Author Topic: UV Protection CC Skulls  (Read 8009 times)
Offline BlindRAGE606
  • Prince of All Saiyans
« on: Mon, 12 November 2012, 12:58:58 »
I've got coming in the mail a White 3D CC which was purchased from another member, and was reading that they are not UV protected. I want to avoid a white color turning into yellow due to UV, is there a way to do this?
I know that several automotive products do offer UV protection to plastics, and is this a safe way to do so on a CC? I will be using the CC on a keyboard, in a room that gets lots of natural sunlight. However, NOT directly in a ray of sunshine.
Thanks
DUCKY TKL MX BLACK | HHKB PRO 2 | BEAST PH&LACEWOOD
Offline dirge
Re: UV Protection CC Skulls
« Reply #1 on: Mon, 12 November 2012, 13:20:30 »
Thinking about things isn't the same as doing things. Otherwise everybody would be in jail.
Offline esoomenona
  • Gnillort?
« Reply #2 on: Mon, 12 November 2012, 13:21:52 »
^Time to lube up my Clacks. Mmm...
Offline dirge
« Reply #3 on: Mon, 12 November 2012, 13:29:54 »
long as you can get them back out.  Pretty embarrassing if the doctor has to retrieve them.
Offline mehkat1974
« Reply #4 on: Mon, 12 November 2012, 18:30:38 »
don't leave it out in the sun
a room with light isn't the same as direct sunlight, I'll wager it will come to no harm
HHKB Type-S / KBC Poker with reds
Offline Ragnorock
  • Group Buy Guy
« Reply #5 on: Mon, 12 November 2012, 18:32:59 »
It'll be fine lol.
« Reply #6 on: Mon, 12 November 2012, 19:29:57 »
No, there was one posted recently that had turned a sort of bone white colour - it looked kinad cool, but not if you expected it to be pure snow white.
Offline mehkat1974
« Reply #7 on: Mon, 12 November 2012, 21:54:56 »
maybe the owner was a smoker?
anything white placed in direct sunlight for a decent amount of time will change colour, paper, plastic, wood... skin. maybe not metal. That's why we paint stuff that's outside and even then it needs re-painting every so often.
just don't leave it in DIRECT sunlight
« Reply #8 on: Mon, 12 November 2012, 22:07:00 »
No.  He said his skull had been in direct sunlight for a while.
Sorry I can't quickly find the picture - it was in one of the media threads, I think.
Offline squarebox
  • In Omnia Paratus
« Reply #9 on: Tue, 13 November 2012, 01:15:31 »
I was the one with yellowed CC. I don't smoke but my computer is close to the window.
Filco Yellow Edition  | Filco Brown | Filco 2 Brown TKL | G80-1950 | G80-3494 | G80-11900 | Leopold FC500R | Noppoo Choc Mini
Offline GMC
  • Shiny.
Re: Re: UV Protection CC Skulls
« Reply #10 on: Tue, 13 November 2012, 01:31:02 »
Looks better than it did when pure white.
CC take note :)) ;D
WASD V1 - waiting on R4... - MX Brown
KBT Pure - Zinc caps - MX Brown
Cherry G80-1800 ISO WKL - SkiData caps - MX Clear
Offline dirge
« Reply #11 on: Tue, 13 November 2012, 01:32:34 »
That looks better.  It's official, clacks get better with age.  and more importantly USE!
« Reply #12 on: Tue, 13 November 2012, 01:43:14 »
In your situation, yes it does look better with the look of a non-bleached skull. However, a yellowed CC on a snow white board would be a bit off...
I'm just trying to prevent this.
Offline jeroplane
« Reply #13 on: Tue, 13 November 2012, 01:57:02 »
I guess if it came down to it, you could just Retr0bright when it yellowed.
My signature hasn't changed since 2012. I should really update it.
« Reply #14 on: Tue, 13 November 2012, 03:26:43 »
That's the one!
Thank you sir :)
Offline WhiteFireDragon
    • youtube
« Reply #15 on: Tue, 13 November 2012, 04:52:22 »
Looks more natural with the color of old-aged bones.
Offline nntnam
« Reply #16 on: Tue, 13 November 2012, 04:58:32 »
Poor little boy. You'd better sell him to me. :P
P/s: try H2O2 30%. It probably makes the baby white again. I used to do that with my ABS DS. Not sure about cc cap.
░▒▓ KMAC | FILCO MJ2 | HHKB | PHANTOM ▓▒░
Offline SmallFry
« Reply #17 on: Tue, 13 November 2012, 10:25:59 »
I know CC's aren't ABS. So, not sure how they would react. CC has never told us what material his caps are made of.
Offline jil_jil32
  • Tokyo Press <3
« Reply #18 on: Tue, 13 November 2012, 10:31:34 »
CC doesn't know... Only the gnomes know it.
Offline MMB
« Reply #19 on: Tue, 13 November 2012, 10:46:02 »
CC should replace your defective keycap for free.
Offline esoomenona
  • Gnillort?
« Reply #20 on: Tue, 13 November 2012, 10:52:42 »
And send the defective one here. For, like, testing and such...
    • youtube
« Reply #21 on: Wed, 14 November 2012, 04:51:40 »
Now that I think about it, UV is harmful is almost every aspect. You can just see the type of damage it had on plastic. It's no wonder that it can cause cancer after long exposures. So of course, touching that now-defective cap will also give you cancer. Even worst, just looking at it can give you cancer.
Best if you give it to me so I can dispose of it properly.
Offline MMB
« Reply #22 on: Wed, 14 November 2012, 09:57:23 »
It's scientifically proven that people who spend less time in the sun, tend to live longer.
Nerds unite!
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #23 on: Wed, 14 November 2012, 09:59:31 »
It's scientifically proven that people who spend less time in the sun, tend to live longer.*
*if you are a vampire
Offline nntnam
« Reply #24 on: Wed, 14 November 2012, 21:53:35 »
No, send it to me. Mr. Jack misses his old friend  :(
