Author Topic: Made a Cherry MX numpad  (Read 23670 times)
Offline Tuomas
« on: Mon, 24 September 2012, 16:48:32 »
Hey guys.
I lurk alot here, but haven't really had anything worth posting so far. Until now that is.
Short version:
check what I just made!
Long version:
I bought my first mechanical KB almost a year ago, a Filco Ninja Majestouch 2 Tenkeyless (Brown switches), and I pretty much fell in love with it immediately when I got it. I bought the tenkeyless version because I like to have the numpad on the left side (I'm left handed), a regular numpad is useless. Now, I could have just bought the Filco tenkeypad, but that's not how I roll. I'm very much into electronics and DIY, so I figured it would be a worthy goal to build my own.
I bought a relatively cheap Cherry keyboard (blue switches) from someone around here a couple of months after getting my Filco, for the purposes of disassembling it. I started dismantling it quite soon after getting it, but before I got very far, I put the project on hold for some reason. After more than 6 months, last week I finally got around to actually going forward with the project.
I looked at the original Cherry keyboard for the numpad layout and designed my own board (using KiCAD). I used a USB-capable Atmel AVR as the microcontroller (at90usb162) and I got the initial design finished the same day. I'm currently studying at a University where I've got access to a circuit mill, so I used it to mill the board the next day, then soldered and programmed it. Code was the easy part, LUFA usb library for AVRs is such an easy thing to use.
I've now used it for over a week and it works very nicely.
More info on my website: http://tuomasnylund.fi/drupal6/content/usb-cherry-mx-numpad
All the code and pcb designs are on my github: https://github.com/tuomasnylund
Now, it's not over yet!
I started improving the PCB design abit after some time of using the numpad.
 - Rounded the PCB corners
 - Moved the switches abit more up, to move them closer to the center of board
 - Slightly wider, now evenly sized at 100mm*80mm
 - Hid the programming header under the PCB
 - Made provisions for the numlock being lit by LED underneath (if I get one of those fancy keycaps with a window in them)
I'll probably not mill the new version, but get it made in China with soldermask and silkscreen. I'm also looking at maybe getting some acrylic lasercut for a case of some sort, but we'll see about that. I'm thinking of ordering something in the following weeks. Or maybe I'll just leave the project alone for 6 months again. You never know.
In any case, comments, questions, suggestions, anything like that, are always welcome.
I'll also try to post updates to this topic if I get further with this whole thing.
Offline The_Beast
  • I like wood ಠ_๏
Re: Made a Cherry MX numpad
« Reply #1 on: Mon, 24 September 2012, 16:50:43 »
WOW super nice :D
Do you know how much the total cost of the project was? Why didn't you just buy a number pad (unless you like DIY :D)?
Offline sth
  • 2 girls 1 cuprubber
« Reply #2 on: Mon, 24 September 2012, 16:52:59 »
this is great! i want to make one :) any chance you would consider making more of the PCBs and selling a kit? i dont have access to the equipment.
« Last Edit: Mon, 24 September 2012, 16:54:30 by sth »
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #3 on: Mon, 24 September 2012, 16:56:38 »
Welcome to GH sir.  Epic first post. ;D
Where can I get that sweet looking Jupiter wallpaper you have?
Offline alaricljs
  • I be WOT'ing all day...
Filco w/ Imsto thick PBT
Offline Tuomas
« Reply #5 on: Mon, 24 September 2012, 18:32:37 »
Thanks for the kind words everyone!
The main cost was the original keybord I dismantled for the switches and can't remember how much I paid for it. 30eur maybe? PCB was essentially free and the other components I had already (component value ~6eur).
I like DIY :D. No other reason really.
I've considered that. I have to order multiple PCBs from China if I want one for myself anyways. I could easily sell a couple of PCBs with surface mount components already soldered and programmed. You'd just have to get switches and keycaps yourself and solder those (maybe an LED too) to get a working numpad.
A kit with keycaps, switches and maybe some lasercut acrylic included might require a bit more effort than I'm willing to put into this right now. I'll order a couple of PCBs first, maybe some lasercutting aswell. I might revisit a more ambitious kit after that, if there is interest.
At a guess:  http://www.wallpapervortex.com/wallpaper-16902_planet_jupiter_jupiters_great_red_spo.html
Pretty much right. It's a mosaic of pictures of Jupiter taken by Voyager 1 back in 1979. Not sure if I cropped the original mosaic myself, or just downloaded a readymade crop.
Offline SmallFry
« Reply #7 on: Mon, 24 September 2012, 21:23:50 »
Cool stuff! Did you write all the code yourself or did you modify some code that was already out there?
Also, you may want to add some rubber feet and/or add some weight to it to help if it slides around.
« Last Edit: Mon, 24 September 2012, 21:25:26 by SmallFry »
Offline TheProfosist
  • Custom Layouts Only!
« Reply #8 on: Mon, 24 September 2012, 22:56:41 »
Want one but you think you could change up the layout a bit? I think i have some ideas.
