Author Topic: IBM Model M Space Saver 87 key idea  (Read 5988 times)
Offline TheRavenDog
« on: Thu, 06 December 2012, 23:51:00 »
Inspired by the success of my IBM Model M 104 modification (see below), I had an idea for an IBM Model M Space Saver 87 keyboard. Here's the idea:
- Start with a IBM Model M Space Saver 84 keyboard
- Separate the barrel assembly from the the back-plate.
- Take a Unicomp Classic 104 (USB or PS/2) and separate the barrel assembly from the back plate
- Cut the number pad off of the Unicomp 104 barrel assembly. Now we have a 87 key barrel assembly.
- Use the back-plate from the 84 space saver
- Use the membrane from the 104 Unicomp classic
- Use the cut-down barrel assembly from the Unicomp classic
- Now comes the tricky part: fold number pad section of the membrane under the back-plate.
- Use the Unicomp USB or PS/2 controller.
If the number-pad-membrane-folding doesn't work, I might try cutting the membrane directly and connecting the row and column lines to the controller with wires.
I'm not quite sure how I can reliably connect wires to the membrane. Any ideas?
What do you all think? Is this crazy? Would people want a 87 key IBM Space Saver?
The IBM Frankenboard Model M:
The dream...                     The reality...
Offline 0100010
  • Not Sure
Re: IBM Model M Space Saver 87 key idea
« Reply #1 on: Fri, 07 December 2012, 08:25:17 »
Folding the membrane would work.  Would imagine you would need to remove the tabs between the Alt / Ctrl keys on the top of the SSK case.
I would never sacrifice an 84 key SSK to get an 87 key SSK though; just too much wrong with destroying an original SSK.
I would cut down a 104 key Unicomp to an 87 key config though.  Just trim and "weld" the case, cut the plate and fold the membrane.
Offline SmallFry
« Reply #2 on: Fri, 07 December 2012, 09:55:54 »
Get a different case first! Its a pretty square label one!
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #3 on: Fri, 07 December 2012, 10:15:55 »
Agree re cutting an original SSK!
But with would it be possible to do a double fold to create a 60% keyboard?
 - Ron | samwisekoi
Offline REVENGE
« Reply #4 on: Fri, 07 December 2012, 14:06:31 »
Sounds plausible, I would fiddle with the membrane first as a feasibility study.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #5 on: Fri, 07 December 2012, 14:26:37 »
 - Ron | samwisekoi
I hope so. I have a fullsized Model M waiting at home waiting to become a 60% over my winter break
