Author Topic: Post your G80-1800 pictures  (Read 714058 times)
Offline fknraiden
Re: Post your G80-1800 pictures
« Reply #550 on: Fri, 15 April 2016, 01:18:20 »
vesp beat me to it.. but yeah, best combo NA
best combo is topre and topre
« Reply #551 on: Fri, 15 April 2016, 01:19:03 »
oh bby talk topre to me
Offline appleonama
  • Trollo en USA
« Reply #552 on: Fri, 15 April 2016, 01:31:47 »
Oh god soldering the smd resistors and diodes is going to take forever  :'(
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #553 on: Fri, 15 April 2016, 01:45:58 »
You can do it. It's worth it.
Offline alienman82
« Reply #554 on: Sat, 23 April 2016, 09:55:01 »
removed.
« Last Edit: Thu, 01 March 2018, 15:27:06 by alienman82 »
Offline Prelim
« Reply #555 on: Sat, 23 April 2016, 09:59:30 »
turquoise FTW!
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline ba7777
« Reply #556 on: Sat, 07 May 2016, 20:39:21 »
A new member to my collection  :cool:
Offline Jokrik
« Reply #557 on: Sat, 07 May 2016, 20:43:20 »
Dolch Pac never cease to amaze me
Offline mason
  • have fun with her, ryan
« Reply #558 on: Sat, 07 May 2016, 21:03:44 »
dam daniel
Offline alienman82
« Reply #559 on: Sat, 07 May 2016, 22:50:24 »
removed.
« Last Edit: Thu, 01 March 2018, 15:17:02 by alienman82 »
Offline yomammary
« Reply #560 on: Sun, 08 May 2016, 08:32:29 »
It's over.  :thumb:
RF 87u 55g | Leeku 1800
Offline alienman82
« Reply #562 on: Mon, 09 May 2016, 02:27:44 »
removed.
« Last Edit: Thu, 01 March 2018, 15:16:39 by alienman82 »
Offline henz
  • What?
« Reply #563 on: Mon, 09 May 2016, 03:30:28 »
da potato
so you cut the case :)
Certainly, i had to modify the case alot in order to get it to fit with the plate.
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #564 on: Mon, 09 May 2016, 04:14:11 »
da potato
Certainly, i had to modiff the case alot in order to get it to fit with the plate i have also
Can you show that via more pics?
Offline meow a cat
  • Resistance is futile.
« Reply #565 on: Tue, 10 May 2016, 17:23:52 »
da potato
I'd be interested in seeing this too. I have the Leeku V3 PCB and plate, and a stock G81 case. Waiting on switches, but I'll be building it soon. Would be good to see what changes to the case I have to do, I thought it fit in there as is besides the USB.
Boards:
Offline yomammary
« Reply #566 on: Wed, 11 May 2016, 08:31:38 »
da potato
It does.
Offline DanielT
« Reply #567 on: Wed, 11 May 2016, 08:39:10 »
Dolch PCB inside a G80-1800 case
Offline henz
  • What?
« Reply #568 on: Wed, 11 May 2016, 08:40:23 »
da potato
It does.
Mind the ugly cuts, ill fix them up when i hook up my drilling tool, i just made the necessary cuts with some clippers to get it to fit
Offline yomammary
« Reply #569 on: Wed, 11 May 2016, 12:35:24 »
da potato
It does.
Wasn't it because you used a plate?
Offline henz
  • What?
« Reply #570 on: Wed, 11 May 2016, 12:57:32 »
da potato
It does.
Yep, im just saying the mods will look nicer eventually =)
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #571 on: Wed, 11 May 2016, 12:58:32 »
Dolch PCB is so pretty. I gotta sort mine out soon.
Offline mason
« Reply #572 on: Thu, 19 May 2016, 08:47:54 »
137475-0
« Reply #573 on: Thu, 19 May 2016, 09:11:51 »
That set!!!   :-*
Lovely board you've got there.  :D
Offline mason
« Reply #574 on: Thu, 19 May 2016, 09:19:40 »
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #575 on: Thu, 19 May 2016, 09:44:15 »
That set!!!   :-*
Thank you! s/o to infiniti
:cool: Lookin' good!
Is that the 1800 I worked on?  Swapped out the case?
Offline mason
« Reply #576 on: Thu, 19 May 2016, 10:42:34 »
That set!!!   :-*
Yup, I like to swap between this one and the black one
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #577 on: Thu, 19 May 2016, 20:35:59 »
That set!!!   :-*
Niiiice!  Imma need an 1800 so I can legitimately post here. :p
  • Frenzy Classic.
« Reply #578 on: Thu, 19 May 2016, 23:07:19 »
That set is so greatting! Where do you get it? What board from?
Offline alienman82
« Reply #579 on: Thu, 19 May 2016, 23:08:14 »
removed.
« Last Edit: Thu, 01 March 2018, 15:10:25 by alienman82 »
  • Frenzy Classic.
« Reply #580 on: Thu, 19 May 2016, 23:39:26 »
looks like the enjoy PBT set  :)
LOL... I thought it's Cherry original.
Offline alienman82
« Reply #581 on: Thu, 19 May 2016, 23:40:07 »
removed.
« Last Edit: Thu, 01 March 2018, 15:10:19 by alienman82 »
Offline alienman82
« Reply #582 on: Thu, 09 June 2016, 19:33:00 »
removed.
