Author Topic: What is this, and does it matter?  (Read 2234 times)
Offline nethowler
« on: Tue, 06 November 2012, 14:30:35 »
Bought this for $3.  The keycaps looked like Cherry MX but they don't fit.  I was considering sanding down the bottom of the caps so see if I can make them fit.  Has anyone had any luck with such a mod?
Offline Hyde
  • White Tofu Extraordinaire
Re: What is this, and does it matter?
« Reply #1 on: Tue, 06 November 2012, 14:40:36 »
To me this look like electronic typewriter but I'm no way an expert in this so I could be wrong  :P
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Tue, 06 November 2012, 14:40:38 »
stem mount is too close to the keywall, it won't work. You would have to remove the entire stem, and replace it. I think that is too much effort, but that is your call.
Offline esoomenona
  • Gnillort?
« Reply #3 on: Tue, 06 November 2012, 15:15:20 »
Or maybe if you had a modified case, where the very front was trimmed back to allow for the difference, would that work?
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #4 on: Tue, 06 November 2012, 15:20:22 »
Doesn't work. Lysol is dead on here. I've encountered these in my e-cycling center exploration and they will not travel enough to activate the switch because of the stem location.
Offline esoomenona
  • Gnillort?
« Reply #5 on: Tue, 06 November 2012, 15:37:34 »
Ah, because of their height?
Offline nethowler
« Reply #6 on: Tue, 06 November 2012, 16:42:35 »
I was thinking about sanding them down from the bottom to lower the stem height, and overall height of the key.  Not sure about how to get around the stem placement.
