Author Topic: MiMiC Cables - Custom Sleeved Cables  (Read 869708 times)
Offline mistakemistake
  • Global Loveinator
Re: MiMiC Cables **Custom Sleeved Cables** 2 Piece has arrived!
« Reply #400 on: Mon, 22 October 2012, 21:46:28 »
Your cables are looking awesome!
Friendly suggestion: the OP is really long and hard to scroll through.  It would be much easier to browse if you gave your images smaller, fixed heights.  For example:
Code: [Select]
[img height=200]http://i.imgur.com/P9HmM.jpg[/img]
This will give you room to stack them next to each other horizontally as well.  The following bbcode yields the images below.
Code: [Select]
[img height=100]http://i.imgur.com/GNQky.jpg[/img]  [img height=100]http://i.imgur.com/8jlzh.jpg[/img]
[img height=100][img height=100]http://i.imgur.com/XPk0C.jpg[/img]  [img height=100]http://i.imgur.com/WYAeN.jpg[/img]
Ok! Hope that looks better. That's for the input :)
  • Global Loveinator
« Reply #401 on: Mon, 22 October 2012, 21:49:59 »
asked about it the one in the beginning post isnt a generic connector but a very good connector once he finished my two for my phantoms ill do a review
I didn't mean generic in a bad way. I'm sure the quality is fine. I just meant that it's not a standard USB connector.
I like removable cables on my keyboards and if the two mating connectors were USB then this would essentially be an easy way to convert a Filco into removable cable board.
I dont think a sturdy mini b female connector is available is the problem but ill let mistakemistake weigh in on this
What profosist said about the female mini b connector is correct. I've seen a DIY with hot glue which seems like it works, but personally I wouldn't really want hot glue on the inside of the keyboard casing. Even though it's on the inside, I feel like it loses its 'clean' factor. That's just me though.
I'll try and think of a solution for what you're looking for xavierblak.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #402 on: Mon, 22 October 2012, 21:50:30 »
i think it looks much better much easier to find what you need and follow.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #403 on: Mon, 22 October 2012, 22:13:35 »
SDL to USB cable! Enjoy :)
**** son, I need one of those. Would it be cheaper if I send to the cable I have to sleeve
  • Global Loveinator
« Reply #404 on: Mon, 22 October 2012, 22:57:52 »
Premium Silver Silica going into a filco
  • Global Loveinator
« Reply #405 on: Mon, 22 October 2012, 22:58:27 »
It will depend on the cable, can you take a picture of it and PM it to me?
« Reply #406 on: Mon, 22 October 2012, 23:06:51 »
MINE!!!
Re: Re: MiMiC Cables **Custom Sleeved Cables** 2 Piece has arrived!
« Reply #407 on: Mon, 22 October 2012, 23:10:24 »
MINE!!!
looking good. So what are you going to do solder it directly on?
« Reply #408 on: Mon, 22 October 2012, 23:33:42 »
Yep! Only issue will be fitting it into the case. 2 piece connectors are just a little bit too pricey at the moment
« Reply #409 on: Mon, 22 October 2012, 23:38:56 »
make a grommet out of 2 orings and some heat shrink.
Offline xavierblak
« Reply #410 on: Tue, 23 October 2012, 11:07:57 »
I think we might be thinking of two different things here. I'm not talking about the filco mods where they add a usb connector flush to the back of the case.
I'm interested in a cable similar to this one.
But instead of the connector used in the photo it would be a usb connector. This would give the filco a short female mini b connector tail.
  • Global Loveinator
« Reply #411 on: Tue, 23 October 2012, 12:54:49 »
Ah, I see. Yeah I can definitely do that.
« Reply #412 on: Tue, 23 October 2012, 13:45:24 »
can you get the actual part that plug into a Filco i would be up for 3 2 piece cables probably if you could make it so I can just unplug the Filco cable and plug your 2 piece in.
  • Global Loveinator
« Reply #413 on: Tue, 23 October 2012, 16:08:52 »
part of a two piece cable :)
« Reply #414 on: Tue, 23 October 2012, 18:03:50 »
Dude that thing looks indestructable.
« Reply #415 on: Tue, 23 October 2012, 20:23:31 »
That looks BEAST!
(sorry The_Beast)
Offline chrono000
« Reply #416 on: Wed, 24 October 2012, 06:45:35 »
Get mine done and post it dude!
Offline SmallFry
« Reply #417 on: Wed, 24 October 2012, 07:05:08 »
Would you do custom cables? Just curious. Either way I'm waiting for the DIY package for the sleeving materials so I don't have to buy a ton of it.
  • Global Loveinator
« Reply #418 on: Wed, 24 October 2012, 13:45:41 »
Trying to get things in stock for DIY kits. Please post sleeve/heat shrink  types you are interested in. No commitment required, I'm just looking to see what people are interested in. I'll try and put together a form tonight.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #419 on: Wed, 24 October 2012, 14:17:57 »
Any news on the SDL cable?
Offline justin one
« Reply #420 on: Wed, 24 October 2012, 16:24:34 »
I would be most interested in tight weave fabric and white heat shrink.
[ KBC Poker ] [ Ducky DK9087 ]
Offline SmallFry
« Reply #421 on: Wed, 24 October 2012, 17:51:33 »
Sorry, "custom cables" was a bit vague. Would you do other cables that are not the USB cables, such as a headphone cable etc. I think that 3/8ths is to big for me to sleeve the tiny headphone cable that I have. The stainless steel/dark stainless steel/red sleeves looked the most interesting to me, but like I said... 3/8ths seems too large.
