Author Topic: [IC] Phantom Keyboard Assembly Service  (Read 40446 times)
Offline TheProfosist
  • Custom Layouts Only!
« on: Sat, 15 December 2012, 04:01:04 »
This interest check is for a service that will be put on by me (Prof) and MiMiC if interest is great enough. The services offered will be plain assembly, modded switches (ergo clears, getto greens, etc), lubing and stickering. We will also be doing a groupbuy for certain parts for our customers to get better bulk pricing and so there is less intermediate shipping. Things offered might be diodes, resistors, leds, switches, stabilzers, cases, plates, and cables, this all depends on interest.
GB thread opened http://geekhack.org/index.php?topic=38471.0
« Last Edit: Fri, 21 December 2012, 04:18:25 by TheProfosist »
Offline dirge
Re: [IC] Phantom Keyboard Assembly Service
« Reply #1 on: Sat, 15 December 2012, 04:33:49 »
Nice one, be sure to use SMD diodes and invest in a cable bender like litster used for the 7 unit space bars.  Will you offer a cherry or costar stabiliser option?
I loved assembling mine, but if you haven't got the stuff having it done for you is great.
This time round with the phantom it would be good to see the plate designed to be integrated with a case, like the Korean's do.
Thinking about things isn't the same as doing things. Otherwise everybody would be in jail.
Offline netdevil
« Reply #2 on: Sat, 15 December 2012, 06:54:08 »
Awesome Will be looking at this closely! Already been poisoned by the phantom gb :eek:
« Last Edit: Sat, 15 December 2012, 06:58:55 by netdevil »
Offline Sai
« Reply #3 on: Sat, 15 December 2012, 06:57:32 »
i will be in if everything could be bought through you guys. its could cut cost in shipping on many things. :D
« Reply #4 on: Sat, 15 December 2012, 08:16:30 »
Cool.
Offline akuJIWA
  • Lock 'N Load!
« Reply #5 on: Sat, 15 December 2012, 08:23:09 »
Is it possible for me to get equipments only? I would really rather assemble them myself, but finding everything else other than the pcb might be a hassle. Thanks.
The Cheat - B/R/B ; Clear switch with 62g springs
quit
Offline Shadovved
  • King of Stickers (and GBs)
« Reply #6 on: Sat, 15 December 2012, 08:24:14 »
Maybe prof can get some DIY kits rolling like the KMACs where everything is included :D
Offline Sai
« Reply #7 on: Sat, 15 December 2012, 08:34:07 »
^ +1
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #8 on: Sat, 15 December 2012, 10:41:04 »
You already know if I'm innnnnn
« Reply #9 on: Sat, 15 December 2012, 10:50:18 »
Nice of you to offer this. Phantoms are kind of a ***** to build. The diodes are very tedious to place and solder, and the Teensy is very tricky to get done right. I've yet to mod my switches, i.e. lubing and stickering, but I'm sure that will be quite a chore, as well. Mounting the switches to the plate and soldering those to the PCB is a relaxing breeze compared to the rest.
« Reply #10 on: Sat, 15 December 2012, 12:09:47 »
+1 and I've only been doing one Kmac. I wouldn't do it for money. Just so bloody tedious.
Awesome you're doing this prof :)
Offline daerid
    • Rossipedia
« Reply #11 on: Sat, 15 December 2012, 12:17:39 »
Yup. I'm definitely in.
Offline nebo
« Reply #12 on: Sat, 15 December 2012, 13:00:47 »
I'd be in for at least building, not sure about switch modding yet.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #13 on: Sat, 15 December 2012, 13:02:05 »
I would probably be interested in this because soldering diodes is difficult right? That and I can be lazy, and after my full ergo clear mod to my FC700R that took probably 4 hours total I really appreciate the work involved in offering a service like this.
Offline Leewei
« Reply #14 on: Sat, 15 December 2012, 16:48:25 »
Interested! gogo!
Filco Majestouch 2 Beige TKL with MX Reds
Qsenn dt-35
Offline TheQsanity
  • SmallFry Lovin'
« Reply #15 on: Sat, 15 December 2012, 20:10:04 »
Maybe.... Not sure if I could make it myself ><.
SmallFry! <3
« Reply #16 on: Sat, 15 December 2012, 21:38:05 »
and thats why this interest check was started
Offline Permeability
« Reply #17 on: Sun, 16 December 2012, 18:27:37 »
any possibility of you guys assembling GH60's once those are ready too?  :))
Keyboards:
'The Cheat' - lubed 62g Clears
Ducky Shine 3 TKL lubed 45g Reds (Work)
« Reply #18 on: Sun, 16 December 2012, 20:34:33 »
yep just talked it over with MiMic hopefulyy a IC check thread for that should be popping up soon.
« Last Edit: Sun, 16 December 2012, 20:37:09 by TheProfosist »
« Reply #19 on: Sun, 16 December 2012, 23:26:34 »
Did anyone ever do SMD diodes on a Phantom as I have not heard of anyone doing that. I will be using Cherry Stabilizers preferably and once I find a place that sells plate mount as I have only found PCB mount. yes I would like to see a nice custom case but i dont know if that actually going to happen this time around though I would think it wouuld for the Phantom v2 if that ever happens.
