Author Topic: [SOLD] QF Rapid with reds - debadged case w/brushed aluminum look - $65  (Read 9914 times)
Offline khaangaaroo
  • Trade Count: (0)
FINAL UPDATE: Board as been sold as well.
UPDATE: Otaku keys have been sold. Now only comes with original key caps, but will include replacement win keys and space bar. All key caps are new, and unused.
I've been using this board on and off since June. I decided to go all topre and sell my cherry mx stuff, including my QF Rapid with reds. Asking $90 $65 plus actual shipping from Los Angeles. (should be $6-12 within US)
It has blank white ABS keycaps from a Leopold. The white spacebar doesn't fit, so I put in a slightly older grey spacebar with a little bit of shine. The white spacebar is included though, along with the original CM Storm keys that were taken off right when I got it.
I spent a lot of time sanding off the rubberized coating and removing the logos to give the plastic a brushed aluminum look. It's not 100% perfect like brushed aluminum out of a factory, but I'm really happy with it.
Plastic key puller, red wasd keys, ps2 adapter, usb cable, and original packaging also included.
« Last Edit: Tue, 30 October 2012, 15:30:50 by khaangaaroo »
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
  • Trade Count: (0)
Re: [FS] QF Rapid with reds - white otaku keys - debadged case - $100
« Reply #1 on: Mon, 22 October 2012, 15:34:38 »
GLWS.  I really like this stripped down minimalist look.  And I actually really like the off-color spacebar too.  It's true to the board's style while at the same time breaking it enough to avoid monotony.
Offline zzAaron
  • Trade Count: (0)
« Reply #2 on: Tue, 23 October 2012, 02:48:22 »
Where is that spacebar from?
Ducky 9008G2 Browns, White Filco TKL Reds
Offline khaangaaroo
  • Trade Count: (0)
« Reply #3 on: Tue, 23 October 2012, 10:08:42 »
wasdkeyboards i think
Offline khaangaaroo
  • Trade Count: (0)
Re: [FS] QF Rapid with reds - white otaku keys - debadged case - $90
« Reply #4 on: Wed, 24 October 2012, 10:30:07 »
bump
Offline Acetrak
  • ssk.ℜ
  • Trade Count: (0)
  • gnawm_
« Reply #5 on: Wed, 24 October 2012, 10:42:05 »
GLWS but considering the recent coupon on slick deals and your board being used...I think lowering the price will be a good idea.
Offline khaangaaroo
  • Trade Count: (0)
« Reply #6 on: Wed, 24 October 2012, 10:50:02 »
I could also sell it without the Otaku keys and include just the original keys for $65 if someone wants to do that.
Offline khaangaaroo
  • Trade Count: (0)
Re: [FS] QF Rapid with reds - debadged case w/brushed aluminum look - $65
« Reply #7 on: Wed, 24 October 2012, 15:20:47 »
Sold the white key caps. Price is now $65 plus shipping for the board with black case and original keys.
Offline danielucf
  • Horrible Mailman
  • Trade Count: (0)
  • Hmmmm beer.
« Reply #8 on: Wed, 24 October 2012, 16:32:13 »
So the surface is brushed metal looking plastic?
« Last Edit: Wed, 24 October 2012, 16:33:45 by danielucf »
Offline khaangaaroo
  • Trade Count: (0)
« Reply #9 on: Wed, 24 October 2012, 16:38:59 »
Pretty much. Maybe a little less shiny than brushed metal.
I finished it with 1000-grit sandpaper to create scratches in one direction. Not sure how else to describe it :P
Offline SurgeonKyle
  • Trade Count: (0)
  • God I love keyboards
« Reply #10 on: Wed, 24 October 2012, 22:06:48 »
I really like the look of it, and recently got a quickfire rapid of my own. Mind describing the process that went into sanding everything down?
Current Rotation: Ducky DK9087G2 PRO | Topre Realforce 87U TKL 55g | APC Branded Cherry G80
Offline jwaz
  • * based mod
  • Trade Count: (0)
  • #geekhack on freenode
« Reply #11 on: Wed, 24 October 2012, 22:10:17 »
cool keyboard, cool dude. GLWS. someone buy this!
