switches and it is to early to tell if Ill stick to it. What is this grey spacebar switch all about? Never read about "grey" MX switches anyway.
I would really appreciate if somebody could give me a hind where Ill could find cheap blank alpha caps shipping to germany. Banggood is still the cheapest vendor...
Cherry always has a stiffer switch for the spacebar than the other keys, so that is what linear gray spacebar switch is for
good luck on getting a complete set of blank keys to fit the entire 1800 layout though as they don't exist...or do they:
http://www.kbdmania.net/xe/photo/540443
http://www.kbdmania.net/xe/photo/536323
they do.
Offline laffindude
« Reply #151 on: Fri, 29 November 2013, 01:21:13 »
;o~~~~
« Reply #152 on: Fri, 29 November 2013, 02:03:33 »
^^ so is the case as nice  as it looks?
Offline laffindude
« Reply #153 on: Fri, 29 November 2013, 05:56:05 »
The case quality actually exceeded my expectation, but don't buy it for the case. I would probably give it a B-. I've owned much better cases. Then again, those cases all cost more than this combo. The factory package is packed very poorly. Only a thin layer of bubble wrap into a thin cardboard. Mine has a few small dings on the edges, a cracked corner plastic piece (not too bad), and a divot where an edge siding piece is digging into the side plate. I am surprised it made it to me without much more damage.
It'll probably go into the collection and occasionally gets fondled. Semi-interesting is that this keyboard is based on an EU ANSI board (see the Euro sign). I've always thought China Cherry distributor imported US ANSI boards.
Offline inlikeflynn
  • file not found
« Reply #154 on: Fri, 29 November 2013, 10:29:37 »
Nice to see one of these boards+case in someones actual hands. bummer about the shipping damage though.
and the board has the Euro sign because they are all the EU models and not the US model for whatever reason. The only difference between the a ENEU and ENUS is the Euro sign. Maybe just all Cherry had left
G80-1865LYNEU-2   MX Red Switches
G80-1865LWNEU-2  MX Blue Switches
G80-1865LXNEU-2   MX Brown Switches
G80-1865LPNEU-2   MX Black Switches
G80-1865LENEU-2   MX Clear Switches
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #155 on: Fri, 29 November 2013, 11:11:07 »
Cherry discontinued use of US and replaced with EU in I think 2009/2010... no idea why... like adding the Euro sign is any kind of importance, as the only Alt Gr character. I really don't see sense in why they renamed as it's still US layout.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #156 on: Sat, 30 November 2013, 13:51:26 »
finally snagged a couple.............
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« Reply #157 on: Sun, 01 December 2013, 03:25:31 »
Dolce Vita
46463-0 46467-1 46461-2
« Last Edit: Sun, 01 December 2013, 08:08:12 by sprit »
« Reply #158 on: Mon, 02 December 2013, 03:36:50 »
Offline phoenix1234
« Reply #159 on: Sun, 09 March 2014, 04:31:20 »
This is a little bit duplication but I post it here to refresh this topic
Here is mine G80-1800 HFU, modded and lubed Vintage Cherry MX Black with 60g spring.
Keycap is mixing between German Cherry thick PBT and US Cherry thin PBT.
I like linear switches
Offline bazh
« Reply #160 on: Sun, 09 March 2014, 04:39:06 »
Gimme dat ecs :'(
HHKB Pro2 white
Newbie again
Offline phoenix1234
« Reply #161 on: Sun, 09 March 2014, 10:27:28 »
Gimme dat ecs :'(
You should have at least one.
It looks very nice on a white keyboard.
« Last Edit: Sun, 09 March 2014, 10:29:05 by phoenix1234 »
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #162 on: Mon, 10 March 2014, 16:11:13 »
« Reply #163 on: Mon, 10 March 2014, 18:30:14 »
Mmm... almost makes me wish I hadn't sold on my 1838. Those bright white keys and the CMYK look so good together.
  • Kitteh Overlord
  • Say WHAAT...
