Author Topic: dye PBT key caps  (Read 8177 times)
Offline hluo87
dye PBT key caps
« on: Tue, 18 December 2012, 00:03:32 »
hi
after reading lots of posts..i found that rit dye does not work very well
as pbt caps require DISPERSE DYES, i found this website
http://www.prochemicalanddye.com/home.php?cat=401
does anyone try this before?
Offline MMB
Re: dye PBT key caps
« Reply #1 on: Tue, 18 December 2012, 00:13:50 »
Offline hluo87
« Reply #2 on: Tue, 18 December 2012, 00:26:04 »
http://geekhack.org/index.php?topic=35444.0
Good information there
thanks man.
i checked.... i plan to dye my caps rainbow :cool:
idye is not prefer neither... i want to find a better one in U.S.
i just order one sampler...lets see how it goes :p
Offline hluo87
dye PBT key caps
« Reply #3 on: Fri, 21 December 2012, 20:39:31 »
here it is
first try with blue
pretty good i guess
« Reply #4 on: Fri, 21 December 2012, 20:46:14 »
here it is
first try with blue
pretty good i guess
Is that with the disperse dye? I like how dark they went. You planning on doing more colours? Interested in seeing the progress. Especially if you do a dark purple :)
Offline hluo87
« Reply #5 on: Fri, 21 December 2012, 23:06:20 »
here it is
first try with blue
pretty good i guess
yeah, i will do more colors
finally i will do rainbow
lol
Offline hluo87
dye PBT key caps
« Reply #6 on: Fri, 21 December 2012, 23:07:00 »
better one
Offline TotalChaos
  • Indy Game Coder
« Reply #7 on: Fri, 21 December 2012, 23:47:25 »
How did you put legends on dyed keycaps?!?  :eek:   :cool:
Offline MissMurd3r84
  • In IRC wondering why Kmiller8 is yelling.
« Reply #8 on: Sat, 22 December 2012, 00:27:30 »
Taking a guess here, but I assume the keys already had legends on them before they dyed them..
KBC Poker - Red switches. Noppoo Choc Mini - Black switches. Leopold FC700R (White) - Blue switches. Ducky YOTD - Brown switches. Razer BW - Blue switches and rusted.
Offline hluo87
dye PBT key caps
« Reply #9 on: Sat, 22 December 2012, 00:31:07 »
you are right w8 for the sampler shipping
Offline TotalChaos
  • Indy Game Coder
« Reply #10 on: Sat, 22 December 2012, 00:44:26 »
I don't understand..  :confused:
If there were legends...
And u soaked the key in diffusion dye...
Then the legend would disappear, right?
I feel like such a n00b.  :-[
