Author Topic: Post your Korean Keyboard ^_^  (Read 13761563 times)
0 Members and 22 Guests are viewing this topic.
Re: Post your Korean Keyboard ^_^
« Reply #300 on: Sat, 10 November 2012, 11:35:38 »
Is that a centered stem caps lock?
« Reply #301 on: Sat, 10 November 2012, 11:36:06 »
Mmmmm... full metal jacket  ;D
Offline TheProfosist
  • Custom Layouts Only!
« Reply #302 on: Sat, 10 November 2012, 11:40:58 »
Maybe...
and lol its a set from a Filco...
« Reply #303 on: Sat, 10 November 2012, 11:43:09 »
But the board has stepped capslock right?
Offline MMB
« Reply #304 on: Sat, 10 November 2012, 11:46:50 »
the PCB supports centered, or off-center placement for capslock.
« Reply #305 on: Sat, 10 November 2012, 11:48:52 »
Yea I know how these work
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
« Reply #306 on: Sat, 10 November 2012, 11:50:42 »
I built this today MYSELF!  Thanks to mistakemistake for all the tips, video walkthrough and soldering station :)  Also, LEDs aren't installed yet...waiting on my shipment from China
(My color balance is way off, so don't mind the purple tint)
Full album including progress:  http://imgur.com/a/9jVqv
« Reply #307 on: Sat, 10 November 2012, 11:51:59 »
The plate and PCB have the option but its centered because thats what the zinc keycaps are... i can always switch it for iget a keycaps set that needs it though with my numpad layout not many key would match the layout
« Reply #308 on: Sat, 10 November 2012, 11:53:03 »
Nice KPAD wouldnt mind one that matched my KMAC but for now my numpad it built into the KMAC
« Reply #309 on: Sat, 10 November 2012, 12:21:03 »
Yeah I know it can go center or off center.
So you plan on keeping it centered for the time being.
I must say, first kmac I've seen with center caps and winkey
Offline WRXChris
« Reply #310 on: Sat, 10 November 2012, 12:30:27 »
GJ Dan!  Glad to see you're becoming more confident with legos for adults! ;P
« Reply #311 on: Sat, 10 November 2012, 12:31:32 »
yep its going to stay where it is for now
yea, im first at something! O and I couldnt do without the win key in windows too useful.
Offline jil_jil32
  • Tokyo Press <3
« Reply #312 on: Sat, 10 November 2012, 12:34:24 »
Offline DanGWanG
  • Higher Standards
« Reply #313 on: Sat, 10 November 2012, 12:44:04 »
How many KMACs you got jil?!
Offline sherryton
  • Kībōdo
    • Originative
« Reply #314 on: Sat, 10 November 2012, 13:13:56 »
Nice keypad!  I built one for my friend too.  It matches the Macbook pro, so he loves it.  He said he couldn't stop touching it.  All the newer Korean PCB's will be a lot easier because of the already soldered on SMD Diodes!  The KMAC Pad was too easy.
Offline sherryton
  • Kībōdo
    • Originative
« Reply #315 on: Sat, 10 November 2012, 13:16:11 »
Did you choose center because you forgot, don't have a stepped caps lock, or you prefer center?
« Reply #316 on: Sat, 10 November 2012, 13:25:03 »
nope didnt forget, I have one or two but zinc keycaps are going on this things as soon as I get them, I    prefer center only for the fact that i use caps as ctrl.
« Reply #317 on: Sat, 10 November 2012, 13:25:29 »
In that configuration it can use all the standard keysets.  If i had a winkey version I would want it that way too!
Offline sherryton
  • Kībōdo
    • Originative
« Reply #318 on: Sat, 10 November 2012, 13:35:05 »
what if a keyset included both stepped caps lock with window keys
« Reply #319 on: Sat, 10 November 2012, 13:39:49 »
you just desolder the capslock and move it?
Offline DanGWanG
  • Higher Standards
« Reply #320 on: Sat, 10 November 2012, 14:02:32 »
Kpad update with keycaps and color corrected photo
Offline phetto
  • HHKB JP
« Reply #321 on: Sat, 10 November 2012, 14:16:05 »
^ Nice! What is that CC? :O
« Reply #322 on: Sat, 10 November 2012, 14:42:22 »
I believe that's a Mr. Friday
Offline DanGWanG
  • Higher Standards
« Reply #323 on: Sat, 10 November 2012, 15:18:24 »
^Correct!
Offline sth
  • 2 girls 1 cuprubber
« Reply #324 on: Sat, 10 November 2012, 15:53:10 »
I have a set of F1-F10 with profile A to E, and they are still missing a KMAC mini to be placed on.  ;-(
i'll have those :P
dan nice to see you got a dolch moogle shift, looking good :)
Offline jcrouse
« Reply #325 on: Sat, 10 November 2012, 17:45:58 »
My first build. Got everything right except for one diode backwards.  ;D
Ergo Clears, stickered and lubed and waiting for a nice set of Sanctuary caps.
