Author Topic: [IC] $10 Topre Keychain  (Read 72819 times)
Re: [IC] $10 Topre Keychain
« Reply #50 on: Sat, 29 December 2012, 13:19:44 »
Reaper has one of those realforce topre keychains. Maybe he can tell how it was made? I believe those are acrylic as well.
From what I've seen, they have a special (clear) switch housing. Probably a better idea is to copy the mrinterface ones from the DT switch try bag which are, I believe, just topre switches screwed to a small piece of acrylic. (2 screws if memory serves.)
Offline TheQsanity
  • SmallFry Lovin'
« Reply #51 on: Sat, 29 December 2012, 20:55:38 »
ooh clear bottom and spring view... sexi!
SmallFry! <3
Offline nullstring
« Reply #52 on: Sat, 29 December 2012, 21:00:05 »
in for one or three
Offline daerid
    • Rossipedia
« Reply #53 on: Sun, 30 December 2012, 01:42:36 »
Count me in for at least one, for sure
Offline cgbuen
    • cgbuen.io
« Reply #54 on: Sun, 30 December 2012, 02:10:59 »
Interested in one as well!
Offline TheGrey
« Reply #55 on: Sun, 30 December 2012, 18:26:50 »
..i'm in!
Offline longweight
  • philanthropist
« Reply #56 on: Sun, 30 December 2012, 18:28:59 »
These are OEM springs or something from another company?
These will be OEM springs/rubberdomes from a Topre Realforce board.
It's the rubber dome not the spring that decides the weight of the switch.
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
« Reply #57 on: Sun, 30 December 2012, 18:35:57 »
yes
Offline tsangan
  • 1000/600
« Reply #58 on: Sun, 30 December 2012, 18:41:09 »
I'll be in for 1-3
These will be keychains right? I'm still using my official one with my keys but in case it breaks i want backups ;o
Keyboardless
Offline kmiller8
« Reply #59 on: Sun, 30 December 2012, 18:58:05 »
I'll be in for 1-3
yes. these will be keychain-ish :)
I should be getting in some prototyping stuffs next week, I'll try to put up some designs ASAP!
« Reply #60 on: Mon, 31 December 2012, 00:28:45 »
oh, incase it wasn't clear from my previous post, I'm interested in one at least.
I was considering doing this myself, but then I got lazy. Thanks for having the wherewithal to finish such an endevour.
Edit: Oh look, page #2
Offline kmiller8
« Reply #61 on: Mon, 31 December 2012, 19:40:10 »
Good news everyone.
I have gotten in three topre switches+ stems/housings and I'll try to see if I have any spare plexiglass I can manually work into some designs tomorrow, but we'll have to wait until Wednesday when more stores are open to get into the real fun part :)
Offline HolidaySHRIMP
« Reply #62 on: Tue, 01 January 2013, 00:24:52 »
If you guys need any close ups of measurements of my rf keychain let me know.
Offline kmiller8
« Reply #63 on: Tue, 01 January 2013, 00:33:22 »
Thanks for the offer, but the way the housing is, it's as simple as cutting a piece of plexi to the right shape/size and screwing it in, but I'm looking into some ways to make each switch unique :x
like I said, I'll keep everyone updated with what crazy and magical ideas I come up with :))
Offline noir
« Reply #64 on: Wed, 02 January 2013, 12:15:37 »
definitely interested!
Offline kmiller8
« Reply #65 on: Wed, 02 January 2013, 17:06:36 »
This little topre housing looks scared
https://www.dropbox.com/s/i9zhkmglqpb8i4s/2013-01-02%2017.04.01.jpg
I plan on live streamin sometime later, so we can all find out just how hard casting resin is :P
STREAM LINK: ~~~~DONE~~~~
« Last Edit: Wed, 02 January 2013, 20:01:58 by kmiller8 »
Offline esoomenona
  • Gnillort?
« Reply #66 on: Wed, 02 January 2013, 17:07:18 »
Shoot, gotta get home!
