Author Topic: KMAC,KMAC 1.2 & KMAC 2: Just what are the differences?  (Read 47264 times)
Offline balanar
« on: Sun, 04 November 2012, 17:57:18 »
Hey guys, figured this might be a good place to ask a question that has been confusing me for some time now. What are the differences between a KMAC, KMAC 1.2 & KMAC 2? I mean in terms of PCB, case (shape, colour, finish), and anything else at all.
I don't have access to a KBDmania or OTD as my attempts to create an account keep failing for some reason so pictures would be friggin' awesome as well. Tried googling but very little if any info shows up and even then I'm not sure which keyboard I'm looking at. Please help a guy who just might have a rare chance to get one of these as soon as I am able to actually know the differences before choosing one.
Re: KMAC,KMAC 1.2 & KMAC 2: Just what are the differences?
« Reply #1 on: Sun, 04 November 2012, 18:37:57 »
By my understanding the new KMACs are very similar, but have better anodizing for improved durability.  KMAC2 has a new case design that can be switched between winkey and winkeyless by using a metal insert.
Offline SmallFry
« Reply #2 on: Sun, 04 November 2012, 18:52:42 »
Heh, I'll post that PM here, as I figure that it may help some other GH'ers as well.
Well let's see... I believe the differences between the KMAC 1 and the 1.2 are mainly in the case. The KMAC 1 had a case that wasn't hard aninized. Thus, after a lot of touching of the case, the KMAC would change colors. They fixed this in the 1.2 IIRC. The KMAC 2 has blocks that make the PCB and case usable in 84 through 86/87 key layouts by adjusting where the blocks go for the case and adjusting the switch positions. I'm sure there's other differences since I don't browse there often, so start a thread. :)
Cheers.
Nate
Offline m00nshake
« Reply #3 on: Sun, 04 November 2012, 18:55:26 »
Cheers.
Nate
Very helpful... but where does the Kmac LE fall in this? Does it have the same issue as the Kmac 1?
Ducky Shine II w/ Green LEDs | Das Professional | Italian Red Filco Ninja Tenkeyless | Unicomp Wildcats Buckling Spring | My Heatware :)
Offline jeroplane
« Reply #4 on: Sun, 04 November 2012, 18:56:35 »
Does anyone have any photos of these infamous "blocks" of the KMAC 2?
My signature hasn't changed since 2012. I should really update it.
Offline WhiteFireDragon
    • youtube
« Reply #5 on: Sun, 04 November 2012, 19:03:10 »
I saw the removable blocks on the kmac 2. Personally, not my cup of tea. It's just an addon square that screws to the main chassis. The block just doesn't look like it integrates with the case very well. Not as elegant IMO. I'll dig up pics when I have time.
Offline reaper
« Reply #6 on: Sun, 04 November 2012, 19:15:40 »
Here you go..
Also the final product won't have that fugly gold color block.  ;)
« Last Edit: Sun, 04 November 2012, 19:51:08 by reaper »
Din Eli
Offline SmallFry
« Reply #7 on: Sun, 04 November 2012, 19:18:09 »
Cheers.
Nate
The LE was supposed to be a Limited Edition of the KMAC. I believe there were less LE's made than official KMAC's. The LE's were unfortunately plagued with the two-toned "mistake"
The KMAC 2's have a modular block that allows you to change the layout pretty easily. See Reaper's post here for some of the KMAC 2 pictures that won't take a year to load. The KMAC 2 comes in three colors as well, silver, titanium, and red, if you read in the KMAC thread I linked to above.
EDIT: Bah, ninja'd
« Last Edit: Sun, 04 November 2012, 19:20:22 by SmallFry »
Offline jeroplane
« Reply #8 on: Sun, 04 November 2012, 19:23:37 »
Thanks for the pics reaper and the info, SmallFry. I would rather just use a 1x key there instead of that block. :confused: But I suppose it would be slightly better if the colour matched the case.
Offline SmallFry
« Reply #9 on: Sun, 04 November 2012, 19:26:49 »
The color will match the case in the final KMAC 2. I like the ability to use 1 unit Super keys as well! Much prefered layout to the total Winkeyless.
Offline AKIMbO
  • HHKBro
« Reply #10 on: Sun, 04 November 2012, 19:28:46 »
That block...no me gusta.  It makes the keyboard look less slick.  Dunno what they were thinking. Maybe they were trying to reduce manufacturing costs?
| KBD75 (box reds)
Offline alaricljs
  • I be WOT'ing all day...
« Reply #11 on: Sun, 04 November 2012, 19:32:38 »
Also, as far as I can interpret from pics it would appear as tho the plate is optional since standoffs are included and the appropriate holes are present.
Filco w/ Imsto thick PBT
Offline SmallFry
« Reply #12 on: Sun, 04 November 2012, 19:33:07 »
People didn't want to get both KMAC's to use the 1 unit Super keys. You'd have to buy both cases and PCB's and swap them.
« Reply #13 on: Sun, 04 November 2012, 19:35:37 »
If they made the blocks color match... would look cool.
