Author Topic: When yellow is not quite yellow  (Read 22691 times)
« on: Wed, 31 October 2012, 23:51:24 »
As discussed here http://geekhack.org/index.php?topic=28039.0 the Filco yellowtop yellow is different to the WASD yellow set.
The Filco yellow (that I had on order until the supplier advised that the keyboard was no longer available) is like this:
The WASD yellow does seem more pastel:
There is an EK yellow Topre set (no good for me, I want MX) which seems closer to the Filco yellow:
And finally SP has a yellow option YY that seems somewhere in between (although the YBP next to it looks quite a bit like the sides of the Filco keys, although they are in shadow, but is probably too orange for the keycaps):
So without a direct comparison available of SP yellow keycaps with the Filco keyboard, has anyone got any ideas how to most closely match the Filco yellow without actually getting a Filco yellow keyboard?
Re: When yellow is not quite yellow
« Reply #1 on: Thu, 01 November 2012, 03:08:24 »
That picture looks to be a different shade than mine. Much brighter. Mine was a bit darker, kind of orangy.
« Last Edit: Thu, 01 November 2012, 03:11:38 by noisyturtle »
« Reply #2 on: Thu, 01 November 2012, 03:52:50 »
At a guess I'd say that was the lighting where you took the picture?  Every other picture of the yellow Filco I have seen, including reaper's in the other thread, is almost the same bright yellow.
Actually reaper's looks a bit duller too.
Anyone else got one?
Offline laffindude
« Reply #3 on: Thu, 01 November 2012, 06:13:23 »
They're called golden yellow (I have an unprinted set for my red cased Filco for ketchup and mustard/micky D look.). It is a warmer yellow than YY in the picture, but not quite as warm as YBP.
Offline squarebox
  • In Omnia Paratus
« Reply #4 on: Thu, 01 November 2012, 09:54:36 »
Problem solved...
« Last Edit: Thu, 01 November 2012, 10:07:15 by squarebox »
Filco Yellow Edition  | Filco Brown | Filco 2 Brown TKL | G80-1950 | G80-3494 | G80-11900 | Leopold FC500R | Noppoo Choc Mini
Offline Cafiend
« Reply #5 on: Thu, 01 November 2012, 12:53:14 »
I have yellow from wasd that is very pale compared to those ninja yellow wasd keys from  thekbco.
toss up between yy and ycf for my yellow set.
seems like everyone has their own idea of yellow =/
« Reply #6 on: Thu, 01 November 2012, 14:17:08 »
Problem solved...
Fantastic!  Exactly what I was looking for - thank you :)
So it seems that the Filco yellow keyboards are YCF (which no-one does a single set of at a reasonable price).
Where are the WASD with side-printed arrows from?  They look closer to YY (SP does YY), but slightly less orange.
Offline laffindude
« Reply #7 on: Thu, 01 November 2012, 14:28:27 »
They're factory Filco caps.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #8 on: Thu, 01 November 2012, 14:28:50 »
Those are Filco aftermarket caps, likely from EK.
Filco w/ Imsto thick PBT
« Reply #9 on: Thu, 01 November 2012, 15:54:12 »
EK sells a Topre set in what looks very much like the same yellow, or at least fairly close to it, which is no good as I want MX.  sigh
I really like the Filco yellow, and the WASD yellow doesn't feel the same.
Is anyone able to advise what yellow the WASD ones are?  As in what colour code please?
Offline Cafiend
« Reply #10 on: Thu, 01 November 2012, 17:55:56 »
YCE for the "wasd yellow" I think. (from wasd)
« Reply #11 on: Thu, 01 November 2012, 18:25:39 »
YCE?  About the palest yellow there is (as much as these leys are pale anyway).
I also just learned that WASD has a sampler pack, including a yellow key cap, so I have ordered one of those.  Let's find out exactly how yellow their yellow is.
Offline squarebox
  • In Omnia Paratus
« Reply #12 on: Thu, 01 November 2012, 19:40:30 »
The WASD is from Filco as an accessory. From my eyes, YY is the closest unlike the Filco Yellow with YCF which are almost a perfect match.
Perhaps I should order some keycaps from WASDkeyboards for referencing. It sucks to always have to pay a exorbitant shipping for everything.
« Last Edit: Thu, 01 November 2012, 19:44:17 by squarebox »
« Reply #13 on: Thu, 01 November 2012, 20:33:21 »
So does that mean that the keycaps on the yellow Filco keyboard are a slightly different colour to the yellow Filco WASD set?
That would kinda make sense if (a) the yellow Filco keyboard is a limited edition, designed such that no-one can easily duplicate it due to an odd colour; and (b) if you had a yellow Filco keyboard you are unlikely to replace the WASD keys with yellow ones seeing as how they are yellow to begin with.
