Author Topic: Guide to mod a full-sized Model M into a "ghetto SSK"?  (Read 10686 times)
  • Live long and prosper
« on: Tue, 13 November 2012, 08:32:22 »
Hey all,
I have a spare Model M that I'm not using that I want to mod into an SSK.  I've just been wondering if there is a guide anywhere that could help me make a "ghetto" SSK.  I believe there used to be a guide on this, and I am pretty sure I remember people doing this before, but I just can't find anything on it.
All help will be greatly appreciated.
Thanks,
-CLiB
P.S.  To the mods/admins, if you feel this thread should be posted in the "making stuff together" sub-forum, feel free to move it.
« Last Edit: Tue, 13 November 2012, 08:34:54 by Computer-Lab in Basement »
tp thread is tp thread
Offline esoomenona
  • Gnillort?
Re: Guide to mod a full-sized Model M into a "ghetto SSK"?
« Reply #1 on: Tue, 13 November 2012, 09:36:41 »
Ooh, I look forward to seeing how this turns out for you.
Offline SmallFry
« Reply #2 on: Tue, 13 November 2012, 10:17:46 »
Kawa should know some stuff... since he is currently the SSK hoarder for his project...:D
« Reply #3 on: Tue, 13 November 2012, 10:26:41 »
CALLING KAWA!!!!
« Reply #5 on: Tue, 13 November 2012, 11:09:29 »
it's a simple mod
http://geekhack.org/index.php?topic=12388.0
Lanx I love you... this is incredibly helpful!  Looks like I know what I'll be doing this weekend...
Offline esoomenona
  • Gnillort?
« Reply #6 on: Tue, 13 November 2012, 11:11:56 »
it's a simple mod
Sweet. If you sanded that even afterward, and then maybe painted it, it could be really nice!
Offline esoomenona
  • Gnillort?
« Reply #7 on: Tue, 13 November 2012, 11:12:37 »
CLiB, make sure to record everything in a build thread.
« Reply #8 on: Tue, 13 November 2012, 11:14:00 »
Will definitely do that.  I'll document the entire process and take a **** ton of pics.
« Reply #10 on: Tue, 13 November 2012, 11:22:53 »
I will most likely have to.  Where can I get the nuts and bolts for a bolt mod?
« Reply #11 on: Tue, 13 November 2012, 12:39:43 »
McMaster-Carr is the place to get bolts.
The come by the 100s, so you will get enough for 2 bolt mods - hooray!
I think that you will be pleasantly surprised at how cheap and fast they are.
The 4th photo is a package of self-tapping screws that are good for the front, where there is a plastic ridge which interferes with the nut.
You can skip them, a pack of 10 costs more than the packs of 100 of the others!
« Last Edit: Wed, 14 November 2012, 08:46:33 by fohat.digs »
- Plato
Offline SmallFry
« Reply #12 on: Tue, 13 November 2012, 12:42:15 »
SCHWING! This is getting better and better!
« Reply #13 on: Tue, 13 November 2012, 12:46:50 »
Thanks fohat.  I'm browsing around their site now, but I'm unsure if I'm looking at the right ones or not... any way you could post a link to the right ones?
Thanks.
Offline wcass
« Reply #14 on: Tue, 13 November 2012, 14:32:25 »
i did this with a model M 122.
http://geekhack.org/index.php?topic=20999.0;topicseen
i'll try to repost the pictures tonight.
Offline wcass
« Reply #15 on: Tue, 13 November 2012, 21:34:36 »
i was unable to modify my old post - not sure why.
so here are the pictures that go with it:
Offline SmallFry
« Reply #16 on: Tue, 13 November 2012, 22:16:53 »
A SSK Unsaver! Nice mod, I had forgotten that you had done that!
« Reply #17 on: Wed, 14 November 2012, 07:33:29 »
Wow, very nice wcass.  Never seen anyone do that with a 122 before...
Thanks so much for all the pics/links guys, this is so incredibly helpful...
And I must also give thanks to Ripster (apparently he's been watching this thread) for showing me some of his guides on reddit, they are also very helpful.
Offline Batmann
« Reply #18 on: Wed, 14 November 2012, 07:49:55 »
That, my good sir, is the hell of an interesting mod!
Someone's gonna have a busy week-end I guess ^^
« Reply #19 on: Wed, 14 November 2012, 07:51:30 »
Well I might start it this weekend, but I won't be able to finish until I get the bolts I need for the bolt mod.  Either way, I'll take a **** ton of pics for you guys.
Offline Batmann
« Reply #20 on: Wed, 14 November 2012, 07:57:46 »
the cutting part looks pretty technical though o.O
« Last Edit: Wed, 14 November 2012, 08:13:23 by Batmann »
« Reply #21 on: Wed, 14 November 2012, 08:08:52 »
That's the only part of this mod that scares the crap out of me.  I hope like hell I don't mangle it up too bad...
