Author Topic: Lower weight MX springs  (Read 2398 times)
Offline Kruen
« on: Sun, 25 November 2012, 06:42:10 »
Hello :)
Do replacement springs for Cherry MX switches such as the Korean ones come in lower forces than the ones normally found in Browns and Reds (45g)? If so, where would I be able to get some from?
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #1 on: Sun, 25 November 2012, 09:00:29 »
Interested too if anyone has a source!
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Lower weight MX springs
« Reply #2 on: Sun, 25 November 2012, 11:46:47 »
sherryton will have some for sell soon. Korean spring is measure on bottom force not actuation force. Red stock spring have about 60 bottom force so Korean 55 or 52 would be actually lighter. I plan to get some of those myself.
Offline jabar
« Reply #3 on: Sun, 25 November 2012, 12:04:18 »
Also, won't going too low in spring resistance force prevent keys from resetting properly? I don't know if anyone has tested the minimum force required.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline daerid
    • Rossipedia
« Reply #4 on: Sun, 25 November 2012, 12:21:37 »
the force just needs to overcome the weight of the stem+cap
Offline Hyde
  • White Tofu Extraordinaire
« Reply #5 on: Sun, 25 November 2012, 12:58:29 »
lol imagine Ergo Red switch, it's like typing on cloud of... air?  Though I'm curious what switch you guys want to put the springs in.
« Reply #6 on: Sun, 25 November 2012, 13:03:48 »
You can for example take the springs completely out of MY switch so only the leaf is left for about 20g and it can reset fine even with heavier Cherry doubleshot. Real light spring will for sure be non issue on linear. Might be a little more of a concern on tactile stem like clear since it have a big hump to overcome on reset. Keycap and stem less than 5g unless you have gold keycap or something.
Offline WhiteFireDragon
    • youtube
« Reply #7 on: Sun, 25 November 2012, 14:29:18 »
I have some 55g springs in my red switches right now. Very light and smooth after lubing it. These may be too light for some people though. When you rest your fingers on the home keys, sometimes that's enough force to press it down. But it just feels great to effortlessly tap it and it actuates. Korean 55g springs + lube job is my personal favorite of all the switches.
Offline AKIMbO
  • HHKBro
« Reply #8 on: Sun, 25 November 2012, 14:34:40 »
55g springs in reds are incredibly light.  The difference between stock reds and 55G Korean spring reds is night and day...the Korean spring variant is much lighter.
| KBD75 (box reds)
Offline remmeh
« Reply #9 on: Mon, 26 November 2012, 19:09:30 »
Where do you obtain korean springs?
Offline TotalChaos
  • Indy Game Coder
« Reply #10 on: Tue, 27 November 2012, 01:58:02 »
Wow!  Thanx for these infos guyz!  I Look forward to trying out a Lite Red keyboard.
Or we could make a CherryRealForce with normal Cherry Red keyboard but these Korean 55 springs under the pinky keys!   :cool:
But I prefer uniform weight.  :)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #11 on: Tue, 27 November 2012, 02:12:31 »
