Author Topic: Quick dye Job  (Read 7478 times)
Quick dye Job
« on: Sun, 14 October 2012, 19:46:06 »
Was at the cottage with my old Cherry with fading PBT caps, so figured I'd spruce em up a bit. Used RIT powder dye, with lotta salt. The colours were teal and rose pink.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Re: Quick dye Job
« Reply #1 on: Sun, 14 October 2012, 19:50:25 »
Nice.
Re: Quick dye Job
« Reply #2 on: Sun, 14 October 2012, 20:21:50 »
That looks good.
Re: Quick dye Job
« Reply #3 on: Sun, 14 October 2012, 20:25:54 »
I really like those colours.
Offline SmallFry
Re: Quick dye Job
« Reply #4 on: Sun, 14 October 2012, 20:46:53 »
Colors came out superb! Glad to hear more and more people are doing this!
Offline YoungMichael88
  • HHKB Wannabe
Quick dye Job
« Reply #5 on: Sun, 14 October 2012, 21:11:20 »
A few of his other caps he threw in the pot warped from the heat so be careful what you use but they turned out great
Re: Quick dye Job
« Reply #6 on: Sun, 14 October 2012, 21:12:25 »
Don't boil ABS, lesson learned...or test successful.
Offline WhiteFireDragon
    • youtube
Re: Quick dye Job
« Reply #7 on: Mon, 15 October 2012, 16:38:08 »
Wow that's actually beautiful. Colors look pretty consistent without any blotches. Can you take a clear closeup of the caps?
Re: Quick dye Job
« Reply #8 on: Mon, 15 October 2012, 16:51:31 »
+1 on consistency :)
Does this wear off over time, or does it like soak into the key caps for a permanent change?
Re: Quick dye Job
« Reply #9 on: Mon, 15 October 2012, 17:21:41 »
I can't atm, moving in a couple weeks so I have most of my stuff 8 hours away ready for moving. Sadly only have one keyboard with me. I'll try to remember to get some nice shots when I get all my stuff.
Not 100% sure, but it is definitely soaked in, so I would think permanent.
Offline TheQsanity
  • SmallFry Lovin'
Re: Quick dye Job
« Reply #10 on: Thu, 25 October 2012, 02:27:10 »
What keyswitch is on that board btw?
SmallFry! <3
Quick dye Job
« Reply #11 on: Thu, 25 October 2012, 02:28:30 »
That beauty came with clears. Got it cheap on eBay a few months back. Was going to harvest for switches, but ended up liking the board.
Offline TheQsanity
  • SmallFry Lovin'
Re: Quick dye Job
« Reply #12 on: Thu, 25 October 2012, 02:38:15 »
Yum, clears I have my eye on one atm. How much did you get them for, if I may ask?
SmallFry! <3
Quick dye Job
« Reply #13 on: Thu, 25 October 2012, 02:45:10 »
I believe I paid around $40 for the board.
Offline TheQsanity
  • SmallFry Lovin'
Re: Quick dye Job
« Reply #14 on: Thu, 25 October 2012, 02:47:58 »
Oh, nice thanks. Are all the G80 POS keyboards Cherry Clears? to be sure.
SmallFry! <3
Quick dye Job
« Reply #15 on: Thu, 25 October 2012, 02:49:59 »
I believe most are browns. Not sure on the technicals of cherry boards, not sure if there is a way to tell without looking.
That seller had pictures of the switches. If the seller doesn't know, best bet is to get them to pop a cap off.
Offline TheQsanity
  • SmallFry Lovin'
Re: Quick dye Job
« Reply #16 on: Thu, 25 October 2012, 02:53:33 »
Wait was this board a Cherry G81? G81's can have Cherry MX on them?
SmallFry! <3
Re: Quick dye Job
« Reply #17 on: Thu, 25 October 2012, 02:59:10 »
Ah nono. Just remembered, all my boards are in my signature as well. It is a Cherry MX 8100.
Offline TheQsanity
  • SmallFry Lovin'
Re: Quick dye Job
« Reply #18 on: Thu, 25 October 2012, 03:14:09 »
Interesting. It seems the G8XXX doesn't decide the switch model 81 just means POS I believe. I have seen a lot of G81's with MY switches. Trying to figure out what switch that is beneath a cap is a trickier game than I thought.
SmallFry! <3
