Author Topic: .  (Read 5206 times)
Offline esoomenona
  • Gnillort?
« on: Thu, 08 November 2012, 15:13:23 »
« Last Edit: Wed, 15 October 2014, 19:59:28 by esoomenona »
Offline Skull_Angel
Re: What do you use for Cherry relegendable keys?
« Reply #1 on: Thu, 08 November 2012, 15:24:26 »
I'm not certain myself, but I have seen them printed on directly. From what I've seen of those printed ones, they seemed to have been done with a sort of stamp kit.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #2 on: Thu, 08 November 2012, 15:26:20 »
I just don't use them at all. They look cool but he tops always pop off
Offline esoomenona
  • Gnillort?
« Reply #3 on: Thu, 08 November 2012, 15:29:15 »
« Last Edit: Wed, 15 October 2014, 19:59:34 by esoomenona »
Offline Skull_Angel
« Reply #4 on: Thu, 08 November 2012, 15:42:08 »
Lasered relengedables? Wow, I've only seen them printed on with washable ink/dye, wouldn't "permanent" print defeat the purpose of relengedables? hehe
Offline baldgye
  • Will Smith Disciple
« Reply #5 on: Thu, 08 November 2012, 15:44:53 »
if you mean the caps with the plastic transparent tops on, what I like to do is print things off, cut them to fit and then have a baller little pic in them.
I HAVE A BOOB KEY. That is all.
Offline esoomenona
  • Gnillort?
« Reply #6 on: Thu, 08 November 2012, 15:55:49 »
« Last Edit: Wed, 15 October 2014, 19:59:42 by esoomenona »
Offline baldgye
« Reply #7 on: Thu, 08 November 2012, 16:00:50 »
They are under the cap, so putting something over them (a piece of paper or such) would cover the legend under it.
That was another thought. I was thinking there would be pre-perforated pages that could be printed on and popped out to fit perfectly. Is this so?
if there are I don't have any... just use trial and error
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #8 on: Thu, 08 November 2012, 16:16:13 »
Hooleon sell the die cut inserts, in several colors.
Offline esoomenona
  • Gnillort?
« Reply #9 on: Thu, 08 November 2012, 16:57:24 »
« Last Edit: Wed, 15 October 2014, 19:59:50 by esoomenona »
Offline The_Beast
  • I like wood ಠ_๏
« Reply #10 on: Thu, 08 November 2012, 17:11:51 »
Offline Rumudiez
« Reply #11 on: Sat, 10 November 2012, 12:45:05 »
I remember seeing a sheet of perforated squares with some relengendable caps somewhere. I'd like to say at SP, but my memory tends to become more vivid[ly wrong] over time.
40% layout, anyone?
