Author Topic: Post your G80-1800 pictures  (Read 714127 times)
Offline ideus
  • Björkö.
Re: Post your G80-1800 pictures
« Reply #650 on: Sat, 23 July 2016, 15:55:18 »
Someone that has an spare 1.75u shift? I'd take any color, any type of legend, any material, as long as it is in Cherry profile, if you want to overwhelm me offer me a pair with its matching 2.25u shift.
originative has some on his site if you are not opposed to buying one:
https://www.originativeco.com/products/dolch-1-75u-shift
Of course not at all, thank you for the reference. Wonderful.
Offline codywanks
« Reply #651 on: Sun, 24 July 2016, 03:45:52 »
I might add some color (CMYK) to it but we'll see
Hi Elth, could you please post pics of the areas on the plastic case you had to cut/file down to acommodate Leeku's plate/PCB?
I went in not knowing that the case needed to be cut, so pretty much everything is done except that.
The keyboard is currently at work so I can't snap any pictures right now, but don't be discouraged after finding out you need to modify the top case for it all to fit.
I've circled the areas on the plate that interfere with the top case; the cuts are very small except for the piece in between the F-row and number row. Also, I'm not 100% on the spot above the Esc and the spot below where the 3 indicator LED's are, but when you try to assemble you'll see if it needs to be cut
Thanks Elth, I've identified the same 7 points - that was the easy bit. What I'm struggling with is gauging/measuring how much of plastic from each section needs to be removed. I thought I'd just go for it & started filing the left arrow key section but it was so slow, imprecise and messy that I just gave up. Maybe I'm not using the right tools.
On top of that, I'm not sure how the cable is supposed to be routed as there doesn't seem to be enough space left inside the case (unless the preexisting USB-mini socket can somehow be repositioned, or there's a daughterboard/other parts I'm either missing or unaware of).
It's frustrating to be stuck at this stage as all the electronics work has been done.
Offline alienman82
« Reply #652 on: Sun, 24 July 2016, 08:33:48 »
removed.
« Last Edit: Thu, 01 March 2018, 14:59:41 by alienman82 »
Offline Elth
« Reply #653 on: Sun, 24 July 2016, 11:11:58 »
What I did to measure was place the top case on the plate (this was before anything was soldered) and used a marker to mark how much plastic I needed to remove.  I then used a utility knife to cut the plastic and then gently broke off the piece with a pair of pliers. You could also use a dremel if you have one, but I would work slow with that as well.
Picture credit to madhias (few pages back in this thread)
As far as the USB cable, if you're direct soldering to the board (which it sounds like you're doing), I ran the cable on the underside of the PCB and there is plenty of room. Basically run the wires from the underside of the pcb and solder them on the top. You can also use the small hole above F7 to secure the USB cable with a zip tie; just helps to reduce the risk of accidentally pulling the cable out.
Hope this helps.
Offline jerue
  • (Whenever that happens :P)
« Reply #654 on: Sun, 31 July 2016, 13:03:45 »
Sharing some love...here's photos of all my 1800 style boards:
G80-1800HAU, like new, 62g vintage blacks
Cherry G80-1800 HAU
Cherry G80-1800HAU PCB
G81-1800HQU, really got this for the WoB winkeyless caps:
G81-1800HQU front side
nice White on Black Cherry Doubleshot keycaps
(the doubleshot detailing on this one is really clean)
Recently acquired Dolch PAC, not a 60 or 65 and not sure how to tell...it's nice to see one of these in decent shape!
Dolch PAC keyboard
And then there's this old 11800 I just picked up...long story but this will be swapped with thick PBT caps and 1997 browns at some point (has a mix of thick/thin caps and 1999 browns)
Compaq G80-11800
Offline mrboovn
« Reply #655 on: Sun, 31 July 2016, 16:21:02 »
Cherry G80-1800 HAU
Dolch PAC keyboard
Compaq G80-11800
What a nice collection jerue.I am waiting for leeku PCB to own my first 1800 :D
Offline alienman82
« Reply #656 on: Sun, 31 July 2016, 17:35:50 »
removed.
« Last Edit: Thu, 01 March 2018, 14:28:06 by alienman82 »
Offline Giorgio
« Reply #657 on: Wed, 03 August 2016, 07:10:42 »
Cherry G80-1800 HAU
Dolch PAC keyboard
Compaq G80-11800
where did you buy the leeku pcb?
Offline alienman82
« Reply #658 on: Wed, 03 August 2016, 17:20:15 »
removed.
« Last Edit: Thu, 01 March 2018, 14:26:22 by alienman82 »
Offline Giorgio
« Reply #659 on: Thu, 04 August 2016, 02:53:28 »
Cherry G80-1800 HAU
Dolch PAC keyboard
Compaq G80-11800
just pm or email here: leeku11@gmail.com
I've ordered from him 3+ times now.
thanks, are there some reviews of said pcb?