This ones for you boost !
« Last Edit: Sat, 10 November 2012, 17:47:52 by jcrouse »
« Reply #326 on: Sat, 10 November 2012, 18:04:52 »
Looking good!
Offline phetto
  • HHKB JP
« Reply #327 on: Sat, 10 November 2012, 19:07:09 »
Nice board, John
« Last Edit: Sat, 10 November 2012, 19:09:20 by phetto »
Offline jcrouse
« Reply #328 on: Sat, 10 November 2012, 19:10:49 »
« Reply #329 on: Sat, 10 November 2012, 19:20:31 »
Another board ruined with that badge
Offline MMB
« Reply #330 on: Sat, 10 November 2012, 19:24:08 »
Going to double-post this, because I know how much demik loves that.
Offline DanGWanG
  • Higher Standards
« Reply #331 on: Sat, 10 November 2012, 19:26:07 »
nice brah
Offline jcrouse
« Reply #332 on: Sat, 10 November 2012, 19:28:47 »
Agreed. I don't like minis much, even though I own two, but that one is extremely nice
Offline GMC
  • Shiny.
Re: Re: Post your Korean Keyboard ^_^
« Reply #333 on: Sun, 11 November 2012, 07:25:46 »
absyrd will like these pics ^_^
Loving this layout.
Presume programmable, so the right hand column can be to preference? Is there a fn layer option?
How much do these go for?
WASD V1 - waiting on R4... - MX Brown
KBT Pure - Zinc caps - MX Brown
Cherry G80-1800 ISO WKL - SkiData caps - MX Clear
Offline alaricljs
  • I be WOT'ing all day...
« Reply #334 on: Sun, 11 November 2012, 11:39:05 »
That is a KMAC mini, or KMini....   There are 2 layers and 12 Macros possible, layout is 100% programmable.
Filco w/ Imsto thick PBT
Offline GMC
  • Shiny.
« Reply #335 on: Sun, 11 November 2012, 12:08:23 »
I may need one of them...  ;D  what sort of price bracket are they in (assuming I could find someone to assist in obtaining from Korea)
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #336 on: Sun, 11 November 2012, 12:17:32 »
If I'm remembering right, the last one I saw for sale was like $350 - 400
Offline GMC
  • Shiny.
« Reply #337 on: Sun, 11 November 2012, 13:40:59 »
Hmm. Needs some thinking about with Xmas round the corner...
Offline chaosstep
  • From Hell
« Reply #338 on: Sun, 11 November 2012, 20:32:28 »
Really nice, John
Offline noxwood
« Reply #339 on: Sun, 11 November 2012, 20:40:05 »
That KMini layout is gorgeous. All the functionality of a TKL, but a little bit larger than a poker.
Offline sth
« Reply #340 on: Sun, 11 November 2012, 20:40:48 »
you realize a poker has all the functionality of a tkl as well?
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #341 on: Sun, 11 November 2012, 20:42:06 »
Damnnn. Looks sweet. Mad jelly :))
That's a MX mini.
Yep. LZ-mini
« Last Edit: Sun, 11 November 2012, 20:43:55 by boost »
-Enzo Ferrari
Offline alaricljs
« Reply #342 on: Mon, 12 November 2012, 00:08:38 »
Ok... take it here:  http://geekhack.org/index.php?topic=37318.0
edit:  The above linked thread is derailment containing no pics of boards...
move along  :)
« Last Edit: Mon, 12 November 2012, 00:26:53 by alaricljs »
Offline MMB
« Reply #343 on: Mon, 12 November 2012, 00:56:30 »
That makes no sense. What in any of my posts required moving them to a 'complaint' thread?
It was on-topic.
Offline akuJIWA
  • Lock 'N Load!
« Reply #344 on: Mon, 12 November 2012, 03:44:05 »
I need to get meself a korean board!
The Cheat - B/R/B ; Clear switch with 62g springs
quit
Offline whiskerBox
« Reply #345 on: Mon, 12 November 2012, 12:11:56 »
I wish the KMAC mini had all the macros on the right side it seems weird to me that they are on the left, but I guess it makes sense if your are using a mouse with your right hand..... (slaps head!)
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline ekw808
  • Ekw
« Reply #346 on: Mon, 12 November 2012, 12:22:53 »
It's also weird that the f keys were originally map left to right instead of up and down.
[One Keyboard at a time]
Offline jcrouse
« Reply #347 on: Mon, 12 November 2012, 12:24:27 »
I can accept that part since they normally go left to right but my first thought was exactly what whiskerbox said.
John
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #348 on: Mon, 12 November 2012, 12:32:27 »
John
You can add a kpad to the right and reprogram that :)
-Enzo Ferrari
Offline AKIMbO
  • HHKBro
« Reply #349 on: Wed, 14 November 2012, 20:24:19 »
Is there a reason people only put LEDs under the WASD and function rows?  I'm curious because I'm looking into putting LEDs under every key in the number row...from tilde to pg up.
| KBD75 (box reds)
