Author Topic: Post your G80-1800 pictures  (Read 714067 times)
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
Re: Post your G80-1800 pictures
« Reply #450 on: Mon, 08 February 2016, 07:46:19 »
I see :))
I read your post on DT. Did you spare 1800 pcb? (Of course I 'm interested ANSI).
Offline jerue
  • (Whenever that happens :P)
« Reply #451 on: Mon, 08 February 2016, 18:32:50 »
I see :))
If you want a PCB that is essentially broken and with only switch bottoms..sure. But shipping costs would be pretty high.
« Last Edit: Mon, 08 February 2016, 18:36:20 by jerue »
Offline alienman82
« Reply #452 on: Mon, 08 February 2016, 18:36:20 »
removed.
« Last Edit: Thu, 01 March 2018, 16:13:55 by alienman82 »
Offline DanielT
« Reply #453 on: Wed, 10 February 2016, 06:13:35 »
This was a HAD 1800, now it's a unicorn, my wife wanted a happy keyboard so I made this for her, I made her happy because she is the best wife a man can wish for :)
The caps are a mix of almost everything, JTK Purple for alphas, Hyperfuse for Numpad, GMK Purple for ISO Enter, CYMW mods and the Rustler because she deserves only the best. The switches are the original MX Blacks, she loves to type on them.
Offline azhdar
  • Praise the AZERTY god
« Reply #454 on: Wed, 10 February 2016, 09:48:04 »
Well that is colored. :|
Azerty Propagandiste
Offline DanielT
« Reply #455 on: Wed, 10 February 2016, 11:29:32 »
Well, yes  :)) But I'm man enough to type on my wife's keyboard :))
Offline Steezus
  • Keeper of Facts
« Reply #456 on: Wed, 10 February 2016, 11:35:11 »
She was definitely looking over your shoulder and seeing what you were typing. ;)
Offline azhdar
« Reply #457 on: Wed, 10 February 2016, 11:52:50 »
Daniel blink twice if you're held hostage
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #458 on: Wed, 10 February 2016, 11:58:48 »
Offline DanielT
« Reply #459 on: Wed, 10 February 2016, 12:21:14 »
Offline ImpendingxDoom
  • MF the SuperVillain
« Reply #460 on: Fri, 19 February 2016, 13:26:16 »
Offline alienman82
« Reply #461 on: Fri, 19 February 2016, 13:26:57 »
removed.
« Last Edit: Thu, 01 March 2018, 16:05:57 by alienman82 »
« Reply #462 on: Fri, 19 February 2016, 13:42:40 »
I see you are fully embracing the 1800.  ^-^  Nicely done.
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #463 on: Mon, 29 February 2016, 11:55:54 »
I am ready to join soon this gentlemen club of 1800 owners, but have to attach an USB cable to the keyboard - and need an hole in the case therefor. Or should I go with PS/2 and an original untouched cable?
Offline alienman82
« Reply #464 on: Mon, 29 February 2016, 12:12:08 »
removed.
« Last Edit: Thu, 01 March 2018, 16:00:38 by alienman82 »
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #465 on: Mon, 29 February 2016, 14:12:25 »
If you use the Dolch case, you can use USB without visible holes :)
Unfortunately with this G81-1800 case there is not much place :(
Offline azhdar
« Reply #466 on: Mon, 29 February 2016, 14:13:31 »
Does that mean you figured what was up with your pcb ?
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #467 on: Mon, 29 February 2016, 14:15:36 »
Yes, but a workaround, thanks to an idea from suicidal_orange I soldered a bridge to the next empty ENTER place on the PCB:
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #468 on: Thu, 03 March 2016, 05:29:00 »
Here is my entry for this noble 1800 owners club. It is a new G81 case, with a Leeku MX 1800 PCB (v3), unlubed and unstickered MX Reds (but with 55g SPRiT springs), and a mixture of ANSI and ISO German caps. Unfortunately the ANSI set I bought a while ago from Taobao were in a weird profile, and so I mixed the sets. Also i have to re-solder the right ALT switch, it is askew!
Offline appleonama
  • Trollo en USA
« Reply #469 on: Thu, 03 March 2016, 05:30:40 »
dam that is smoking hot great pics
Offline azhdar
« Reply #470 on: Thu, 03 March 2016, 05:32:31 »
I really like this red led.
Would you have a picture of how the usb cable is plugged into the case?
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #471 on: Thu, 03 March 2016, 05:40:16 »
I will make one later, basically I just had to make a cutout for the USB plug. A sharp knive is enough for cutting the case.
Regarding the LED I used one I got from SPRiT (I think he added a RGB set to every order I made), and it glows red now.
Offline appleonama
  • Trollo en USA
« Reply #472 on: Thu, 03 March 2016, 05:44:21 »
where do you guys come across one of these boards? I am highly interested in obtaining one
Offline Khers
  • Schrödinger's box
« Reply #473 on: Thu, 03 March 2016, 05:55:43 »
« Last Edit: Tue, 03 July 2018, 08:30:08 by Khers »
Offline Prelim
« Reply #474 on: Thu, 03 March 2016, 06:29:21 »
gorgeous pics, as always  :eek:
you needed to cut the case frame, right?