« Last Edit: Thu, 01 March 2018, 15:04:41 by alienman82 »
Offline mason
« Reply #583 on: Thu, 09 June 2016, 22:33:32 »
Spent a long long time lubing this thing and making it awesome!  Going to get a nice coiled cable for it in the future.  :thumb: :thumb: :thumb:
das nice. what switches? i've always wanted backlighting on my 1800 :(
Offline yomammary
« Reply #584 on: Fri, 10 June 2016, 07:50:01 »
Good job!
Offline juahenza
  • DoSmallThingswithGreatLove
« Reply #585 on: Fri, 10 June 2016, 08:22:32 »
sooooo well done  :thumb:
456GT | TGR Jane CE | Dolphin v2 | Whale | 360c | LZ FE | LZ IRON | TX-CP | Varmilo VA87M | HHKB P2 | IBM SSK P.1397681| IBM Industrial SSK P.1395682 | VE.A | Realforce 87u | Datamancer Streamline TKL | Datamancer Mechinist TKL | TANK v1 | RAMA M-4 | Realforce 108UW-HIPRO
Offline alienman82
« Reply #586 on: Fri, 10 June 2016, 10:18:43 »
removed.
« Last Edit: Thu, 01 March 2018, 15:04:39 by alienman82 »
Offline Khers
  • Schrödinger's box
« Reply #587 on: Fri, 10 June 2016, 14:23:47 »
« Last Edit: Tue, 03 July 2018, 08:40:02 by Khers »
Offline alienman82
« Reply #588 on: Fri, 10 June 2016, 16:01:47 »
removed.
« Last Edit: Thu, 01 March 2018, 15:04:36 by alienman82 »
Offline ramnes
  • T fou, mec?
« Reply #589 on: Fri, 10 June 2016, 16:58:42 »
Nice one bud!
Offline katushkin
  • Just the guy
« Reply #590 on: Fri, 10 June 2016, 17:07:07 »
NOICE
Offline juahenza
« Reply #591 on: Mon, 13 June 2016, 02:03:01 »
Found this piece at taobao and got it for 110usd. Model is G81-1800
just received it not more than an hour ago. unpacked and find the condition of the keyboard is almost like new except a small scratch on the spacebar.
started typing on it and this how i feel generally,
- the switches feels a bit clumsy, not as crisp as my other blue switches
- the typing experience feels hollow, very plastic
- key caps are 99.5% brand new. Love the caps
- Love the layout, good for working and even gaming.
- the case is way too thin, when you accidentally tap on it you can actually hear that hollow plastic sound.
Plans
- changing the pcb (possibly leeku with plate)
- lube all the switches or even maybe changing them
- add LEDs, orange is my color
- spray the case to dolch color
- custom a usb cable for it
- custom pvc sticker for the num lock,caps lock and scroll lock indicators.
Would love to hear what you guys think about the mods im gonna make. any suggestions?
Offline katushkin
  • Just the guy
« Reply #592 on: Mon, 13 June 2016, 02:25:29 »
Wait, so someone sold you an 1800 with dolch caps? Are they GMK or OG Dolch?
Offline juahenza
« Reply #593 on: Mon, 13 June 2016, 03:00:26 »
OG
Offline DanielT
« Reply #594 on: Mon, 13 June 2016, 05:05:36 »
This might be one of the rare Dolch Keyboards https://deskthority.net/wiki/Cherry_G80-1813 , and if this is the case I wouldn't mod it. 1800 case are easy to find and cheap, it would be a shame to mod something rare, if this is the case.
Maybe you can post more details :)
Offline juahenza
« Reply #595 on: Mon, 13 June 2016, 05:34:29 »
This is the back
This is cut from the page, a message from seller, saying : (Google Translated)
Used keyboard , Condition very new . Removed from the industrial cabinet , keyboard cap absolutely no signs shine !
Keyboard inside very clean! !
MY 1800 is to take the housing shell traded . Because the original IPC keyboard shell , especially ugly !
Keyboard board is absolutely standard G80-1813HFU, with MY shell, is a hundred percent compatible ! Please rest assured !
Offline DanielT
« Reply #596 on: Mon, 13 June 2016, 05:45:30 »
Ok, so it's not something rare :)) It's a frankenboard, a G81 case, a PCB from another board (maybe Dolch ?? ) and Dolch keycaps . But a not bad find :)
I think if you open it you will see that the PS/2 cable is soldered on the PCB or something like that.
Offline juahenza
« Reply #597 on: Mon, 13 June 2016, 06:05:58 »
yeah well i guess its not something rare looking at the price i paid  ;D
Offline jerue
  • (Whenever that happens :P)
« Reply #598 on: Wed, 15 June 2016, 22:10:28 »
Plans
$110 is a nice price for that...
Sometimes MX blues can vary for whatever reason, and that board looks like it has some newer MX blues. Just swap some vintage blues in and it'll be much nicer to use :), easy to find, just need a "Dolch" G80-1813, the slider color is lighter than what's in your board right now.
Personally, I wouldn't mod it much beyond swapping in some new switches/sliders. Enjoy it for what it is!
Offline juahenza
« Reply #599 on: Wed, 15 June 2016, 23:56:24 »
Plans
Thank you for the suggestion. Had an headache by just  thinking about all the de-soldering and soldering. I still havent make up my mind now between getting the TX1800 and salvage the caps from this g80 or keep it and just do as what you suggest changing the switches. I really like the design of g80 case dou, but it just feels too hollow. I just cant make up my mind right now.
