Author Topic: Tvse keyboard  (Read 2527 times)
Offline AGmurdercore
Tvse keyboard
« on: Thu, 06 December 2012, 17:14:54 »
Hello! I just found some super cheap mechanical keyboards in ebay and i want to ask if anyone of you have heard of them and if they have any opinion if i should risk to buy one of those or not. Thank you, here is the link.
What the hell am I even doing
Tvse keyboard
« Reply #1 on: Thu, 06 December 2012, 18:17:35 »
If those are the same keyboards I'm thinking of, horror stories. I would wait until someone involved in it says something before you buy. I'll try to find the thread.
Hopefully I'm just confusing the keyboard names.
http://geekhack.org/index.php?topic=31954
That's what I was thinking of. Tvs gold, not sure how different tvse are.
Re: Tvse keyboard
« Reply #2 on: Thu, 06 December 2012, 18:32:30 »
Ah thank you i will stay away until someone gives feedback about that.
Offline FoxWolf1
  • 154
Re: Tvse keyboard
« Reply #3 on: Thu, 06 December 2012, 18:36:42 »
Says in the eBay ad, "TVS Gold Keyboard". So probably no or minimal difference.
Offline salmo
    • messmore.org
Re: Tvse keyboard
« Reply #4 on: Thu, 06 December 2012, 22:40:40 »
It's odd too that it says cherry blue switches, but the switches don't have the cherry logo on them in the picture.  Also the keys look pretty worn for "new."
Re: Tvse keyboard
« Reply #5 on: Fri, 07 December 2012, 04:37:23 »
I cant see is there is logo on the switches. but yeah the key caps look shiny from usage.
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Tvse keyboard
« Reply #6 on: Sat, 08 December 2012, 15:31:36 »
Formerly Cherry TVS Electronics of India (Now ZF TVS). They use Cherry MX switch, not fakes as they are a part of Cherry/ZF as well. The build quality is a bit less than the G80 line in general, but they come with really sh!t oem keycap of the cheapest possible type. If you can get one from an honest Indian not a fraud ebay seller they are worth the ~$40 they cost. Even if you don't like the keyboard it is hard to get that many MX switch for less new.
Re: Tvse keyboard
« Reply #7 on: Sat, 08 December 2012, 17:46:14 »
Well if someone have tested this seller and is legit one i might consider getting one of these, but else not because thats kind of too much money for a job less student like me lol
Offline salmo
    • messmore.org
Re: Tvse keyboard
« Reply #8 on: Sat, 08 December 2012, 22:08:37 »
Oh good to know.  I guess my paranoia bit was kicking in.  If it's new, then that's terrible even just for 100+ Cherry MX switches (and hopefully usable stabilizers too).