I've found the thread, which is locked because the site isn't available anymore?
Anyway I'll contact him :-)
https://geekhack.org/index.php?topic=73845.0
Offline alienman82
« Reply #660 on: Thu, 04 August 2016, 07:03:57 »
removed.
« Last Edit: Thu, 01 March 2018, 14:25:02 by alienman82 »
Offline duynguyenle
  • Personal text? What personal text???
« Reply #661 on: Sat, 27 August 2016, 06:14:30 »
Look what the cat dragged in  :D
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline Giorgio
« Reply #662 on: Sat, 27 August 2016, 07:13:11 »
Nice one! Where did you get it? Price?
Offline duynguyenle
« Reply #663 on: Sat, 27 August 2016, 08:04:18 »
80 euros from Amazon DE. I got the last one they have.  :thumb:
Offline Giorgio
« Reply #664 on: Sat, 27 August 2016, 09:05:16 »
Thank you  :)) :thumb:
Offline juahenza
  • DoSmallThingswithGreatLove
« Reply #665 on: Sat, 27 August 2016, 09:21:30 »
wow thats a very good deal. congratz :thumb:
456GT | TGR Jane CE | Dolphin v2 | Whale | 360c | LZ FE | LZ IRON | TX-CP | Varmilo VA87M | HHKB P2 | IBM SSK P.1397681| IBM Industrial SSK P.1395682 | VE.A | Realforce 87u | Datamancer Streamline TKL | Datamancer Mechinist TKL | TANK v1 | RAMA M-4 | Realforce 108UW-HIPRO
Offline Giorgio
« Reply #666 on: Mon, 29 August 2016, 09:07:19 »
shwitches are pcb mounted, but you can't open them, because they have a sort of bezel that needs to be removed manually with a knife or something similar
Offline Giorgio
« Reply #667 on: Mon, 29 August 2016, 09:08:49 »
Just some considerations about the size of this fantastic keyboard.
g80-1800
Dimensions (product):
approx. 405 x 180 x 44 mm
g80-3000
approx. 470 x 195 x 44 mm
That's a difference of 65mm or 2.55 inches, which is a lot!!
If the bezel of the g80-1800 was more modern and smaller (let's say as big as the novatouch), the g80-1800 could measure only 380mm!! Which is a fantastic result considering that a tkl measures about 360mm
novatouch
approx. 359 x 39 x 138 mm
pok3r
approx. 292 x 103 x 38mm
Offline kinglukas38
  • Do you even tactile?
« Reply #668 on: Sat, 03 September 2016, 20:10:50 »
freshly built, 100g vintage blacks with 150g (activation weight) on the spacebar and arrows
I've never done it before, but I'm pretty sure I'm good at it
Offline alienman82
« Reply #669 on: Sat, 03 September 2016, 20:38:19 »
removed.
« Last Edit: Thu, 01 March 2018, 14:13:24 by alienman82 »
Offline kinglukas38
« Reply #670 on: Sat, 03 September 2016, 20:41:17 »
woah you like em heavy!
They're a little lighter than the tactile greys I use on my daily, but still nice
Offline xondat
  • i'm not a star
« Reply #671 on: Sun, 04 September 2016, 07:38:19 »
That's super heavy :eek:
What does it feel like to type on 65g or something like that?
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #672 on: Sun, 04 September 2016, 08:09:57 »
Someone sell me their g80 pronto
Offline kinglukas38
« Reply #673 on: Sun, 04 September 2016, 09:35:54 »
No idea, I don't own a board with anything less than 100g :p
Offline Giorgio
« Reply #674 on: Sun, 04 September 2016, 15:22:27 »
I need to know your wpm and how long do you type :-)
Offline funderburker
« Reply #675 on: Mon, 12 September 2016, 10:20:20 »
Keyboard design by Skepur
Offline nemron
« Reply #676 on: Thu, 29 September 2016, 16:40:54 »
Raptor Gaming K1 alias Cherry G80-1890LUADE-2
149421-0
  • Cherry MX Clears from old G80-3000
  • green Status-LEDs, the standard blue ones were too bright
  • Cherry DyeSubs from old G81-3000
  • EnjoyPBT light gray/beige blanks and CMY-Mod-Pack
Offline Rayndalf
« Reply #677 on: Wed, 05 October 2016, 19:07:21 »
Any clue if Leeku still has any 1800 pcbs? I'd love to retrofit a g81 and live the NKRO dream...