Offline Shadovved
« Reply #20 on: Sun, 16 December 2012, 23:31:52 »
Hey prof, maybe you didnt see this, but some of the people are looking for smth like this :D
Maybe to address some concerns?  :)) :))
« Reply #21 on: Sun, 16 December 2012, 23:36:02 »
I dont plan to run a GB for all of the parts separately as the sorting for the amount of people expected to be in the GB would be a very large amount and ive only hear horror stories from the last GB. Also everything should be readily available ill just be buying in larger quantities hopfully.
« Reply #22 on: Sun, 16 December 2012, 23:37:27 »
this was done last GB ans was reportedly hell so im really not so interested in doing that...
« Reply #23 on: Sun, 16 December 2012, 23:45:24 »
Thanks for then props guys. Once you know how to do most of this stuff it really isnt all that hard (personal feeling) but it is mighty tedious and takes a fair bit of time especially when done right.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #24 on: Mon, 17 December 2012, 00:59:24 »
Seems like you got everything organized and lots of experiance in distributing part of the gb as well.
SmallFry! <3
Offline bpiphany
« Reply #25 on: Mon, 17 December 2012, 02:00:26 »
One of the large problems with sorting components for the previous group buys was that we got the diodes in bulk (loose one by one) rather than on tape. With tape it is pretty quick to just measure out the correct amount with a ruler and cut. Since diodes are very very cheap when bought in quantities my suggestion would be that they are included in the PCB group buy. Other than diodes only switches and a Teensy is needed. And a few resistors and LEDs, but since people are going to want different colors and with that different resistors, this would be a chore to include.
Re: Re: [IC] Phantom Keyboard Assembly Service
« Reply #26 on: Mon, 17 December 2012, 02:16:20 »
thanks for the insite bpiphany
Offline t2russo
« Reply #27 on: Mon, 17 December 2012, 02:25:19 »
In on this and the GB thread for the Phantom
Offline Dgsbllx
« Reply #28 on: Tue, 18 December 2012, 15:04:52 »
Tempted to go for it myself but can't decide yet, but as others have said I am definitely down for making up the numbers in bulk purchasing! Slightly off topic, but do we need the Teensy 2 or the 2 with pins?
Cheers for running this service! (if there is enough interest)
« Reply #29 on: Tue, 18 December 2012, 15:09:46 »
yea ill gets teensys also if the Gb doesnt have them with the PCBs, sorry I didnt include that.
Offline Leewei
« Reply #30 on: Tue, 18 December 2012, 15:36:29 »
oOo. So this would basically be the complete thing right? =D
Qsenn dt-35
« Reply #31 on: Tue, 18 December 2012, 15:37:24 »
yes
Offline iArson
« Reply #32 on: Tue, 18 December 2012, 15:54:29 »
Interested and have a man crush on you for the awesome idea.
Offline Leewei
« Reply #33 on: Wed, 19 December 2012, 11:34:39 »
I haven't see any phantoms that are winkeyless layout. Would that be a possible option?
Qsenn dt-35
Offline esoomenona
  • Gnillort?
« Reply #34 on: Wed, 19 December 2012, 11:41:06 »
Just don't put that switch in when you build it.
Offline Leewei
« Reply #35 on: Wed, 19 December 2012, 11:45:18 »
I see. I guess the only thing left is the casing itself. =)
Qsenn dt-35
« Reply #36 on: Wed, 19 December 2012, 16:40:17 »
we are planning to have that as well.
Offline Leewei
« Reply #37 on: Wed, 19 December 2012, 16:53:06 »
Prof you so cool man. <3
Qsenn dt-35
Offline Rendom
« Reply #38 on: Wed, 19 December 2012, 17:12:39 »
Can I know how much to buy the service?
QFR - MX Blue
« Reply #39 on: Wed, 19 December 2012, 17:16:18 »
working on it GB thread should be up soon.
Offline Rendom
« Reply #40 on: Wed, 19 December 2012, 17:51:55 »
Alright!  ;D
QFR - MX Blue
Offline SmallFry
« Reply #41 on: Wed, 19 December 2012, 17:58:20 »
If you get too bogged Prof, I'll help.
« Reply #42 on: Wed, 19 December 2012, 18:13:27 »
been trying to talk to yo uabout that but you no respond on GTalk or IRC...
Offline okooko
  • afk.
« Reply #43 on: Wed, 19 December 2012, 18:20:10 »
Interested in this =P
Will see how GB details go and how international logistics go
Offline Amarok
« Reply #44 on: Wed, 19 December 2012, 19:15:11 »
Very interested, just put in an order for the PCB GB.
Realforce 87u 55g
Offline reverkiller
« Reply #45 on: Wed, 19 December 2012, 19:24:45 »
Is there any chance we can learn about where you're getting your cases from?
I have everything worked out but casing, and I was hoping to get that from somewhere.
« Reply #46 on: Wed, 19 December 2012, 19:46:56 »
well until there is a better option its probably going to be a PLU-87...
Offline Leewei
« Reply #47 on: Wed, 19 December 2012, 20:44:49 »
Would it be too difficult to get an aluminum casing similar to those korean customs?
Qsenn dt-35
« Reply #48 on: Wed, 19 December 2012, 20:55:27 »
yes as there is nothing designed yet
Offline netdevil
« Reply #49 on: Thu, 20 December 2012, 02:07:57 »
I supposed that I have to still put in my order for the phantom pcb gb still even though I have expressed interest here?
