Author Topic: HHKB Pro 2 DIP switch option  (Read 2956 times)
Offline OrpheusX
« on: Mon, 19 November 2012, 12:45:20 »
So I just placed an order for a KBT Pure having learned I could use the Fn just to the right of the space bar in conjunction with the O, K, L, and ; as arrow keys. Now I'm wondering re: the HHKB Pro 2 if can set the right (and only the right) Meta key to act as a Fn key (via the DIP switches.) This would let me use my thumb to access the arrow functions on the ;, ', [, and ? keys instead of my poor pinky (on the right Fn.)
Any HHKB owners do this or know if it can be done?
Cheers!
« Last Edit: Mon, 19 November 2012, 17:00:05 by OrpheusX »
Offline OrpheusX
Re: HHKB Pro 2 DIP switch option
« Reply #1 on: Wed, 21 November 2012, 07:40:25 »
Nobody knows? Nobody cares?  :'(
Offline whiskerBox
« Reply #2 on: Wed, 21 November 2012, 08:34:42 »
I don't think you can do that
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #3 on: Wed, 21 November 2012, 09:28:05 »
Offline OrpheusX
« Reply #4 on: Wed, 21 November 2012, 14:56:46 »
http://elitekeyboards.com/products.php?sub=pfu_keyboards,hhkbpro2&pid=pdkb400b
Look at the chart there
Heh, that's actually the chart that made me think there might be a solution. But there really isn't anything there that suggests that the two keys are treated separately. So I think whiskerBox is correct. I am sad.
Thanks to you both.
Offline whiskerBox
« Reply #5 on: Wed, 21 November 2012, 18:59:48 »
I know it seems weird, but making the switch from a poker to an HHKB was very easy and I much prefer the arrow cluster on the HHKB.