  • Global Loveinator
« Reply #422 on: Wed, 24 October 2012, 17:59:24 »
Sure, I can use your existing cable and add on new connector ends or make the cable from scratch (assuming its something detachable)
  • Global Loveinator
« Reply #423 on: Wed, 24 October 2012, 18:04:10 »
Oh as for heatshrink I can get much smaller stuff. I was saying 3/8 is the smallest I use for the cables I make
  • Global Loveinator
« Reply #424 on: Thu, 25 October 2012, 00:30:56 »
For TheProfosist: your beast of cables.
  • Global Loveinator
« Reply #425 on: Thu, 25 October 2012, 01:33:21 »
And, another: Hip Hop
Offline Sinzz
« Reply #426 on: Thu, 25 October 2012, 02:19:51 »
 :D Can't wait until I receive mine!
Keycool 84 MX Blue | Pure Pro | HHKB Pro 2
  • Global Loveinator
Re: MiMiC Cables **Custom Sleeved Cables** DIY Order Form has arrived!
« Reply #427 on: Thu, 25 October 2012, 02:55:18 »
DIY order form is live, check out OP!
« Last Edit: Thu, 25 October 2012, 02:59:35 by mistakemistake »
« Reply #428 on: Thu, 25 October 2012, 14:20:55 »
Thank You <3, These are so over kill!!! BEAST Cables for the WIN!
  • Global Loveinator
« Reply #429 on: Sat, 27 October 2012, 13:01:28 »
^No Problem at all :)
  • Global Loveinator
« Reply #430 on: Sun, 28 October 2012, 17:48:38 »
another two piece?
« Reply #431 on: Sun, 28 October 2012, 22:48:10 »
Oooo that looks good man!
Offline justin one
« Reply #432 on: Sun, 28 October 2012, 22:53:15 »
Great job on this DIY order form, I'll be getting some.
Offline Sinzz
« Reply #433 on: Sun, 28 October 2012, 23:40:30 »
Received my cable and it looks amazing! one thing that I would say is slightly dissappointing is that the orange isnt really an orange, its more of a pale orange/peach color. Perhaps I should've gone with the Yellow. But the Hip Hop color sure stands out and I'm loving it! Will probably order another, more subtle one for work someday in the future. :p
  • Global Loveinator
« Reply #434 on: Sun, 28 October 2012, 23:43:26 »
^aw I'm sorry to hear about the heat shrink color. I can send some yellow out for you if you'd like :)
Offline Sinzz
« Reply #435 on: Sun, 28 October 2012, 23:53:17 »
it's okay, would hate for you to lose money that way. Great customer support though ;D!
  • Global Loveinator
« Reply #436 on: Sun, 28 October 2012, 23:55:51 »
It's no trouble at all, I'll just throw it in a bubble mailer and ship some out tomorrow.
Offline Sinzz
« Reply #437 on: Mon, 29 October 2012, 00:04:23 »
Really?! well thanks and sorry for all the trouble!
  • Global Loveinator
« Reply #438 on: Mon, 29 October 2012, 00:05:49 »
No worries! I want you guys to be happy with your cables :)
« Reply #439 on: Tue, 30 October 2012, 02:04:33 »
Im got pics of mine in action ill try to get then up tomorrow.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #440 on: Wed, 31 October 2012, 04:31:11 »
Mine just got delivered today.  In short I got the biggest grin on my face.  Nothing better than getting a cable that is better made than most stuff coming out of China these days.  The Stainless glistens in the sunlight like a Jewel, all I want to do is place it on the desk still curled up and ogle at it's perfection.
You have indeed made an old man extremely happy with his purchase, nice to deal with someone who really cares about his craft and sharing it amongst us heathens.
  • Global Loveinator
« Reply #441 on: Wed, 31 October 2012, 09:43:40 »
Aw, thanks so much for your kind words! I really appreciate it and glad you're happy with your cable! Enjoy :)
« Reply #442 on: Wed, 31 October 2012, 21:18:02 »
Here are the pics i finally took of the cables that I got:
« Reply #443 on: Wed, 31 October 2012, 21:21:51 »
Those things look like they'd survive a nuke.
« Reply #444 on: Wed, 31 October 2012, 21:24:15 »
and they had better at the price they cost ;) i kinda wish I had a proper case to match though...
« Reply #445 on: Wed, 31 October 2012, 21:32:03 »
don't you have that mkc neon yellow one?
« Reply #446 on: Wed, 31 October 2012, 21:33:22 »
that was actually for a friend and it would have to be pretty heavily modified for my 7bit layout and i think id like to stick with white, if it was acrylic maybe the middle layer could be yellow...
Offline Elrick
  • Hype Master
« Reply #447 on: Thu, 01 November 2012, 00:17:57 »
Mistakemistake, couldn't resist.....just put in another Cable Order.  I need a two piece Cable setup for a Filco, let me know if it's possible.
Re: Re: MiMiC Cables **Custom Sleeved Cables** DIY Order Form has arrived!
« Reply #448 on: Thu, 01 November 2012, 01:23:41 »
i believe he is getting the filco connectors on friday dont quote me on this though.
Offline jeroplane
« Reply #449 on: Thu, 01 November 2012, 01:45:19 »
Oh really? If that is the case, I might cave and get one...
My signature hasn't changed since 2012. I should really update it.