Offline duynguyenle
« Reply #678 on: Wed, 05 October 2016, 19:37:48 »
Last I heard, he's out of stock. If there's enough interest, there's probably an opportunity for a mini GB there.
« Reply #679 on: Mon, 10 October 2016, 04:38:44 »
Spent a long long time lubing this thing and making it awesome!  Going to get a nice coiled cable for it in the future.  :thumb: :thumb: :thumb:
I've come to realise that I like white backlighting.
And this picture only serves to reinforce that liking :)
Offline Giorgio
« Reply #680 on: Mon, 10 October 2016, 07:15:25 »
yes yes yes please contact him if you have his contacts
Offline ideus
  • Björkö.
« Reply #681 on: Mon, 10 October 2016, 07:15:54 »
Cherry G80-1800 HAU
Dolch PAC keyboard
Compaq G80-11800
Nice collections, congratulations.
Offline kinglukas38
« Reply #682 on: Mon, 10 October 2016, 11:22:03 »
I just bought one yesterday from leeku, pcbs only, no plates
Offline duynguyenle
« Reply #683 on: Mon, 10 October 2016, 11:47:49 »
So it's back in stock? Nice!!!  :thumb:
Offline Giorgio
« Reply #684 on: Mon, 24 October 2016, 02:31:31 »
g80-1800, temporarily with lasered keys, while waiting for gmk beige doubleshots....
Spring swapped with sprit 50gr springs... The uniqey clips precompress the spring, so the switch becomed heavier; to better approximate mx reds I used some lighter springs, which makes them almost indistinguable from cherry mx reds (wich are a little bit heavier, we are talking about a couple of grams). I lubed only the base of the spring by dipping them in krytox oil (from sprit too).
Completely silenced with gmk uniqey clips. Oh, the joy!!!!!
151068-0
151070-1
151072-2
« Last Edit: Sat, 29 October 2016, 02:00:45 by Giorgio »
Offline getf
  • In Rod We Trust
« Reply #685 on: Sat, 05 November 2016, 11:59:56 »
My Industrial Grey G80 1867 EN/KR
« Reply #686 on: Sat, 05 November 2016, 12:31:39 »
Ueber frosh.
Offline ba7777
« Reply #687 on: Sat, 05 November 2016, 17:30:27 »
Is it pained or original grey?
Offline ideus
  • Björkö.
« Reply #688 on: Sat, 05 November 2016, 18:14:45 »
It looks great, congratulations Giorgio. Even with lasered key caps the tuxedo combination rocks.
Offline Giorgio
« Reply #689 on: Sat, 05 November 2016, 18:29:14 »
thanks, now I notiche that I need to add the black keys on the 2 top rows on the right, above the numpad :-)
Offline ideus
  • Björkö.
« Reply #690 on: Sat, 05 November 2016, 19:09:25 »
Indeed.
Offline hillmu
« Reply #691 on: Tue, 08 November 2016, 00:49:03 »
Not enough GMKs to fillin, waiting for Dolch Reborn key set coming. I give this keyboard name "Dolch Reborn"
« Last Edit: Tue, 08 November 2016, 01:11:38 by hillmu »
Offline DannyHuynh
« Reply #692 on: Thu, 10 November 2016, 20:23:00 »
Here ma Carbon Dolch
Offline mrboovn
« Reply #693 on: Thu, 10 November 2016, 20:54:57 »
it would be perfect if the spacebar is dolch  :)) :))
Offline juahenza
« Reply #694 on: Mon, 21 November 2016, 00:44:23 »
thats super awesome! what switches it came with? and whats the condition like? looks nib to me  :thumb:
Offline orpheo
« Reply #695 on: Sat, 26 November 2016, 12:42:43 »
My two french Dolch, they are my dreams come true...
Note that one is from a Dolch Pac 586, the other one from a Dolch Pac 486.
The newer 586 keyboard has turquoise cord plug! Never seen this color before!
Offline alienman82
« Reply #696 on: Sat, 26 November 2016, 13:07:39 »
removed.
« Last Edit: Thu, 01 March 2018, 13:34:56 by alienman82 »
Offline Giorgio
« Reply #697 on: Sun, 04 December 2016, 03:02:55 »
Maybe you want to show your support for modern 1800 layout, with gmk Olivetti?
https://geekhack.org/index.php?topic=86104.new#new
Offline PharaoRamsesII
« Reply #698 on: Tue, 06 December 2016, 14:36:24 »
My 3 newly acquired G1800s
154807-0
from 2009 with keycaps from the mxboard 3.0
154809-1
from 2012
154811-2
from 2006
Offline kiwi99
  • that's a gnarly dookie
« Reply #699 on: Tue, 06 December 2016, 20:23:39 »
from 2012
from 2006
nice chess boards  :)
