Author Topic: Post your G80-1800 pictures  (Read 714215 times)
Offline jerue
  • (Whenever that happens :P)
Re: Post your G80-1800 pictures
« Reply #750 on: Tue, 02 May 2017, 15:21:34 »
You will need to buy a standard 1800 keyboard and either swap the switches or the stems. I don't recall ever seeing G80-1800 keyboard with anything other than mx Black (with the exception of Skidata which had mx clear) (11800 and 11900 were made with MX brown, but they're not true 1800 layout and the keycaps are not totally compatible due to the 2u right shift.
blues and blacks, I only saw those versions. Opening the switches and replacing the springs is very fast though. I've just ordered the new cherry silent switches for my g80-1800
Didn't Dolch come with Blues sometimes?
Yea, though for the actual part number G80-1800, I think this only has MX blacks. Different switches usually have part number variations,
1804 - clears (or blacks)
1813 HF* - blues
1824 - clears
1838 - browns (vintage)
1854 HAF - blacks
The ones with winkeys come in several different switch types, e.g. 1865/1890 - blues, browns, or reds depending on the product code
Offline duynguyenle
  • Personal text? What personal text???
« Reply #751 on: Tue, 02 May 2017, 19:57:15 »
Big facepalm moment, I totally forgot about Dolch (and from someone who owns a Dolch Pac keyboard, no less!).
Yes the Dolch Pac boards did indeed come with MX Blues and also a single MX Green switch under the spacebar.
Shameless Dolch Pac plug:
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #752 on: Wed, 03 May 2017, 15:50:12 »
Duuuuuuude, how did you get an ISO one? The one that came with my PAC is ANSI :(
Offline duynguyenle
« Reply #753 on: Wed, 03 May 2017, 16:27:30 »
Lucked out with a Deskthority Classified listing  :p
I'll probably convert it with a Leeku PCB and bring it to the next meetup  ;)
Offline katushkin
  • Just the guy
« Reply #754 on: Wed, 03 May 2017, 17:39:57 »
Convert it to what?
Offline duynguyenle
« Reply #755 on: Wed, 03 May 2017, 17:50:24 »
Convert it to what?
Convert it to use a Leeku PCB >_<
The stock G80 PCB only supports 2KRO
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #756 on: Wed, 03 May 2017, 18:09:32 »
Convert it to what?
I still need one of those with a plate. I've got a mint G81-1800 case with UK doubleshots that needs to be used.
|||My other keyboards :
x
Offline alienman82
« Reply #757 on: Wed, 03 May 2017, 23:22:43 »
removed.
« Last Edit: Thu, 01 March 2018, 12:57:32 by alienman82 »
Offline katushkin
  • Just the guy
« Reply #758 on: Thu, 04 May 2017, 00:00:04 »
Convert it to what?
Still works though! I'm not converting mine, I love the old internals. NKRO is overrated ;)
Offline duynguyenle
« Reply #759 on: Thu, 04 May 2017, 02:44:30 »
Convert it to what?
Oh don't get me wrong, I'm not throwing away the OG Dolch Pac internals, I'll keep it around for nostalgia's sake. Also because I don't come across UK version of the Pac very often so it's unique  :thumb:
Offline autobot
« Reply #760 on: Wed, 10 May 2017, 12:59:08 »
My first vintage Cherry!
Cherry G80-1800HFU with vintage Blues. Feels great and in pretty decent shape. Just ordered some adapters to hook this thing up, and am going to give the keycaps & housing a cleaning!
First thing I did was plop some CMYK on this bad boy, looks great! Excuse the potato, was excited when it came in.  :p
Offline middaparka
« Reply #761 on: Wed, 10 May 2017, 13:53:29 »
Nice - the keycaps on the earlier G80-1800's are much nicer than the newer ones. (Recently picked up a 1800 and swapped the modern MX blacks for blues - next up will be some nicer caps.)  :)
Offline Acerk
  • I pay attention to details!
« Reply #762 on: Fri, 12 May 2017, 13:49:41 »
  • Leeku MX1800
  • Stainless Steel plate
  • Gateron Yellow
  • Lubed stabilizers
  • Clipped stabilizers
Aww yeah!
Close enough.
Offline Khers
  • Schrödinger's box
« Reply #763 on: Fri, 12 May 2017, 14:04:12 »
« Last Edit: Tue, 03 July 2018, 09:11:33 by Khers »
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #764 on: Fri, 12 May 2017, 14:15:48 »
Looking good  :thumb:
Offline Acerk
« Reply #765 on: Fri, 12 May 2017, 14:36:03 »
Got some desoldering help from my brother. Now I can sleep tonight.
