Author Topic: KMAC LE DIY: TheProfosist! (beware high bandwidth content)  (Read 45925 times)
Offline TheProfosist
  • Custom Layouts Only!
Re: KMAC DIY: TheProfosist!
« Reply #50 on: Sat, 10 November 2012, 13:41:27 »
thanks for the video ill defiantly be trying to do the furture ones a bit more carefully with less lube and should be faster with brush. i also have smaller dental syringes that i might give a try.
Offline WhiteFireDragon
    • youtube
« Reply #51 on: Sat, 10 November 2012, 21:45:33 »
Lol this is a ridiculous amount. It shouldn't be gushing out like that. Squirt some grease out a very small container, and use a toothpick or fine brush to apply the grease. The needles that are included with the syringe are waaay too thick so you don't get a good control on the amount that comes out.
Offline MMB
« Reply #52 on: Sat, 10 November 2012, 21:53:23 »
Offline m00nshake
« Reply #53 on: Mon, 12 November 2012, 14:00:04 »
Can't wait to see more updates, oh, and hopefully zinc key caps. :)
Ducky Shine II w/ Green LEDs | Das Professional | Italian Red Filco Ninja Tenkeyless | Unicomp Wildcats Buckling Spring | My Heatware :)
« Reply #54 on: Mon, 12 November 2012, 18:16:53 »
All I have to say about my lube job is its crazy smooth and im happy with the way its turned out. Though for future build i will be applying less more accurately.
Offline Guillairmo
« Reply #55 on: Mon, 12 November 2012, 20:40:48 »
Sorry this may be a little off topic but... I understand KMAC is probably the best Cherry MX board out there right now, however for some people (like me) buying a DIY board like this is almost like gambling. Sure I love mechanical keyboard, however I have practically no experience with assembling/modding any keyboards. So what I'm trying to say is that for the certain people who want top notch quality - could potentially botch the keyboard job and lose their money. Does that make sense or am I just crazy?
Offline esoomenona
  • Gnillort?
« Reply #56 on: Mon, 12 November 2012, 20:45:00 »
It makes sense, and if the concern for that is too great for you to risk, there are certainly people out there who will help you put it together. It may cost more, but that's the price you pay.
« Reply #57 on: Tue, 13 November 2012, 00:04:13 »
Yep im willing to do it... Im building 2 KMAC LE's as well as mine one for m00nshake and one for Acetrak.
« Reply #58 on: Thu, 15 November 2012, 03:34:18 »
Sorry for no progress as of late my internships been taking up most of my time. But I did manage to get some new work lights that just make everything so much easier.
« Reply #59 on: Wed, 21 November 2012, 23:02:20 »
!!! BIG UPDATE !!!  with m00nshake's and Acetrak's KMACs as well as cables from MiMic.
Offline mistakemistake
  • Global Loveinator
« Reply #60 on: Wed, 21 November 2012, 23:40:39 »
nice, looks awesome!
Re: Re: KMAC DIY: TheProfosist!
« Reply #61 on: Thu, 22 November 2012, 04:37:59 »
Offline m00nshake
« Reply #62 on: Thu, 22 November 2012, 12:37:29 »
Thanks so much for the update! Everything looks great so far... :)
« Reply #63 on: Thu, 22 November 2012, 12:42:40 »
Yea hopefully after the holiday break ill get more done.
« Reply #64 on: Fri, 30 November 2012, 00:22:56 »
Got the Zinc caps for my and m00nshake's keyboards in today. m00nskaes good to go,  I am down 5 caps :(
« Reply #65 on: Fri, 30 November 2012, 03:14:25 »
Updated as the Zinc caps showed up.
« Reply #66 on: Fri, 30 November 2012, 18:47:24 »
Updated with some small progress I made on m00nshakes KMAC
Offline bace
« Reply #67 on: Fri, 30 November 2012, 23:01:39 »
wow this looks amazing! everything is so nice and clean especially with the zinc caps. props to you sir.
[Current] : Maxkeyboard NightHawk x8 ; Topre Realforce 103UB 55g ; Topre TypeHeaven
[Past] : Noppoo Choc Mini ; Das Keyboard Pro ; Filco Majestouch 2 Linear R Black Ninja 104 ; White Filco Majestouch 2 Ninja 104 ; Plu ML-87
Logitech G500
« Reply #68 on: Fri, 30 November 2012, 23:07:23 »
Thanks I try to keep  eveything as clean and in good of shape as possible especially when dealing with other keyboards.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #69 on: Sat, 01 December 2012, 00:19:46 »
Just wondering, does the nonslip roll help it feel any different?
SmallFry! <3
« Reply #70 on: Sat, 01 December 2012, 00:38:46 »
I have not tried it without it but i know when i added it to other keyboards it felt like it tightened stuff up and it lowered the noise while typing.
