Author Topic: PCB-mounted with Cherry Reds  (Read 4883 times)
Offline RSIgamer
« on: Tue, 23 October 2012, 08:46:32 »
Are there any mechanical keyboards out there that are PCB-mounted and have red cherry switches?
Or am I stuck with blacks, blues, browns?
Thanks in advance.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
Re: PCB-mounted with Cherry Reds
« Reply #1 on: Tue, 23 October 2012, 09:09:46 »
Pures are pcb mounted and come in browns, blues, blacks, and reds :) I've got one with green leds and red switches.
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Tue, 23 October 2012, 10:20:54 »
All but the Race and Pure on tha page are plate.
If you don't mind a mini board, you have Poker, Pure, Race. If you need a fullsize 104 look for Cherry G80-3494LYCUS or G80-3800 is also available with red and quite a bit cheaper but it is not as good quality.
« Last Edit: Tue, 23 October 2012, 10:22:25 by lysol »
Offline RSIgamer
« Reply #4 on: Wed, 24 October 2012, 07:17:47 »
Thanks.
Looks like my choices are very limited.
« Reply #5 on: Wed, 24 October 2012, 10:53:36 »
If you don't mind to change the stems or springs, the selection gets quite large with other models of Cherry G80 if you prefer say the 1800 for example. Making ghetto reds with blue/brown board and change the stems to those of blacks or vice versa is quite easy. This also gives you the ability to pick up a used G80 for cheap.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #6 on: Wed, 24 October 2012, 13:53:39 »
Offline squarebox
  • In Omnia Paratus
« Reply #7 on: Thu, 25 October 2012, 00:12:45 »
Dont forget about the G80-3494
And Cherry G80-1865
Filco Yellow Edition  | Filco Brown | Filco 2 Brown TKL | G80-1950 | G80-3494 | G80-11900 | Leopold FC500R | Noppoo Choc Mini
« Reply #8 on: Thu, 25 October 2012, 00:15:55 »
I didn't forget the 3494, but did forget the 1865 with reds. 1865 usually have brown, is the full model on these LYCUS for reds as well?
Offline squarebox
  • In Omnia Paratus
« Reply #9 on: Thu, 25 October 2012, 13:41:46 »
G80-1865(red) are still available at PC|Home. It states it's EU layout. Probably in english. Well, chinese layout is the same anyways, just more etching.
Offline laffindude
« Reply #10 on: Thu, 25 October 2012, 15:20:11 »
I been trying to get a 1865 in blue. I may have a source, but I need to go ask. I have too many boards already, but I want to replace my favorite board (1800 in blue, but I want it in USB ;)). If i don't find it, I may need to get that red board and mod it.
