Author Topic: KMAC LE DIY: TheProfosist! (beware high bandwidth content)  (Read 45916 times)
Offline TheProfosist
  • Custom Layouts Only!
« on: Fri, 02 November 2012, 23:03:59 »
I decided to make a thread about building KMAC LE's in pictures. Check it out below!
m00nshake's KMAC LE Build:
Acetrak's KMAC LE Build:
TheProfosists's KMAC LE Build:
aggiejy's KMAC LE Build:
HolidaySHRIMP's KMAC LE Build:
« Last Edit: Tue, 01 January 2013, 18:48:43 by TheProfosist »
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Re: KMAC DIY: TheProfosist!
« Reply #1 on: Fri, 02 November 2012, 23:07:30 »
Looking forward to build progress.
Offline mistakemistake
  • Global Loveinator
« Reply #2 on: Fri, 02 November 2012, 23:09:07 »
^ohhh pretty! same here, posts lots of pics!
« Reply #3 on: Fri, 02 November 2012, 23:14:23 »
Dont worry I have 3 KMAC's to do so there should be a whole bundle of pics. If I miss something you want to see the first time around let me know and ill get it the next time.
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #4 on: Fri, 02 November 2012, 23:20:47 »
Looking forward to this thread  ;D
« Reply #5 on: Fri, 02 November 2012, 23:22:05 »
Good thread
« Reply #6 on: Fri, 02 November 2012, 23:22:06 »
Hope yo udont mind if I feature your KMAC as well.
« Reply #7 on: Fri, 02 November 2012, 23:37:22 »
New pics from tonight added.
« Reply #8 on: Fri, 02 November 2012, 23:53:29 »
Will be following this thread :) looks like it'll be fun and possibly educational.
Offline esoomenona
  • Gnillort?
« Reply #9 on: Fri, 02 November 2012, 23:58:03 »
« Last Edit: Mon, 21 September 2015, 16:17:58 by esoomenona »
« Reply #10 on: Sat, 03 November 2012, 00:02:09 »
Seeing how fast you're jumping on this and will have it done makes me sad that mine won't be done for awhile. Probably nothing for e for the end of the year. So I shall live vicariously through you and your thread.
Yea the only parts im waiting on are lube and a spacebar wire which are both stuck on the east coast at this time otherwise i think I would have tried to bang the thing out in one sitting. What can I say, im anxious to get this thing working to start testing out layouts.
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #11 on: Sat, 03 November 2012, 00:19:08 »
Don't mind at all, I'm actually quite interested and have always loved WIP threads
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #12 on: Sat, 03 November 2012, 01:07:46 »
Good idea, profosist!
Offline jeroplane
« Reply #13 on: Sat, 03 November 2012, 02:10:05 »
This is great - I love seeing step-by-step documentation of things being put together :)
Looking forward to seeing your progress!
My signature hasn't changed since 2012. I should really update it.
Re: Re: KMAC DIY: TheProfosist!
« Reply #14 on: Sat, 03 November 2012, 02:28:28 »
if there is anything you specifically want to see let me know then.
« Reply #15 on: Sat, 03 November 2012, 02:31:06 »
Thanks everyone ill do my best to take pics at each step but if i miss something or you want to see something specific let me know. Ill do my best to get pics of what your looking for I have 3 of there so build and i plan to snap shots throughout the entire process of all of them.
Offline WhiteFireDragon
    • youtube
« Reply #16 on: Sat, 03 November 2012, 02:50:36 »
How about a video with talking commentaries for the newbs too  ;)
« Reply #17 on: Sat, 03 November 2012, 03:08:21 »
Now, I think thats asking too much. And im sticking to pictures so if you have questions about some that I post ask away!
« Last Edit: Sat, 03 November 2012, 03:11:36 by TheProfosist »
Offline m00nshake
« Reply #18 on: Sat, 03 November 2012, 04:40:46 »
I think this is a great idea, TheProfosist, and can't wait to see everything as it's worked on. Hopefully the lube won't take much longer to arrive.
Ducky Shine II w/ Green LEDs | Das Professional | Italian Red Filco Ninja Tenkeyless | Unicomp Wildcats Buckling Spring | My Heatware :)
Offline ZcHuer
« Reply #19 on: Sat, 03 November 2012, 08:48:52 »
Anyone have a Enlish KMAC manual? Can't find it anywhere else.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #20 on: Sat, 03 November 2012, 08:53:08 »
Thanks for sharing detailed pics of your process.
« Reply #21 on: Sat, 03 November 2012, 11:12:38 »
i think there was one but its not up to date with the latest firmware or something you should ask in the main KMAC DIY thread.
« Reply #22 on: Sun, 04 November 2012, 01:29:43 »
No real progress today as i was trouble shooting firmware with SmallFry. I hope to finish desoldering some vintage black from a WYSE PCE board tomorrow.
« Reply #23 on: Mon, 05 November 2012, 01:29:38 »
Firmware figured out and uploaded to the KMAC and working and the WYSE PCE is fully desolderd more pics to be uploaded tomorrow.