Offline SmallFry
« Reply #22 on: Wed, 14 November 2012, 08:11:13 »
Nice part is that M's are cheap and abundant.
« Reply #23 on: Wed, 14 November 2012, 08:26:47 »
Exactly, which is why I am willing to take the risk...
Offline SmallFry
« Reply #24 on: Wed, 14 November 2012, 08:31:49 »
You are a good work poster. Tsk tsk CLiB!
« Reply #25 on: Wed, 14 November 2012, 08:38:37 »
What's wrong with posting at work?  It's not like I have anything better to do at work...
Not the case today though.  I actually have work to do for once!  :eek:
Offline SmallFry
« Reply #26 on: Wed, 14 November 2012, 08:42:45 »
Nothing is wrong with it, 'specially since I'm currently in U.S. History...whoo...
« Reply #27 on: Wed, 14 November 2012, 08:44:53 »
Sorry I did not post a more useful screw order before.
The bottom item, #4, is self-tapping screws that are easier to install at the front row (near the spacebar). You can use nuts and bolts by clipping little notches out of the plastic ridge, or ignore them altogether. It irritates me that 10 of them cost more than 100 of the others. If I remember correctly, there are about 7 in that row, and that 7 would be subtracted from the "50-ish" bolts needed for the whole job.
I think I still have a couple of M-122 carcasses that I scavenged for keycaps that I would sell fairly cheap to someone who wanted to try this.
« Last Edit: Wed, 14 November 2012, 12:19:03 by fohat.digs »
- Plato
Offline The_Beast
  • I like wood ಠ_๏
« Reply #28 on: Wed, 14 November 2012, 08:46:19 »
I was just about to say that you shouldn't be talking cause I know you're in class/school right now
Then again, I am too. AutoCAD class is boring when you've taking 4 years worth of AutoCAD in high school and have a summer job that is entire AutoCAD based
Offline SmallFry
Re: Re: Guide to mod a full-sized Model M into a "ghetto SSK"?
« Reply #29 on: Wed, 14 November 2012, 08:51:26 »
LoL! I know, we are watching a video and I'm thread crapping, productive I know. ^-^
« Reply #30 on: Wed, 14 November 2012, 10:16:59 »
Thanks fohat, that's exactly what I needed.  I'll order those Friday once I get paid...
Offline jkercado
  • Green XM clickclacker
« Reply #31 on: Wed, 14 November 2012, 10:32:26 »
AWESOMENESSS.
Now I know what to do with the extra Model M I have. This, plus change it to USB. Heck yeah!
Ducky 1087XM Green | Unicomp Ultra Classic Black | IBM M4 | 1989 IBM Model M | Genius i200 | Cherry G84-4100 | Microsoft Arc Keyboard
Offline esoomenona
  • Gnillort?
« Reply #32 on: Wed, 14 November 2012, 10:38:07 »
I have a Model M with an Industrial case on the way. Maybe I should chop that mofo up...?
« Reply #33 on: Wed, 14 November 2012, 10:42:19 »
An Industrial Model M?  I wouldn't chop that one up if I were you...
If you want a Model M that you can mod, I still have one of mine for sale if you're interested.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #34 on: Wed, 14 November 2012, 10:42:36 »
No, do it to a non-industrial
Think of the children
Offline esoomenona
  • Gnillort?
« Reply #35 on: Wed, 14 November 2012, 10:43:28 »
I was only kidding about that... And I'm still interested in that board of yours. I just keep getting caught in other stuff... sorry :\
Offline wcass
« Reply #36 on: Wed, 14 November 2012, 10:49:47 »
a chop job like this leaves an ugly scar unless you take care to finish and paint it.
the beuty of the industrial is the color - so if you are going to paint it anyway, use the most common available case and paint any color you like.
« Reply #37 on: Wed, 14 November 2012, 10:52:57 »
Don't worry about it, I've been holding onto it just for you... along with the SiiG MiniTouch if you still want that too.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #38 on: Wed, 14 November 2012, 11:01:12 »
Fancy stuff. :)
SmallFry! <3
Offline jkercado
« Reply #39 on: Wed, 14 November 2012, 13:31:20 »
I think my scale modeling skills will come in handy in this project. :D I can bondo and sand nicely, can even simulate the texture. I also wonder if plastic cement works with the IBM plastic. You know, the very thin, watery cement that actually melts the plastic.
Offline Batmann
« Reply #40 on: Sat, 17 November 2012, 16:55:58 »
How are things going?
Still 10 fingers?