Nearly everything costs too much to get shipped out here to Australia (mainly from US or UK).  Usually at least four times what it costs to ship within Australia.
Offline sth
  • 2 girls 1 cuprubber
« Reply #14 on: Thu, 01 November 2012, 20:49:15 »
clearly you should forget MX and get a topre. besides topre yellow is the best yellow.
« Reply #15 on: Thu, 01 November 2012, 21:49:04 »
^ lol
« Reply #16 on: Thu, 01 November 2012, 22:25:00 »
Topre has wonderful colors.  Except the spacebars...
Offline SmallFry
Re: Re: When yellow is not quite yellow
« Reply #17 on: Thu, 01 November 2012, 22:47:13 »
Those darn ABS space bars!
« Reply #18 on: Thu, 01 November 2012, 22:47:38 »
If I could afford (read: if my other half would approve the expense) a Topre board + yellow keycaps I could have imported a yellow Filco from the US in the first place ;)
Offline reaper
« Reply #19 on: Fri, 02 November 2012, 00:16:16 »
I have both but personally prefer Filco's yellow over Topre's.
Din Eli
« Reply #20 on: Fri, 02 November 2012, 00:22:35 »
Don't want to derail the thread, but where is your new avatar from, reaps?  Reminds me of the Strogg!
Offline reaper
« Reply #21 on: Fri, 02 November 2012, 00:24:41 »
It's from the Expendables.  :)
Din Eli
« Reply #22 on: Fri, 02 November 2012, 00:27:42 »
Thanks reaper :)
That one has bigger legends - I was actually thinking of the slightly bigger legends from WASD (they call it "classic" as opposed to "modern").  The pic I posted above is actually from the WASD eBay listing, where they illustrate the "modern" legends.
That space bar you have looks a slightly different colour.
« Reply #23 on: Fri, 02 November 2012, 00:29:10 »
Offline reaper
« Reply #24 on: Fri, 02 November 2012, 00:33:50 »
Thanks reaper :)
You're welcome and tbh, I've seen some yellow keycaps from WASD (ABS) and personally, I didn't like it at all.
As for the color differences, that is typical on any PBT set since all the keycaps are PBT except the spacebar.  :)
« Last Edit: Fri, 02 November 2012, 00:53:30 by reaper »
Din Eli
« Reply #25 on: Fri, 02 November 2012, 05:11:12 »
As to most things like this, it will probably come down to personal preference.  I have a sampler pack from WASD on its way, so I will be able to see for myself what the yellow looks like.  From the pictures though, it looks a bit, well, plasticky, if that makes sense..
« Reply #26 on: Thu, 15 November 2012, 03:48:26 »
WASD sample pack arrived, and the yellow is somewhat washed out.  Even compared to the yellow Ducky key chain cap I have (the difference is more noticable under natural light).
Offline squarebox
  • In Omnia Paratus
« Reply #27 on: Thu, 15 November 2012, 05:20:11 »
So it's post-it note yellow or canary yellow
YCE yellow?
« Reply #28 on: Mon, 03 December 2012, 03:37:03 »
I now have four different yellow keycaps, apart from the hazard set each one is by itself i.e. not part of a set:
From left to right:
1. WASD sampler kit
2. KeyPop awesome face
3. Ducky key chain keycap
4. Hazard set
The WASD seems the palest, and I probably prefer the hazard yellow best, only marginally better than the awesome face.  The Ducky one seems to sit somewhere between.
From the Hazard GB, this post http://geekhack.org/index.php?topic=36038.msg682866#msg682866 seems to indicate that the colour is YAM, but that does not appear in the earlier pictures of the colour rings.  It does not seem to be one of the standard colours for a SP customised set.
Has anyone got a YAM sample?  For example to compare with the Hazard key, and maybe the WASD key?
I know it is asking a lot - one day I will have to try to get my own colour ring :)
« Last Edit: Mon, 03 December 2012, 03:49:46 by rowdy »
Offline MissMurd3r84
  • In IRC wondering why Kmiller8 is yelling.
« Reply #29 on: Mon, 03 December 2012, 04:26:57 »
IF I get the yellow PBT keys (currently have not heard a thing about them) I will post them next to my yellow WASD key and awesome face to compare the colours for you, too.
KBC Poker - Red switches. Noppoo Choc Mini - Black switches. Leopold FC700R (White) - Blue switches. Ducky YOTD - Brown switches. Razer BW - Blue switches and rusted.
Offline Alessandro
  • The Price Is Right
    • Alessandro's Sweet Shop
« Reply #30 on: Mon, 03 December 2012, 11:56:59 »
Needs more Litster face caps for egg yolk yellow.