Edit: ma bad, only looked at the pictures :P
« Last Edit: Sun, 04 November 2012, 20:10:52 by Sifo »
Offline SmallFry
« Reply #14 on: Sun, 04 November 2012, 19:41:13 »
The blocks are supposed to match. Read all of Reaper's post. :D
Offline balanar
« Reply #15 on: Sun, 04 November 2012, 20:11:43 »
EDIT: Bah, ninja'd
Wait a sec, in the thread you pointed to, reaper mentioned that the KMAC 2 only comes in titanium. Which is it?
Also, does the new slanted design mean the height will not be adjustable. This is not the case (pun not intended) with the KMAC 1/1.2 right?
Offline SmallFry
« Reply #16 on: Sun, 04 November 2012, 20:46:28 »
[Strike]See this post.[/strike]
« Last Edit: Sun, 04 November 2012, 21:34:07 by SmallFry »
Offline m00nshake
« Reply #17 on: Sun, 04 November 2012, 21:20:48 »
I'm confused. What's the mistake in the two tones of the Le? I thought it was intended to be two tones.
Offline reaper
« Reply #18 on: Sun, 04 November 2012, 21:28:16 »
Read my review on the original KMAC here (it's in archive).  Look toward the bottom of the review for that particular info.  The KMAC LE came from the defective batch.
Also I was told that the KMAC 2 only comes in titanium and that the new KMAC 1.2 will be available in either red, silver or titanium color.
« Last Edit: Sun, 04 November 2012, 21:29:49 by reaper »
Din Eli
Offline alaricljs
« Reply #19 on: Sun, 04 November 2012, 21:29:15 »
It was not intended to be 2 tones on the 1 case set.
Offline balanar
« Reply #20 on: Sun, 04 November 2012, 21:32:27 »
See this post.
So basically what I understand from that is:
KAMC 2 = 1 colour (Titanium)
KMAC 1.2 aka revised KMAC = 3 colours (Titanium, Silver & Red)
Both KMACs will come with the blocks. The blocks will match the colour of the case.
Please correct me if I am wrong.
Offline SmallFry
Re: Re: KMAC,KMAC 1.2 & KMAC 2: Just what are the differences?
« Reply #21 on: Sun, 04 November 2012, 21:33:17 »
Reaper is correct on the colors, scratch my color stuff from earlier.
Offline MMB
« Reply #22 on: Sun, 04 November 2012, 21:33:53 »
KMAC 2 doesn't use legs like the KMAC 1. It has a case that is angled, and is quite a bit heavier, due to the extra aluminum.
Offline MMB
« Reply #23 on: Sun, 04 November 2012, 21:41:21 »
They all come with blocks. This was confirmed.
This was the info I got from Taeyoung:
Yes, both of KMAC 1.2 and KMAC2 can use the blockers and which is allows to make 84 and 86 layouts.
As you can see the attached pic, KMAC2 doesn't use the keyboard feet any more which means KMAC2 is much heavier than KMAC 1 and 1.2(kmac2_02.jpg/kmac2_03.jpg)
And also you can assemble KMAC2 without plate due to KMAC2 has 33 ea support holes for non-plate-mounted style.
As for KMAC2, there's only one color which might be kind of  dark grey or gunmetal grey color so you can order RED case.
Both of KMAC2 and 1.2 will have a RED metal plate
« Last Edit: Sun, 04 November 2012, 21:42:58 by MMB »
Offline reaper
« Reply #24 on: Sun, 04 November 2012, 21:44:24 »
Okey Dokey... let me erase that then. lol  :)
Din Eli
Offline MMB
« Reply #25 on: Sun, 04 November 2012, 21:51:12 »
Also, as stated; KMAC 2 is NOT titanium. It's more of a gunmetal grey.
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
« Reply #26 on: Sun, 04 November 2012, 22:47:14 »
How hard are these things to put together? can you buy an additional PCB to easily swap out the switches? and what's a base price for one of these ... kits?
Gotta say, I thought that KMACS was a new flavor of Emacs. I been out of it a while I guess.
Offline SmallFry
« Reply #27 on: Sun, 04 November 2012, 23:06:31 »
About ~$400 USD xsphat.
Offline xsphat
  • Enlightened
« Reply #28 on: Sun, 04 November 2012, 23:09:19 »
Why would anyone pay that much to do so much work? JK, I get it, I'm just not getting in line ...
Offline alaricljs
« Reply #29 on: Sun, 04 November 2012, 23:15:39 »
Also, no on the extra PCBs, you buy the full KB kit, no replacement or separate parts.  I have put together quite a few of these Korean customs... the all metal case ones are quite nice.  I am not a fan of the acrylic models.
Offline xsphat
  • Enlightened
« Reply #30 on: Mon, 05 November 2012, 00:37:23 »
Can you put Topre switches in them?
Just kidding, don't kill me, lol.
