Author Topic: Just got the Filco Ninja  (Read 2387 times)
Offline GODJOEY
    • Site
« on: Thu, 15 November 2012, 21:22:07 »
Absolutely love this keyboard. I really like my cmstorm also I think I prefer the shape of the filco buttons but both are excellent. Shift first day is a little squeaky so I gotta fix that or will it just go away?
feature=iv&annotation_id=annotation_163685
Re: Just got the Filco Ninja
« Reply #1 on: Thu, 15 November 2012, 21:30:47 »
The squeak might lessen over time, but it is simple to lubricate it, and there are several guides around here on how to do it and what to use.
Offline wetto
  • Brazil's Keyboard Enthusiasts Representative
    • Portuguese Mechanical Keyboard Guide
« Reply #2 on: Thu, 15 November 2012, 21:37:54 »
You can fix that quite easily, but it's weird... The last Filco Ninja I received had the same problem, on the backspace key... Are they not applying oil/grease/whatever they use on the stabilizers?
My collection:
Mice: Logitech G602, CM Storm Recon, CM Storm Spawn, Razer Naga, Ozone Radon Opto, Corsair M60, Tesoro Gandiva, CM Storm Alcor, Mionix Naos 8200.
Keyboards: Matias Secure Pro, Matias Mini Quiet Pro, custom modded Metadot Das Keyboard Model S Professional Silent (MX Brown, Costar), CM Storm Trigger (MX Brown), Noppoo Choc Mini (MX Red), Tesoro Lobera G5NFL Supreme, CM Storm Devastator.
Soon: CM Storm Quick Fire TK (MX Brown), CM Storm Trigger Z.
Boards I don't own anymore: CM Storm Quick Fire Rapid (MX Black), Logitech K800 (Membrane), Logitech G710+ (MX Brown), Thermaltake Meka G-Unit (MX Black), Corsair K70 (MX Red).
Mice I don't own anymore: Logitech G9x MW3, Corsair M65, Logitech G700, Roccat Kone Pure.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #3 on: Thu, 15 November 2012, 22:50:46 »
All new Kbs are  like that. you can lube em, if they dont go away.
SmallFry! <3
Offline Hyde
  • White Tofu Extraordinaire
« Reply #4 on: Thu, 15 November 2012, 23:10:15 »
I heard they only lube spacebar, and only wasd keyboards lube all stabilized keys.
Offline daerid
    • Rossipedia
« Reply #5 on: Thu, 15 November 2012, 23:56:36 »
I've had to lube all my Costar boards. Comes with the territory. A $5 tube of Lithium grease goes a long way.
Offline stingrae
« Reply #6 on: Fri, 16 November 2012, 00:39:32 »
Also had to lube my ninja (just recently) as backspace was squeaky (I don't use it much due to colemak). While not yet had to lube my cm storm, just luck of the draw it seems. Anyway removing stabilizer key wasn't even hard, just fiddly.  Love the keyboard, although somehow the space bar is dead silent compared to my noppoo and cm storm which both seem to 'clatter' for lack of a better word.
Filco Ninja Tenkeyless  -Noppoo Choc Mini - Cm Storm Quickfire Rapid
Offline GODJOEY
    • Site
« Reply #7 on: Sat, 17 November 2012, 00:09:57 »
Thanks I'll find the tutorial on here so far it kind of stopped squeaking I been playing black ops 2 like mad on it and it's working GREAT!