« Reply #164 on: Tue, 11 March 2014, 04:39:05 »
I need to get the ss plate put in it... but I'm scared all jack it all up  ;D
Offline stoic-lemon
« Reply #165 on: Tue, 11 March 2014, 08:30:09 »
Wow that looks beautiful. Would love one of those.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #166 on: Tue, 25 March 2014, 18:33:07 »
Leeku 1800 in custom Magic School Bus case: http://geekhack.org/index.php?topic=56335
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #167 on: Thu, 27 March 2014, 06:19:50 »
Really nice boards, all of you.
I came across this thread after doing some research into these. Got a Skidata (or two) on the way and it seems that those keys fit the ISO G80's.
It would be hilarious to swap the switches for Clears and vinyl wrap it blue to make a mini SkiData XD.
What's a Skidata you say?
|||My other keyboards :
x
Offline kaz
« Reply #168 on: Thu, 27 March 2014, 06:41:36 »
Awesome variety of mods. How much smaller are these than the 11800/11900?
Cherry G80-11800 (Workhorse) | Cherry G80-11900 | \'93 IBM Model M | Apple M0116
Offline Michael
  • Formerly Bro Caps
« Reply #169 on: Thu, 27 March 2014, 09:43:15 »
sorry for the double-post (not really, demik)
Offline daetsid
« Reply #170 on: Thu, 27 March 2014, 17:21:33 »
Will miss u <3  :))
Offline josh
  • Since 2011
« Reply #171 on: Tue, 08 April 2014, 19:25:24 »
So I finally got one!! Of course I forgot to bring it to work today.... ???
REALLY NICE!
OTD 356CL Gunmetal | OTD 356CL Black | OTD 356CL DGE | OTD 356 Mini Military Green | OTD 356 Pad | TGR Jane V2 Blue Grey | TGR Jane V2 Pink | TGR Jane V2 ce E-White | TGR Alice Prototype 1.0 | TGR Alice Pink Silver Two Tone | TGR Alice Polycarbonate | TGR 910 RE Red | TGR 910 ce Silver | TGR x GAF 910 Black | TGR x GAF 910 Purple | Noxary Vulcan Pro Silver | Noxary Evija HG | Keycult No.2/65 Unfinished Red | Realforce 101 | Realforce 10 Year Anniversary | Realforce 23U | HHKB Professional White | HHKB Professional Charcoal | HHKB Snow 25th Anniversary Japan Edition
Offline bazh
« Reply #172 on: Wed, 09 April 2014, 01:52:45 »
Where da hell did you get that full blank set :o
HHKB Pro2 white
Newbie again
« Reply #173 on: Wed, 09 April 2014, 09:22:00 »
Looks like a blank BSP set.
Offline bazh
« Reply #174 on: Thu, 10 April 2014, 01:51:10 »
yeah can tell by the lack of 1.75x shift, but Sherry doesn't have blank numpad available on Originative, or hasn't yet?
HHKB Pro2 white
Newbie again
Offline laffindude
« Reply #175 on: Thu, 10 April 2014, 02:55:47 »
Was there ever a JIS layout 1800? I been mainly using JIS boards and got addicted to the extra keys.
Offline tinlong117
« Reply #176 on: Thu, 10 April 2014, 03:25:32 »
No. Only 3600 and 11800.
Offline Cheesebaron
    • blog
« Reply #177 on: Sun, 20 April 2014, 14:54:37 »
Are all of these these with Mechanical switches? I have found one for very cheap at a local auction site:
http://www.dba.dk/tastatur-blandet-der-er-i/id-1000980715/
4th picture you see a black model.
MINILA       Poker II       Model M
MX Blue      MX Blue       SSK '88
Offline Pacifist
  • on hiatus
« Reply #178 on: Sun, 20 April 2014, 14:57:39 »
if its g80, its MX. If its g81, its MY
but im putting my money on G80 with doubleshots
Offline JonasDK
  • Let me poo on you
« Reply #179 on: Sun, 20 April 2014, 17:38:13 »
I've tried contacting the seller way back, without luck. He doesn't respond (at least in my case he didn't)
Offline Broadmonkey
« Reply #180 on: Mon, 21 April 2014, 02:09:11 »
Lol, I have also tried to contact that idiot for two years now, either he scams people, is too stupid to figure out how to sell anything over dba or plain simply don't want to sell anything.
