Author Topic: Best Match for off-white SP PBT & ABS  (Read 2864 times)
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« on: Mon, 10 December 2012, 19:04:03 »
As you may know, Matt3o and I are preparing a group buy for Elvish Key Caps. They will be dye-sub printed, so PBT.  The most popular color combo in the IC thread is Green and "Pearl"; really green and off-white.
The problem is that if we go with SP PBT, the spacebar must be ABS.
Does anyone know the best matching color codes for off-white PBT keycaps and ABS spacebars from SP?
Thanks in advance!
 - Ron | samwisekoi
p.s.  Original Thread here:   [IC] Sindarin (elven) set - Group Buy Coming on 14-Dec-2012
