Author Topic: Diamond Key cap for proposal  (Read 4132 times)
Offline Orphagn
« on: Thu, 11 October 2012, 10:18:53 »
So i'm looking to propose to my girlfriend on the 21st of October on our anniversary and I'm going to make a custom makeshift ring that has a Cherry MX switch. Does anybody know if there's a clear diamond piece that will fit an MX switch or a keycap with a diamond on it?
I'm not trying to be cheap, i'm still willing to buy her a ring later on that she can pick out herself, but I want to craft something for her since she's always making small crafts for me.
Any help here would be greatly appreciated.
Thanks in advance!
Keyboards:
KBC Poker
Cherry G80-11900
Cherry G80-3494
Offline SmallFry
Re: Diamond Key cap for proposal
« Reply #1 on: Thu, 11 October 2012, 10:28:39 »
Moonprismpwr incoming! Hopefully she and Kellybear can help you.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #2 on: Thu, 11 October 2012, 10:37:48 »
Great idea! I did something similar when I proposed. Bought the most giant fake plastic POS ring and tied it to the end of her fishing line (fishing is her fav thing to do in the world) while she was off hiking up stream to find a diff spot. She came back, reeled her line in, and boom! There it was.
It is also much nicer to go pick out the real ring WITH your loved one. It was a nice experience to go through the process with my wife and get her EXACTLY what she wanted.
Best of luck!
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #3 on: Thu, 11 October 2012, 10:39:40 »
A dyesub by imsto or qtan is probably the way to go.
I'm sure Moonprismpwr can do some kickass artwork for it.
« Reply #4 on: Thu, 11 October 2012, 11:03:19 »
Also QWERkeys does custom designs.
I'd like to offer some advice.  If at all possible, have the ring for the proposal.  Girls have been programmed their whole lives by bad movies, and they want that f***ing rock.
  • techkeys.us
    • TechKeys
« Reply #5 on: Thu, 11 October 2012, 11:04:37 »
I would have to agree with metalliqaz, even if its just a band with a fake rock.
Offline Orphagn
« Reply #6 on: Thu, 11 October 2012, 18:29:16 »
Thanks for the input guys. My girlfriend isn't the girly girl type (but she has her moments) and I totally understand the "need a rock" mentality. I'll have to look at the local jewelry stores to see if I can find a ring with a rock I can afford at the moment.
As for the Cherry MX ring, if it comes down to it I'll have to find some clear substance that I can shape into a diamond or use a mold.
Keyboards:
KBC Poker
Cherry G80-11900
Cherry G80-3494
« Reply #7 on: Thu, 11 October 2012, 18:34:16 »
Maybe one of our 3d keycap specialists can help you make a diamond :D That's a really awesome idea though
Offline moonprismpwr
  • pew pew
« Reply #8 on: Thu, 11 October 2012, 18:47:18 »
Thats pretty cute. If I may, I dont think you need to worry about "having to have a rock". I think she's going to be over the moon about marrying you, diamond or not. When I got married, we both got plain gold bands with an engraving and I was happy with that. Our jeweler told us though that some girls go in there and they're a nightmare, practically asking for your entire life savings. Your girlfriend sounds sweet and down to earth though, so I think shes really going to find it cute what you're doing. And ofc later you can have her pick out the 'serious' ring, but I dont think shes going to be pissed if its not there during the proposal.
I'm not sure what substance you'd use to shape the diamond, but I would suggest checking etsy for candy molds that are gem-shaped. These are usually made from silicon and come with a lot of different 'cuts' and sizes.
Offline SmallFry
« Reply #9 on: Thu, 11 October 2012, 18:50:15 »
Speaking of candy...trying a ring pop might be good too, just make sure its one piece before proposing
Offline jeroplane
« Reply #10 on: Thu, 11 October 2012, 21:01:37 »
You could go out and buy a cheap piece of jewelry with a large piece of Cubic Zirconium (i.e. "fake" diamond), and try to embed that into a keycap. One option may be to spray a keycap in silver or gold auto paint and then find a way to perhaps inlay the CZ into the centre of the cap. Not sure if that fits the bill, but it's an idea.
An example of the kind of sizes of CZ you can find is this listing on eBay.
« Last Edit: Thu, 11 October 2012, 21:05:59 by jeroplane »
My signature hasn't changed since 2012. I should really update it.
Offline Orphagn
« Reply #11 on: Thu, 11 October 2012, 21:25:46 »
@Moonprismpwr: Great idea on the candy mold for a diamond! And thanks for the input as well!
@SmallFry: A ring pop is a good idea, but it might be a too big lol I kinda want something she can use everyday.
@Jeroplane: That's an awesome idea, I just ordered two 7mm diamonds to try to work with.
Once I get this finished i'll post up pictures.
Keyboards:
KBC Poker
Cherry G80-11900
Cherry G80-3494
Offline SmallFry
« Reply #12 on: Fri, 12 October 2012, 09:59:03 »
She could use it every day...pending any pets not eating it:)