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline meow a cat
  • Resistance is futile.
« Reply #475 on: Thu, 03 March 2016, 06:48:26 »
Beautiful Madhias, that looks amazing. Soo classy!  ;D
I'm planning out a Leeku 1800 build right now, and I was wondering if anyone here could tell me if the original PS/2 cables work alright via USB with a converter? I prefer the look of the OG coiled PS/2 cables, but I'd still like some USB action.  :))
Boards:
Offline Khers
  • Schrödinger's box
« Reply #476 on: Thu, 03 March 2016, 06:54:16 »
« Last Edit: Tue, 03 July 2018, 08:30:03 by Khers »
Offline meow a cat
« Reply #477 on: Thu, 03 March 2016, 06:56:55 »
Now, that would be something! I would also like to know this. Double win if that is the case, no need to cut the case _and_ original coiled cable... Yummy!
Yeah, those were my thoughts too. I don't really want to cut the case, so I'll deal with PS/2 if I have to. The cable is sexy enough to make up for it. PS/2 is inconvenient for board swapping though..
Boards:
Offline henz
  • What?
« Reply #478 on: Thu, 03 March 2016, 07:03:16 »
mine is in the mail. cant wait to get it.
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #479 on: Thu, 03 March 2016, 08:32:55 »
I also thought of using PS/2, but as you said board swapping and using it all the time somewhere else makes it so much easier to have USB directly available! I would say with a correct adapter it will work to use the PS/2 mode and cable. I have still the original cable, with original packaging and all, so maybe one time I will change it.
Yes, I had to cut the case, but a sharp knive was enough to do this. It is not that exact, I like it, it could be better though, but it is on the back of the case... I will post a picture later. Now my wife has taken the camera! Arrgh.
Offline jerue
« Reply #480 on: Thu, 03 March 2016, 09:10:22 »
1800 + CMYW = <3
looks great as always. I like the mix of caps!
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #481 on: Thu, 03 March 2016, 09:13:51 »
1800 + CMYW = <3
I'd like to have CMYK though :) I hope there will be a group buy soon.
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #482 on: Thu, 03 March 2016, 13:33:06 »
Here is the picture:
Also I know now that the LED should be automatically change its color! So I may have to swap the resistors that this feature does work.
Offline joey
« Reply #483 on: Thu, 03 March 2016, 13:34:09 »
That doesn't look too bad madhias, you could just get some sandpaper and smooth it out!
Offline alienman82
« Reply #484 on: Thu, 03 March 2016, 13:34:23 »
removed.
« Last Edit: Thu, 01 March 2018, 15:58:01 by alienman82 »
Offline yomammary
« Reply #485 on: Tue, 08 March 2016, 07:58:11 »
Leeku PCB with OG Cherry keycaps and GMK RGB modifiers.
RF 87u 55g | Leeku 1800
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #486 on: Fri, 11 March 2016, 00:57:23 »
Nice, even with RGB leds!
Offline yomammary
« Reply #487 on: Fri, 11 March 2016, 07:40:34 »
« Reply #488 on: Sun, 13 March 2016, 23:08:50 »
Nice touch with the LEDs :)
Offline slickmamba
« Reply #489 on: Sun, 13 March 2016, 23:15:58 »
Whoops, didn't put it in RGB order, sorry haha.  Also, cap incoming
Thanks!  :p
Hi :)
« Reply #490 on: Sun, 13 March 2016, 23:17:19 »
why didn't you go red green blue on the LEDs o.o
1800 has always had a special place in my heart tho.
Offline slickmamba
« Reply #491 on: Sun, 13 March 2016, 23:18:03 »
I SIP socketed them for him and just threw them on in random order
Hi :)
« Reply #492 on: Sun, 13 March 2016, 23:21:11 »
ah, so it can be easily fixed.
you did a great job
Offline appleonama
  • Trollo en USA
« Reply #493 on: Sun, 13 March 2016, 23:32:01 »
how do you find the production date on the 1800 label?
Offline slickmamba
« Reply #494 on: Sun, 13 March 2016, 23:36:21 »
check inside on the controller.  I think
Hi :)
Offline appleonama
  • Trollo en USA
« Reply #495 on: Sun, 13 March 2016, 23:38:02 »
aw lame I am only looking at pictures. I just found an 1800HEU which has clears and I wanted to know its production date.
Offline kokokoy
« Reply #496 on: Mon, 14 March 2016, 01:12:21 »
Offline appleonama
  • Trollo en USA
« Reply #497 on: Mon, 14 March 2016, 01:46:48 »
I'm following this -> https://deskthority.net/wiki/Cherry_date_codes
oh nice I think I found a 1800 from 1995 with clears
Offline yomammary
« Reply #498 on: Mon, 14 March 2016, 07:20:41 »
I'll change them :P
Happy?
Thanks to slickmamba for doing all the hard work :)
First real soldering job for me.
Offline Jokrik
« Reply #499 on: Mon, 14 March 2016, 07:38:11 »
I'll change them :P
Happy?
That's a very interesting mod layout :) in a good way
