Author Topic: Keychain Question  (Read 2482 times)
Offline SmallFry
Keychain Question
« on: Sat, 29 September 2012, 17:04:50 »
I ordered a keychain from Feng earlier today, and I wanted to add it to my keys... Has anyone ever had any problem with the cap falling off? I don't want to lose a CC over having a bad-*** keychain.
Re: Keychain Question
« Reply #1 on: Sat, 29 September 2012, 17:20:38 »
I have the ducky one, it's as tight as it is on your board. Some caps are actually a PITA to pull off
« Reply #2 on: Sat, 29 September 2012, 17:21:45 »
I have quite a few ducky keychains. The stems are never loose. But I have had a few issues with the switches themselves not being tightly fit. When I go to pull a cap they pop out. This can be solved with some glue if you never plan on changing the switch.
« Reply #3 on: Sat, 29 September 2012, 17:50:43 »
That's odd, my ducky one never does that even when the fit is super tight.
Offline Appeac
« Reply #4 on: Sat, 29 September 2012, 18:08:31 »
I have lost one keycap this way, although it was only a blank one. I'd recommend glue.
FC660C
122 Terminal M w/ Soarer board
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #5 on: Sat, 29 September 2012, 18:12:20 »
You can swap the stem out with a tighter fitting stem :)
-Enzo Ferrari
« Reply #6 on: Sun, 30 September 2012, 02:42:02 »
The non-ducky ones I have have clips in the casing that a cherry switch slots into, so it's pretty secure. Just make sure it's seated right.
Offline WhiteFireDragon
    • youtube
« Reply #7 on: Sun, 30 September 2012, 02:44:51 »
SmallFry, a CC on your keychain and pocket? This is the one type of key I would want to keep in perfectly mint condition, and that will be impossible when it rubs on other keys or in your pocket. Of course if you don't care about this, then that doesn't matter.
« Reply #8 on: Sun, 30 September 2012, 05:28:21 »
Both mine feel fairly secure, but I wouldn't trust them in my pocket.  Apart from the potential for the key cap to fall off, they might also get scratched by my (metal door-locking) keys.
« Reply #9 on: Sun, 30 September 2012, 11:53:25 »
I carry my keychain around (separate from my keys) in my pocket every day, almost everywhere I go. Click Clack hasn't fallen off, although it's gotten a bit dirty. Currently carrying Dan's 420 cap around. As I've mentioned, I have not experienced the cap falling off.
Offline SmallFry
« Reply #10 on: Sun, 30 September 2012, 15:28:24 »
Ok, so maybe my CC won't make the voyage... In which case I now need a cool cap to put on my keychain. Off to Techkeys to see if there's anything that I'd like on my keychain.
Offline theOwlol
« Reply #11 on: Sun, 30 September 2012, 17:49:15 »
An plain and 'boring' (black) Escape key on mine, stuck to my phone. :)