Offline merlin64
    • MechMerlin
« Reply #766 on: Fri, 12 May 2017, 14:36:34 »
I have a dolch pac case + leeku pcb that I still need to build. I finally got to see and touch a G80 1800 at the Portland Meetup a few months ago. I see that the G80 1800 is still actually available new. Is there some reason why the older ones are preferred over these new ones? Is it the keycap quality?
Offline Acerk
« Reply #767 on: Fri, 12 May 2017, 14:43:02 »
It depends on what you're looking for. I thought the keycaps felt good compared to other stock keycaps, but they are etched or lasered. You notice the patterns slightly under your fingers. If you're looking for a vintage look, they don't have it. They're grey, not warm. I do think that color looks good on the case, but you can probably find a cheaper deal on an old G80-1800 case if you're planning to switch out the PCB. Typing on a stock, PCB mounted G80-1800 feels terrible. There's so much flex.
This is what the new ones look like
http://www.cherry.de/cid/compact_keyboards_G80-1800.htm?rdeLocationAttr=0&rdeLocaleAttr=en&switch=true
« Last Edit: Fri, 12 May 2017, 14:45:27 by Acerk »
Offline alienman82
« Reply #768 on: Fri, 12 May 2017, 14:43:31 »
removed.
« Last Edit: Thu, 01 March 2018, 12:56:32 by alienman82 »
Offline merlin64
    • MechMerlin
« Reply #769 on: Fri, 12 May 2017, 14:46:30 »
I figured the keycaps would be lasered. I watched a Linus Tech Tips video in which they showed some machine just engraving all the keycaps while already on the board.
I'd ideally love to find an old G80 18XX, but I actually have never seen one on eBay haha. I've seen plenty MY versions though. I'll see if I can finish the Dolch this weekend and I'll be able to post a photo up here.
Offline Acerk
« Reply #770 on: Fri, 12 May 2017, 14:48:55 »
I've read a number of places that you can put a Leeku MX1800 PCB into the G81-1800 (MY) case. I just purchased one myself for my next build. But if you put out a classifieds thread or post on MechMarket, you will find one in a short while. That's how I got my case.
You have to make some notches on the top half of the case to fit the Leeku MX1800 plate into the case. I did that today and it took some hours with a file and knife.
« Last Edit: Fri, 12 May 2017, 14:51:19 by Acerk »
Offline merlin64
    • MechMerlin
« Reply #771 on: Fri, 12 May 2017, 15:08:34 »
I have a plate, but I like the PCB feel better. I'm mainly looking for a stock G80 1800 just for the collection
Offline kinglukas38
  • Do you even tactile?
« Reply #772 on: Fri, 12 May 2017, 15:16:35 »
leeku pcbs and plates fit in g80 and g81 boards, the case is the same just different guts :)
I've never done it before, but I'm pretty sure I'm good at it
Offline funderburker
« Reply #773 on: Fri, 12 May 2017, 15:44:49 »
  • Leeku MX1800
  • Gateron Yellow
  • Lubed stabilizers
Aww yeah!
Close enough.
Damn, that looks nice. How's the Gateron Yellows? Have you had experience with MX/Gat Blacks?
Keyboard design by Skepur
Offline Acerk
« Reply #774 on: Fri, 12 May 2017, 17:19:45 »
I really like them. They feel a bit like lubed switches, without the mushiness. I have tried MX Red, MX Black and Gateron Yellow. I prefer the yellows, but only by a small margin over MX Red. I think it's a much bigger deal if the stabilizers are mushy or rattly.
Offline duynguyenle
« Reply #775 on: Fri, 12 May 2017, 19:54:15 »
Stock G80-1800 is just about one of the worst typing experience you can get, lots of flex, PCB sometimes shift around a little bit as you type, scratchy MX Blacks (at least the ones made in the noughties and 2010s, earlier ones have a chance of having vintage blacks.
Also, new 1800 keyboards come with 1u bottom rows and offset stem 6u caps, which for me is a slightly less desirable layout for a 1800 (don't mind it too much personally, but it does take a period of adjustment when I switch between keyboards with and without this bottom row arrangement)
Offline autobot
« Reply #776 on: Mon, 15 May 2017, 09:47:19 »
So I just got the Din5-to-PS2 and PS2-to-USB adapters, and gave the 1800 a cleaning, and it works great!
"PgDn" and "Scroll Lock" seem to have some loose solder joints (they don't register 100% of the time), so I'll remedy that.
I need to adjust to the overall layout, but I love having the numpad in a compact footprint!
Offline Giorgio
« Reply #777 on: Mon, 15 May 2017, 09:59:31 »
wow, where's the upvote button?
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #778 on: Mon, 15 May 2017, 10:17:23 »
Try here
Offline Giorgio
« Reply #779 on: Mon, 15 May 2017, 12:00:24 »
Try here
Sorry, It gives me the error 303 keyboard not found.