Offline reaper
« Reply #31 on: Mon, 05 November 2012, 00:53:17 »
Haha, I wish.  That would be cool.  :)
Din Eli
Offline xsphat
  • Enlightened
« Reply #32 on: Mon, 05 November 2012, 00:57:58 »
I still like the Topre switch the best, but only the black stemmed ones ... Another joke.
Offline m00nshake
« Reply #33 on: Mon, 05 November 2012, 15:16:08 »
Thanks for the clarification. Was this rectified in later batches of the KMAC LE? And other than the two tone color, is the KMAC LE basically the same as the original KMAC or KMAC 1.2?
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #34 on: Mon, 05 November 2012, 16:57:24 »
I thought the two-tone look was really neat – just added a little extra to the styling. I imagine too many other people do to be able to snap one up really cheap ;-)
(Not going to spend a lot on a TKL as I'd only use it a spare at work, just for its low size – I likes my number pad, I do. I want a G84 board but Cherry cannot for the life of them manage a single sensible layout for the G84, while laptop makers the world over get compact layouts perfect.
The other reason I wouldn't want a metal keyboard at work as something about the floor means that I'd get static shocks off my keyboard all day and I'd end up throwing it out the window. That aside, I lament the lack of love that full-size boards get in the aluminium department ...)
Bore Awards
Offline reaper
« Reply #35 on: Mon, 05 November 2012, 23:00:34 »
You're welcome and as far as I know, it was never rectified.  After the orginal KMAC was sold out, the rest was put on sale as LE.
KMAC LE is the same as the orginal KMAC except the letter LE on the PCB.  KMAC 1.2 has a new plate & PCB.
Not going to spend a lot on a TKL as I'd only use it a spare at work, just for its low size – I likes my number pad..
Like you numpad you say..  get a Kpad too then.  :)
« Last Edit: Mon, 05 November 2012, 23:04:39 by reaper »
Din Eli
« Reply #36 on: Mon, 05 November 2012, 23:07:32 »
Now that's a mighty attractive setup right there.
Offline esoomenona
  • Gnillort?
« Reply #37 on: Mon, 05 November 2012, 23:11:48 »
« Last Edit: Mon, 21 September 2015, 14:51:49 by esoomenona »
Offline reaper
« Reply #38 on: Mon, 05 November 2012, 23:19:54 »
Yup.
Din Eli
Offline esoomenona
  • Gnillort?
« Reply #39 on: Mon, 05 November 2012, 23:24:58 »
« Last Edit: Mon, 21 September 2015, 14:51:01 by esoomenona »
Offline TheProfosist
  • Custom Layouts Only!
« Reply #40 on: Mon, 05 November 2012, 23:29:10 »
Damn all you guys are so lucky!
Offline tubby
« Reply #41 on: Mon, 05 November 2012, 23:37:09 »
Very informative!
Now, would any one know the differences between KMACs and OTD Customs? ^^;
Realforce 87UB SE1700 | HHKB Pro 2 | Filco Kobo Red Wood | Filco FKBN87MR/CB2 | Filco FKBN97MRL/EW2 | Filco FKBN87MC/EY2 | Filco FKBN87M/EMU2 | Filco FKBN104M/EB-AI | Filco FKBN104MC/EB | Ducky DK9008 | KBC Poker brown | Realforce 23UB WC01B0 | Filco FKB22MB
Offline reaper
« Reply #42 on: Mon, 05 November 2012, 23:39:58 »
Which one?  There's so many of them.
« Last Edit: Mon, 05 November 2012, 23:50:01 by reaper »
Din Eli
Offline sherryton
  • Kībōdo
    • Originative
« Reply #43 on: Tue, 06 November 2012, 00:02:02 »
Let me clear this up a little bit...
They got the KMAC batch.  Somehow, they were able to distinguish the top and the bottom were different colors.  If you look real carefully, they are the exact same colors, and it is nearly impossible to distinguish the differences without the Korean's eyes.  They decided to re-order them again, and they posted the KMAC LE after the initial sale finished.
Offline tubby
« Reply #44 on: Tue, 06 November 2012, 03:43:43 »
I don't have any specific ones in mind cos I don't even know whats out there ^^; But just in general. For example, case-wise I notice most of OTD Customs consists of 3 layers instead 2 like KMACs, would that be right?
And I was also told that they have different PCBs too, and would like to know how are they different =)
Offline m00nshake
« Reply #45 on: Tue, 06 November 2012, 05:06:44 »
Thanks for the clarification about the Kmac Le, Reaper and Sherryton.
Now who's going to help me obtain Kpad? It looks really nice, Reaper.
Offline trentva
« Reply #46 on: Tue, 06 November 2012, 08:29:16 »
ahhh want a kmac badly
« Reply #47 on: Wed, 07 November 2012, 04:31:53 »
you wont need a kpad for your kmac ;) your layouts got a numpad in it ;)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #48 on: Tue, 20 November 2012, 01:00:28 »
Are there any pictures of the KMAC 2? These are  programmable right?
Offline sth
  • 2 girls 1 cuprubber
« Reply #49 on: Tue, 20 November 2012, 01:02:05 »
in this thread