Offline sth
« Reply #9 on: Mon, 24 September 2012, 23:00:53 »
ah but of course - i was speaking mainly of the PCB. i would not need a kit or anything like that, just the board with holes and traces. it WOULD be really cool if it ran off the Teensy which is a very popular uc platform in the KB community.
« Reply #10 on: Mon, 24 September 2012, 23:06:37 »
Yep ive actually been thinking about a teensy run numpad for a while now but havnt put any real time into the thought.
Offline jeroplane
« Reply #11 on: Tue, 25 September 2012, 03:12:25 »
This looks really nice! Any plans for a case to put it in?
My signature hasn't changed since 2012. I should really update it.
Offline Tuomas
« Reply #12 on: Tue, 25 September 2012, 04:27:03 »
If I get the PCBs ordered, I could easily sell some bare PCBs for you if you want.
I've got some Teensy 2.0s laying somewhere, but I don't really see a point in using a whole Teensy for this thing. The cost of PCB + parts (switches not included) for my numpad is less than the price of a Teensy. Also it would take more space. The microcontroller I'm using was actually used in the original Teensy 1.0, so most code should work with a simple recompile. I should be able to get a bootloader running on this thing aswell so programming the chip should be as easy as keeping one of the keys depressed while plugging in the USB cable, then running an app on the PC to load new firmware.
Welcome to Geekhack!
Very few people who start their first post with something as awesome as this.
But ...
http://www.amazon.com/DSI-Left-Handed-Keyboard-Black-KB-DS-8861XPU-B-V2/dp/B0009S52X8
http://www.dsi-keyboards.com/dsi-black-usb-left-handed-keyboard-kb-8861xpu-b-v2.aspx
http://www.ergogeek.com/left-handed-cherry-mx-blue-mechanical-keyboard-usb--ps-2-black.html
Thanks. I know about keyboards like that, but they wouldn't have given me an excuse to build my own numpad ;). Doing things the easy way is boring.
Maybe. What did you have in mind?
Code is based on the LUFA USB library Keyboard example code. I've used LUFA for more complex stuff than keyboards before, so this was easy.
Case is in consideriation. I was thinking of sandwiching the next version PCB between a couple of pieces of lasercut acrylic. No idea how that will go.
Offline xavierblak
« Reply #13 on: Tue, 25 September 2012, 13:37:43 »
Very nice. I was considering a project like this recently. Props to you for completing it!
Do you notice any flex with just using the pcb like that with no case? Or is the pcb small enough that it doesn't matter much?
Offline nullstring
« Reply #14 on: Tue, 25 September 2012, 23:18:59 »
I really like the look of this. I wonder if we can make a whole keyboard like this. Who needs a case!
« Last Edit: Tue, 25 September 2012, 23:42:47 by nullstring »
« Reply #15 on: Wed, 26 September 2012, 00:02:24 »
Ill post some layout ideas soon but my thinking was something close to the realforce numpad but with 2 additional keys to the left one being space the other shift because i planned to use numrow numbers instead of numpad ones to that you also have access to the symbols
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #16 on: Wed, 26 September 2012, 00:07:59 »
I would love a numpad like this, all the commercial MX ones are too large and have extra row of keys on the top. It would be really amazing in the same style of case as Poker in my opinion.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #17 on: Wed, 26 September 2012, 00:09:28 »
Plus most of them have the 0 and 00 keys instead of just the big 0 key. I'd much rather have the singe 0 key like this pad has.
Plus it looks DIY and cool ^___^
« Reply #18 on: Wed, 26 September 2012, 12:03:05 »
Yes that is another good point, much easier with 2units 0. It's pretty hard to find the 00 Cherry doubleshots, only on a couple models.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #19 on: Wed, 26 September 2012, 12:04:54 »
I just plain don't like the 0 and 00 key. I find imputing numbers easier with the single 0 key
Plus that's what I've always used so I'm used to it
« Reply #20 on: Wed, 26 September 2012, 16:56:54 »
I was thinking something in the realm of
but better thought out
Offline neeb
« Reply #21 on: Wed, 26 September 2012, 17:58:13 »
Wow that's beautiful man. I really wish I had the ability to do things like that lol. I need to start dabbling in DIY stuff more, seems much more rewarding
Offline thp777
« Reply #22 on: Wed, 26 September 2012, 20:20:53 »
nice job. im thinking of doing this and using my extra nostromo board for it
Offline Squiddy
« Reply #23 on: Mon, 01 October 2012, 17:09:44 »
Make a Kit just needing keycaps, keyswitches and maybe an LED and you've got yourself a buyer right here! :D
« Reply #24 on: Mon, 01 October 2012, 17:18:44 »
I'd be +1 for a kit, I have some extra switches laying around.
« Reply #25 on: Sun, 04 November 2012, 01:46:32 »
Would you be willing to design one to my specs?
« Reply #26 on: Sun, 04 November 2012, 02:22:03 »
Oh :/ right, this never happened yet :s
I still need an MX pad.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #27 on: Sun, 04 November 2012, 09:17:01 »
dis