I once phoned him with luck asking for that exact keyboard and he told me to just write him a mail, which I had done multiply times already and also did again... He never replied or picked up the phone again.
But I think it's a G81 if I have to be honest, but still nice caps. I would love the 1.5 mods on it.
Offline Cheesebaron
    • blog
« Reply #181 on: Mon, 21 April 2014, 05:27:48 »
That is super encouraging. I guess I will call him and take my bike for a spin to visit him. Will let you know how it works out :D
Offline Frenir
  • HHKB Viking
« Reply #182 on: Tue, 22 April 2014, 13:26:45 »
my "yellow sun" and the grey one are based from a G80 1800 (Raptor K1)
Wow, that's pretty damn sexy  :eek:
Offline mildott
« Reply #183 on: Sun, 27 April 2014, 10:49:21 »
Hello.
This is my first post.
I have found (this morning, in Spain) a vintage NIB g80- 1800 series.
The model is G80-1814HEE/00
It means that is a 1800 series but I can not find any information on Internet.
Thank you
« Last Edit: Sun, 27 April 2014, 10:53:50 by mildott »
« Reply #184 on: Sun, 27 April 2014, 10:58:58 »
That's a nice keyboard you have there. Doubleshot keycaps and it should have MX clear switches. Doubleshots in Spanish layout aren't common. It looks very dirty though, not NIB :confused:
Offline mildott
« Reply #185 on: Sun, 27 April 2014, 11:15:56 »
Thanks Photekg.
What is"HEE" mean?
And Yes, the keyboard has dust but (I think it) never was used.
http://www.subeimagenes.com/img/imagen-944308.html
« Reply #186 on: Sun, 27 April 2014, 11:23:22 »
The H means it is doubleshot
The middle E means it has clear switches
The last E means it is spanish layout
See here for more info : http://deskthority.net/wiki/Cherry_article_numbers
« Reply #187 on: Sun, 27 April 2014, 13:13:43 »
Hello.
Thank you
Nice find, that is very lucky as those are quite rare... first I have seen even outside of model number lists.
Offline mildott
« Reply #188 on: Sun, 27 April 2014, 14:48:07 »
Quote from: IvanIvanovich
Thank you Ivan.
I was comparing my 1814 with the 1813 model and are the same. I think that the different number is because is... Spanish?? In any case it is a "mx clear" keyboard and that is very interesting too.
Now I have to clean it "in a easy way" (because I am not capable to dismount it)
« Reply #189 on: Sun, 27 April 2014, 15:01:37 »
Since it just looks dusty and not heavily soiled, just hold it keys down (so the dust falls and doesn't get pushed inside it) and use something like feather duster or some soft bristles paint brush or similar. It's basically how I do my regular cleaning on my keyboards.
Offline tinlong117
« Reply #190 on: Sun, 27 April 2014, 18:22:07 »
Thank you Ivan.
Around 6 years ago, a Korean come up with a G80-1814HEU. It's from a Siemens system.
Link: http://cryo.egloos.com/2383060
Offline Michael
  • Formerly Bro Caps
« Reply #191 on: Sun, 27 April 2014, 18:23:27 »
« Reply #192 on: Sun, 27 April 2014, 18:45:43 »
Oh, I forgot the 1814 was the platemounted one.
Offline mildott
« Reply #193 on: Mon, 28 April 2014, 07:38:33 »
It looks like a very early Cherry g80 model and indestructible.
Offline Broadmonkey
« Reply #194 on: Tue, 29 April 2014, 03:22:14 »
A black ISO winkeyless platemounted 1800 with clears!?!
I am very jelly!
Offline tinlong117
« Reply #197 on: Sat, 03 May 2014, 20:51:41 »
I also forgot that plate is aftermaket one. D:
Offline n2k
  • plasticchair
    • donate skins pls
« Reply #198 on: Tue, 06 May 2014, 07:53:44 »
Work in progress. Might change LEDs, cable and paint bottom half as well.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #199 on: Tue, 06 May 2014, 08:05:44 »
That looks sweet. :-o
Almost like it's an aluminum case.
x