Offline khaangaaroo
  • Trade Count: (0)
« Reply #12 on: Wed, 24 October 2012, 23:06:06 »
Sure! First you have to take the cover off. There's only one screw at the bottom, underneath the white warranty sticker. Then I used an old gift/credit card to slide under the front and rear edges to separate the cover from the base.
I think the paint job is done in three phases. Base coat (either black or gray), then logos, then clear rubberized coating on top.
I started with a pad of Scotch-Brite. I found it worked a little better than sandpaper to rub off the rubberized coating. You might want to do this outside cause rubber flakes will be floating everywhere.
Then I went with (I think) a 600-grit wet/dry sandpaper to take off the logos and base coat. I just dipped the entire cover in tub of water to keep it constantly wet.
After getting all the paint off, I started standing the plastic in one direction for all the surfaces I wanted to look brushed. I eventually moved on to finer sandpaper until the scratches looked the way I wanted.
Offline MissMurd3r84
  • Trade Count: (0)
  • In IRC wondering why Kmiller8 is yelling.
« Reply #13 on: Thu, 25 October 2012, 00:10:57 »
GLWS. If I didn't think it would cost an arm and a leg to post to me, I'd be interested.
KBC Poker - Red switches. Noppoo Choc Mini - Black switches. Leopold FC700R (White) - Blue switches. Ducky YOTD - Brown switches. Razer BW - Blue switches and rusted.
Offline SurgeonKyle
  • Trade Count: (0)
« Reply #14 on: Thu, 25 October 2012, 08:18:51 »
Looks like I'll know what to order to replicate this sweet look, any specific type of Scotch-Brite or did you just get a box of the all-purpose pads?
Offline khaangaaroo
  • Trade Count: (0)
« Reply #15 on: Thu, 25 October 2012, 10:17:11 »
Just one of those thin green all purpose pads. I'm sure other ones might work too. Good luck!
Offline ekw808
  • Trade Count: (0)
  • Ekw
« Reply #16 on: Thu, 25 October 2012, 10:53:29 »
Could you post some pics of the underside of the keyboard? That brushed aluminum looks really nice btw, good job.
[One Keyboard at a time]
Offline khaangaaroo
  • Trade Count: (0)
« Reply #17 on: Thu, 25 October 2012, 11:57:07 »
Here are some photos of the board with the original keys. I gave away the cmstorm logo windows keys. So I'm including domed winkeys from a Filco instead. Looks better than logos anyways right?
I'd say the brushed finish isn't as pronounced in person as it is in the photo of the original post. I used a really fine sandpaper, so it's pretty discreet. I just set up the lighting so it would show up well in the first photo.
« Last Edit: Thu, 25 October 2012, 11:58:39 by khaangaaroo »
Offline SurgeonKyle
  • Trade Count: (0)
Re: Re: [FS] QF Rapid with reds - debadged case w/brushed aluminum look - $65
« Reply #18 on: Thu, 25 October 2012, 12:56:44 »
Thanks for the tips, I'll probably post back tomorrow somewhere with my results since I'll be off work.
Update 10/26: Just finished it and it looks amazing, just to the let water dry and it'll be perfect. Thank you so much OP.
« Last Edit: Fri, 26 October 2012, 16:25:22 by SurgeonKyle »
Offline khaangaaroo
  • Trade Count: (0)
« Reply #19 on: Sat, 27 October 2012, 15:44:30 »
You're welcome! I'm glad it came out well.
Offline khaangaaroo
  • Trade Count: (0)
« Reply #20 on: Sun, 28 October 2012, 15:47:35 »
I hate to see "quick fire" on the space bar of this otherwise logo-less keyboard. I'm now including a brand new blank space bar that I ordered from wasdkeyboards. Someone buy my QFR!
  • Trade Count: (0)
« Reply #21 on: Sun, 28 October 2012, 23:55:11 »
Already said I might of the price wasn't as much as an arm and leg to send. :p