Offline ZcHuer
« Reply #24 on: Mon, 05 November 2012, 10:27:15 »
I was stuck in the key mapping... failed to generate a HEX file by kmacs.exe. Could anybody help me out there ?
Offline alaricljs
  • I be WOT'ing all day...
« Reply #25 on: Mon, 05 November 2012, 11:02:29 »
the exe needs to be in a path that has no spaces... such as:  C:\KMAC
Filco w/ Imsto thick PBT
Offline SmallFry
« Reply #26 on: Mon, 05 November 2012, 11:11:48 »
Aha! There is your problem Prof! Sweet!
« Reply #27 on: Mon, 05 November 2012, 16:26:07 »
yep there is another way around that too by adding a space found that out after much testing
« Reply #28 on: Tue, 06 November 2012, 02:29:41 »
OP updated with more pictures of progress!
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #29 on: Tue, 06 November 2012, 08:05:25 »
Progress looking good Prof ;D
Offline esoomenona
  • Gnillort?
« Reply #30 on: Tue, 06 November 2012, 09:44:59 »
« Last Edit: Mon, 21 September 2015, 14:48:04 by esoomenona »
Offline ekw808
  • Ekw
« Reply #31 on: Tue, 06 November 2012, 10:24:45 »
Why do you have to solder diodes, I thought the KMAC pcb came with them already installed.
[One Keyboard at a time]
Offline SmallFry
« Reply #32 on: Tue, 06 November 2012, 10:27:40 »
I think that's on the mini, not the original KMAC, IIRC. Not sure exactly.
Offline esoomenona
  • Gnillort?
« Reply #33 on: Tue, 06 November 2012, 10:31:11 »
« Last Edit: Mon, 21 September 2015, 14:47:24 by esoomenona »
  • Global Loveinator
« Reply #34 on: Tue, 06 November 2012, 12:14:14 »
looking pretty awesome!
« Reply #35 on: Tue, 06 November 2012, 13:37:29 »
Coming along nicely. Looking forward to seeing it completed. What weight are those springs?
62g
« Reply #36 on: Tue, 06 November 2012, 13:39:13 »
my KMAC LE did not have any diodes on it at all had to solder them all on, the whole time wishing i had a finer tip.
« Reply #37 on: Wed, 07 November 2012, 04:30:49 »
No progress tonight as the lube has still not made it to me.
Offline Rinsaku
  • lorem ipsum
« Reply #38 on: Wed, 07 November 2012, 04:35:34 »
So awesome! I need to start some kind of project, so i wouldn't be jelly all the time.. Cant wait to see it completed!
Current Boards : Apple m0116 (Salmon Alps), B.Face (Mx Clears), Filco Tkl (Mx Blues), HHKB Pro JP (Topre), Jd45 (78g Zealios), KBParadise v60 (Gateron Yellows), KBParadise v60 (Matias Quiet Click), Kbt Pure (Kailh Bronze), Leopold FC660M (Mx Browns), Minidox (Mod-H), Pok3r (62g Zealios)
« Reply #39 on: Wed, 07 November 2012, 04:39:36 »
well the first KMAC should be completed by the end of the week hopefully (pertaining lube delivery). As for the rest thpse havnt even made it to me yet... Id start a project for my custom Filcos also but all thats left is the lubing of the switches as i progressively been working on them over time.
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #40 on: Fri, 09 November 2012, 15:50:30 »
Time to update dem photos Prof  :))
« Reply #41 on: Fri, 09 November 2012, 19:41:23 »
Well KMAC is completed for the most part pics will be up soon I have to reinstall photoshop on Win8
« Reply #42 on: Sat, 10 November 2012, 01:57:38 »
More Pics uploaded My KMAC is now complete minus the keycaps, just using an extra Filco set i have currently. I received m00nshake's KMAC and will take unboxing pics tomorrow.
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #43 on: Sat, 10 November 2012, 09:09:21 »
Looking good! I like the sig update too :)
Was it hard to figure out the led?
« Reply #44 on: Sat, 10 November 2012, 11:40:03 »
Thanks, cant wait for the proper zinc keycaps though!
na not all all what made you thin they would  be?
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
« Reply #45 on: Sat, 10 November 2012, 12:57:36 »
Prof, I just saw a picture of the lube on your switches.  I think you should re-mod them, you've put WAY too much lol
« Reply #46 on: Sat, 10 November 2012, 13:03:37 »
they feel fine....? on the rest ill keep the lube down i need a new application method my hand hurts after using that syringe for so long. Also does lubing the springs really do anything I have my doubts...
Offline alaricljs
« Reply #47 on: Sat, 10 November 2012, 13:12:56 »
Syringe?  wow... I use a small paint brush, and really should use a smaller one.  Lubing the springs makes it a little quieter.
« Reply #48 on: Sat, 10 November 2012, 13:20:47 »
ok I have some paint brushes from when i used that white lube wasd used to use so those should work!
Offline DanGWanG
  • Higher Standards
« Reply #49 on: Sat, 10 November 2012, 13:25:40 »
Not my greatest video ever, but take a look below.  You should only brush 1-2 strokes per side at most.