Offline Sai
« Reply #71 on: Thu, 13 December 2012, 02:42:10 »
i'd love to get one !! nice thread. always come to this thread to drool  :p :p
« Reply #72 on: Thu, 13 December 2012, 09:06:49 »
My Cheat felt way to unstable so I padded the bottom.  I used a piece of a ShamWOW towel (just a big chunk of felt, really) with nonslip on both sides.  It REALLY changed the feel of the board.  It provided some support behind the PCB to absorb some flex, and it quieted down.  It provides a bit of shock absorption, which accounts for the reduction in noise.  It also helped keep the plate from moving around inside the assembly (the cheat doesn't have screw mounts for the plate)
« Reply #73 on: Thu, 13 December 2012, 09:13:03 »
i think sherryton might still have on KMAC up for sale so you mabe be in luck.
« Last Edit: Thu, 13 December 2012, 09:17:55 by TheProfosist »
Offline Sai
« Reply #74 on: Thu, 13 December 2012, 09:33:53 »
well. i'll need to put my urge to get KMAC , etc to on hold for now. Currently waiting for GH60 project.  ;D ;D
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #75 on: Thu, 13 December 2012, 09:46:31 »
Might be a long wait if you're not on the prototyping team...
« Reply #76 on: Thu, 13 December 2012, 09:52:59 »
yea i still havnt goten my protoboard so like all GH projects itll be a while.
« Reply #77 on: Thu, 13 December 2012, 10:52:13 »
Hey prof, quick question. Do you happen to know the length of the spacebar stabilizer wire off hand? I have one that's a bit too long I need to bend.
« Reply #78 on: Thu, 13 December 2012, 11:06:10 »
havnt a clue but i can measure it. Ive always just had alaricljs make me new ones since hes got the wire and the bender.
« Reply #79 on: Thu, 13 December 2012, 11:34:32 »
Yea I've been waiting for some from him in the mail, but I fear they may have gotten lost. Oh well, I'll just compare with another board and give it a try.
Offline Sai
« Reply #80 on: Thu, 13 December 2012, 19:43:20 »
ok. that is fine by me since i don't have any place to keep KMAC and i will need to save some money. I'll just find in the classified section when the time comes !! ;D ;D or build for me , prof. :D
Re: KMAC LE DIY: TheProfosist!
« Reply #81 on: Thu, 13 December 2012, 19:45:01 »
alright sounds good!
« Last Edit: Thu, 13 December 2012, 21:47:31 by TheProfosist »
« Reply #82 on: Thu, 13 December 2012, 19:53:05 »
Updated the thread with pics of m00nshake's finished board. and added a place for aggiejy's.
« Reply #83 on: Sun, 16 December 2012, 19:49:29 »
added a place for HolidaySHRIMP's KMAC LE
Offline TheQsanity
  • SmallFry Lovin'
« Reply #84 on: Sun, 16 December 2012, 21:06:07 »
Whats the differance between kmac and phantom.  They both seem to be highly rated.
SmallFry! <3
Offline SmallFry
« Reply #85 on: Sun, 16 December 2012, 21:16:01 »
Phantom is a GeekHack project. The KMAC is a Korean KBDMania project. They are very different in that the Phantom was the first to introduce a "modder plate" but it was designed to fit into a Filco Case. The KMAC had a full case included which bolted the plate to the case among other things. It's very very different.
« Reply #86 on: Sun, 16 December 2012, 21:17:42 »
Also should mention how you program them is completely different as well.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #87 on: Sun, 16 December 2012, 21:57:58 »
Aside from which there are 2 completely different firmwares available for the Phantom and enough information available to write your own or adapt yet another one that is available to it.  :)
Filco w/ Imsto thick PBT
« Reply #88 on: Sun, 16 December 2012, 21:59:34 »
hasu FTW!
Offline clakdale661
« Reply #89 on: Sun, 16 December 2012, 23:40:24 »
Hey everything in here looks so nice and clean. I want my Filco to look like this too. Great job Profesist! These are inspirational builds
« Reply #90 on: Sun, 16 December 2012, 23:48:00 »
Thanks I try.
Offline HolidaySHRIMP
« Reply #91 on: Mon, 17 December 2012, 15:45:57 »
Yay <3
« Reply #92 on: Thu, 20 December 2012, 05:50:11 »
more unboxing pics to come tomorrow.
Re: Re: KMAC LE DIY: TheProfosist!
« Reply #93 on: Thu, 27 December 2012, 02:56:49 »
oops these never came did they well i have my dslr now ill try to get them up once i have my new watermark.
« Reply #94 on: Fri, 28 December 2012, 20:50:56 »
Can't wait!
« Reply #95 on: Mon, 31 December 2012, 05:45:04 »
Started taking some pics yeaterday. Im waiting on some new soldering equipment before i continue to build these as it will be much easier with the new stuff.
« Reply #96 on: Mon, 31 December 2012, 14:18:18 »
m00n's build came out to be so beautiful!  Couldn't have wished a better keyboard for such a cool guy, and whoa, Prof, your dedication to assembling these boards while documenting the process has made my eyes really happy..  :D
Re: KMAC LE DIY: TheProfosist! (beware high bandwidth content)
« Reply #97 on: Tue, 01 January 2013, 18:49:27 »
added disclaimer to the title.