Offline inlikeflynn
  • file not found
« Reply #31 on: Mon, 03 December 2012, 12:01:36 »
rowdy: yellow's back in stock in the US now http://www.amazon.com/gp/product/B0060J3XNG/ref=as_li_ss_tl?ie=UTF8&camp=1789&creative=390957&creativeASIN=B0060J3XNG&linkCode=as2&tag=5336432816-20
I know you're not from the US, but at least its available again somewhere now
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
« Reply #32 on: Mon, 03 December 2012, 13:11:54 »
Thank you :)
I thought that was a one-of-a-kind?
Saw that.  Funny - there were only 10 in stock last night, now there are only 20.  At $150 + shipping to AU it is a bit too expensive for the next couple of months, but thank you, at least there is some hope that there are a few left in stores somewhere around the world :)
« Reply #33 on: Fri, 11 January 2013, 00:40:28 »
Following on from the previous comparison, now I have a new yellow keycap to add to the mix:
1. WASD sampler kit
4. Hazard set
5. KeyPop Smile!
The Smile! is probably closest to the awesome face, which is to be expected as they are both from KeyPop.  Also very similar to the Hazard set.
Offline Alessandro
« Reply #34 on: Fri, 11 January 2013, 13:43:16 »
So was everything.
So, is this like the ultimate yellow collection or something?
« Reply #35 on: Fri, 11 January 2013, 16:34:04 »
Just me on my quest for a set of yellow keycaps.  Comparing various yellows available, and sorta making this some kind of small reference to yellow keycaps, at least those that I have.
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
« Reply #36 on: Fri, 11 January 2013, 17:18:45 »
Which are all from SP ;)
« Reply #37 on: Sat, 12 January 2013, 00:07:57 »
That would explain a lot!
« Reply #38 on: Sun, 13 January 2013, 07:09:13 »
I found a yellow for you...
« Reply #39 on: Sun, 13 January 2013, 13:09:08 »
Gimmeh!!1!!!!
(Need a bigger bath tub tho.)
 ;D :)) :D
« Reply #40 on: Sun, 13 January 2013, 16:09:00 »
Hey Rowdy, do you have any topre yellow for comparison? If not I could send you over the esc cap I'm not using.
« Reply #41 on: Sun, 13 January 2013, 23:35:01 »
Not having any Topre boards, no, I also do not have any Topre keycaps.
If I was thinking of getting a Topre board, I would probably get the EK yellow keycaps straight away.  From what I have seen they are a really nice shade of yellow.
I am tempted to say yes, just get get another yellow keycap, although it would spend its life sitting in my spare keycap box.  Is there anyone else who might like it?  Or did you want to keep it to have the full yellow set for potential future sale or something?
If not, I might be tempted :)
For science.
« Reply #42 on: Sun, 13 January 2013, 23:42:22 »
I hope I don't need to sell this topre board in the future! But with esc or not, there is a clack to replace it ;)
Well if you never plan on going topre, and can't help but wanting a cap, lemme know.
« Reply #43 on: Sun, 13 January 2013, 23:55:01 »
I would, to see and compare the yellow, but not if I am stopping someone else from actually using the keycap.
I didn't even enter the EK draw for the Topre clacks, I felt so guilty.
« Reply #44 on: Sun, 13 January 2013, 23:58:04 »
You'll be stopping a box from using it, poor little box!
Just shoot me a pm with your address.
« Reply #45 on: Mon, 14 January 2013, 00:03:04 »
YGPM thanks :D
« Reply #46 on: Wed, 16 January 2013, 12:11:57 »
And the little yellow esc is on his way down! Hope it gets there safe and sound!
I have a feeling the topre yellow will be close to filco yellow from pics I've seen.
Make sure to take comparison shots once it arrives!
« Reply #47 on: Wed, 16 January 2013, 13:09:55 »
Many thanks for that, I'll get back to you in a couple of weeks (which is about how long it usually takes).
Comparison photo - definitely!
One day, hopefully soonish, I hope to get some Filco yellow for what I hope will be a final comparison.
« Reply #48 on: Wed, 30 January 2013, 19:34:08 »
A new addition: Topre yellow!  Thanks Halverson :)
From left to right:
1. WASD sampler kit
4. Hazard set
5. KeyPop Smile!
6. Topre
The Topre yellow is actually different to what I expected.  In the picture it looks like a cross between the WASD yellow and the Ducky yellow, but it is more ... orangish, I suppose.
I imagine it is probably closer to the Filco yellow (which is on it's way!!!).
By itself (as a single keycap), I think I probably still prefer the Smile!/Hazard yellow, but a set of Topre yellow would look really nice :)
« Reply #49 on: Wed, 30 January 2013, 19:37:02 »
Very nice! Ya the topre set in pictures is a little brighter than in person. My thought are similar to filco yellow as well.