« Last Edit: Mon, 15 May 2017, 12:15:11 by Giorgio »
Offline autobot
« Reply #780 on: Mon, 15 May 2017, 13:58:06 »
Try here
I think the link was meant as a joke?
Also, thanks for the compliment! I love this board!
« Last Edit: Mon, 15 May 2017, 17:38:34 by autobot »
Offline Urbi
« Reply #781 on: Sun, 21 May 2017, 13:33:53 »
1813 HF* - blues
1824 - clears
1854 HAF - blacks
There were also early iso-de (QWERTZ) Raptor Gaming K1 with Cherry MX browns and DS keycaps. AFAIR the K1 was released in 2005 and only some of the very first had browns. To my knowledge these all were QWERTZ. I know this for sure because I have a K1 with browns laying around somewhere. AFAIK there also is the Cherry "HUMUS" (G80-1863HUMUS-2) with browns.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #782 on: Sun, 21 May 2017, 14:58:36 »
HUMUS is a great name though.
x
Offline jerue
« Reply #783 on: Sun, 21 May 2017, 20:46:59 »
HUMUS-2 also had MX Blacks...but with the WnV edition the real showstopper is the original Cherry Corp red Esc key (that once sold for $250 here on geekhack and is ripster's favorite story about keycap appreciation) and the WnV keys.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #784 on: Mon, 22 May 2017, 16:38:54 »
I remember that one. That was a Chinese market limited edition with its own special carrying case wasn't it?
EDIT: More info and more pics here.
Dat two-tone case! </3
« Last Edit: Mon, 22 May 2017, 16:44:16 by JaccoW »
x
Offline duynguyenle
« Reply #785 on: Mon, 22 May 2017, 17:25:16 »
I'm assuming it's just a differently coloured version of the Raptor K1 since the USB Hub at the back looks identical? (even comes with the switch blockers)
Cool board nonetheless, as a whole I think I still prefer the Raptor K1 due to the glow in the dark keycaps but that's personal preference  :))
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #786 on: Mon, 22 May 2017, 17:35:05 »
So what happens when you plug your mouse into the "headset" usb port? Does it blow up?! :D
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #787 on: Mon, 22 May 2017, 17:38:42 »
It squeaks! Duh! :P
x
Offline digi
  • elite af tbh
« Reply #788 on: Mon, 22 May 2017, 17:52:23 »
It squeaks! Duh! :P
Figures.. :D
Offline kiwi99
  • that's a gnarly dookie
« Reply #789 on: Mon, 22 May 2017, 21:29:56 »
Anyone have a spare leeku plate? or maybe the files are out there? looking to cut one for a build.
Offline Acerk
« Reply #790 on: Tue, 23 May 2017, 16:13:27 »
If it's for the L3, contact kin25 who's running the TX1800v2 GB directly. I got a plate and PCB for Cherry G80-1800 case sent immediately. Look at the plate options in the thread.
Offline streetwizzur
  • ok
« Reply #791 on: Fri, 26 May 2017, 15:05:47 »
brought my 1800 into work, this is for sure top tier layout
Offline kinglukas38
« Reply #792 on: Fri, 26 May 2017, 18:53:15 »
Don't think I would consider 1u bot row 'top tier'  :p
Offline avantdark
« Reply #793 on: Sat, 27 May 2017, 05:43:42 »
Someone sells these for 8€ on eBay.de
Btw are other 1800 layout boards allowed here, too?
Gesendet von iPhone mit Tapatalk
Offline alienman82
« Reply #794 on: Sat, 27 May 2017, 12:34:00 »
removed.
« Last Edit: Thu, 01 March 2018, 12:52:25 by alienman82 »
  • ok
« Reply #795 on: Sat, 27 May 2017, 22:43:20 »
w/e it works and i like it
Offline autobot
« Reply #796 on: Sun, 28 May 2017, 06:56:38 »
I consider it top tier too!
While the 1.5 bottom row is more visually "classic", in practice, I actually find it uncomfortable for CAD work. I tap/hold control, shift, and alt constantly w/my pinky, ring and middle fingers, respectively. So the "classic" layout makes for a cramped hand pretty quickly. I imagine the 1u version being much more comfortable for my application.
I also like the fact that your more modern layout enables the use for command shortcuts on MacOS.  :D
Offline avantdark
« Reply #797 on: Sun, 28 May 2017, 07:00:54 »
On my Model M I mapped Caps to Ctrl, Ctrl to Option and Alt to Command. Works for me
Offline autobot
« Reply #798 on: Sun, 28 May 2017, 07:06:18 »
Tru dat, bruh.  :p
I do need to try that arrangement, lots of people rave about it!
Offline ba7777
« Reply #799 on: Fri, 02 June 2017, 18:38:47 »
new stuff. ;D
