Author Topic: Proper PS/2 to USB conversion?  (Read 1860 times)
Offline blakespot
    • My (modest) keyboard gallery
« on: Thu, 18 October 2012, 16:02:02 »
If one grabs a Model M with a PS/2 connector for use on a USB machine, what is the proper drill there? I've got a number of tiny converter dongles lying around the house, but are they the way to go? Does it require more electronics to get it done in a way that won't show ghosting, repeats, etc?
Thanks.
bp
:: Leopold FC660C (x2), FC660M (browns), Realforce 87U, Das Keyboard (blues), Matias Tactile Pro (v1), HHKBL2, Matias Quiet Pro, Unicomp Classic 101, Focus FK-2001, Corsair Vengeance K65 (reds), Steelseries Apex 7 TKL ("browns")
:: Modest photo gallery of my keyboards
Re: Proper PS/2 to USB conversion?
« Reply #1 on: Thu, 18 October 2012, 16:20:59 »
I have never had any trouble with the cheap converters, but a lot of people here have complained about them either not working at all, or working improperly.
Just try what you have, and see. A Model M draws quite a bit of power, and you might try a powered USB hub if you have one.
Otherwise, every rig is different, and trial and error will tell you where you stand.
PS - I don't game so my needs are simple.
"A whole civilization will die tonight."
- D Trump 2026-04-07
What is wrong with this picture?
Offline 0100010
  • Not Sure
« Reply #2 on: Thu, 18 October 2012, 18:25:07 »
Probably the easiest is to get a protocol adapter, such as : http://www.clickykeyboards.com/index.cfm/fa/items.main/parentcat/11298/subcatid/0/id/124184
They come in either just the adapter or also in a short cable format.
Could also perform any number of USB conversions too - but those would be probaby more costly and require work; nothing wrong with tinkering if you're interested though...
Offline tobydeemer
« Reply #3 on: Fri, 19 October 2012, 14:37:05 »
I have had good luck with the blue cube mentioned above for my Model M's. I need to get a Belkin adapter for my WGI AT101, as it is more finicky. With cheaper adapters, I've had issues only when I try to remap keys in Linux. For instance, my cheap microcenter adapter works 98%- it loses repeate function when I map Left Ctrl to my caps lock. That's it.
However, there is also this seller on ebay, who IIRC is a member here (not sure of name), that makes custom cables for this application. They're a little more expensive than an adapter, but look far classier to be honest. (Which might not matter depending on desk setup, etc.) Anyway, here's the link:
http://www.ebay.com/itm/USB-to-SDL-6-Pin-6ft-IBM-Lexmark-Unicomp-Model-M-Clicky-Keyboard-Cable-NEW-/270955553909?pt=LH_DefaultDomain_0&hash=item3f1635a475
(Oh also, this is only for the Model M's with the removable PS/2 cable....)
// SGI AT101 // SIIG Minitouch  // 87 & 93 & Terminal 122 Model M // Poker II Brown // CMS QFS Gateron Green // Alps GlidePoint Rackmount // DataGeneral 6311 Acer // ...annnnd some other randoms... //
« Reply #4 on: Fri, 19 October 2012, 15:02:31 »
Oh, I forgot.
I have 2 of orihalcon's cables and they work great for me.
Offline hasu
  • @tmk
« Reply #5 on: Fri, 19 October 2012, 19:22:54 »
Exactly same here. Both of my two cheap converter have that problem and seem to have some trick on CapsLock.
Offline urbanus
« Reply #6 on: Sat, 20 October 2012, 01:25:37 »
Agreed -- I got a couple of those so-called "blue cube" adapters, but I got them from eBay instead because it was cheaper (sorry clickykeyboards.com dudes).
As for the keyboard mod: I wouldn't go down that path personally because I think it would affect the value of the board.  Also it would remove some of the old-style charm.  :)
Offline TheProfosist
  • Custom Layouts Only!
« Reply #7 on: Sat, 20 October 2012, 01:50:52 »
Get a belkin or rosewill ps2 kwyboard and mouse to useb the kind with the box in the middle.