Offline kmiller8
« Reply #67 on: Wed, 02 January 2013, 18:47:02 »
derp de derps, stream time, lets try not to break anything o.o
EDIT: Done for now, I'll put out  a pic of what monstrousity I created in ~24h when it's done curing :P
« Last Edit: Wed, 02 January 2013, 20:02:25 by kmiller8 »
Offline kmiller8
« Reply #68 on: Thu, 03 January 2013, 17:23:17 »
Well.... the results are in!
Oatmeal Jizz turns out to be a bad molding material :)
I've ordered some silicone rubber, once that gets in, we'll try again to make a better mold!
However, this resin worked amazingly in degassing itself o.o there are no bubbles throughout the resin, just along the oatmeal outer surface. And as expected, the mold shrunk, the topre housing measures in at .55 inches, our ****ty molded resin cast came out to be .59 inches. I'm hoping the silicone will yield better results... until then, I'll get off my lazy butt and try to get some acrylic fitted to the bottom of this thing... maybe.
Offline chongyixiong
« Reply #69 on: Sun, 06 January 2013, 20:08:05 »
Definitely interested in two, or more.
Offline kmiller8
« Reply #70 on: Tue, 08 January 2013, 15:00:23 »
Silicone rubber is in, not sure if I'll stream it, since I'll be doing it oustide, and that will require me to drag all my stuff to the garage, where there isn't wifi, and yadda yadda yadda.
The rubber should take 24h, so this is what's going to happen. I'm going to get home today, 1h, i'm going to not do anything for a few hours, 3h, I'm going to cast the first rubber mold, 24h to cure, cast the second rubber mold, 24h to cure, then try to cast the final part in resin, 24h. So hopefully.... I'll have the first decent custom topre housing casted by friday evening :D:D
Also, the semester starts next wednesday, so I'll try to check what kind of access I can get to that plexiglass cutter, and try to get something cut to attack to my mold.
Offline damorgue
    • Personal portfolio
« Reply #71 on: Tue, 08 January 2013, 15:08:19 »
I felt that the ones included in the switch try bags were a bit off. Ensuring that they are made in a way that properly replicates the original switches in mounting distances and feel is probably a good idea.
Offline kmiller8
« Reply #72 on: Tue, 08 January 2013, 15:32:41 »
Hmm... I've never tested a realforce board before so I won't be able to tell if they feel off :/
Honestly, they'll probably feel the same as the switch try bag unless I end up doing something radically different?
Offline aesthetics1
« Reply #73 on: Tue, 08 January 2013, 17:52:13 »
In!
Home: Filco Majestouch TKL MX Red | Work: Ducky Shining (Blue LED) MX Black | Collection: CM Quickfire Rapid MX Red
« Reply #74 on: Tue, 08 January 2013, 22:44:27 »
Offline kmiller8
« Reply #75 on: Tue, 08 January 2013, 22:48:10 »
http://geekhack.org/index.php?topic=39001.0
 :eek: :eek: :eek:
You get the dyesub realforce cap, totally worth it!!!
E: Oh also, Part 1/3 of our casting round two http://imgur.com/a/X6gXj !!!
« Last Edit: Tue, 08 January 2013, 22:50:32 by kmiller8 »
« Reply #76 on: Tue, 08 January 2013, 23:05:17 »
If yours turn out even half as good as these, they will be totally worth it :)
Offline FabsSpeed
« Reply #77 on: Wed, 09 January 2013, 00:11:03 »
In for 2
| Wanted: KMAC  & KMAC 1.2, 356 Mini, 456 GT |
Offline missalaire
  • Great Finder of Great Finds
« Reply #78 on: Wed, 09 January 2013, 00:20:31 »
I'd probably be interested in one or two. I've always been curious to know what the Realforce switches are like.
Offline kmiller8
« Reply #79 on: Wed, 09 January 2013, 17:32:02 »
Day 2. http://imgur.com/a/KnOOp
The mold was a bit bubbly on the top, but where it mattered it seemed to be bubble free
Second part of mold is curing, tomorrow, we cast our first part!
E: as shown, I used ~100g for the entire mold, which is pretty cool I guess.
Offline el2k
« Reply #80 on: Wed, 09 January 2013, 20:31:28 »
THIS ONE GONNA BE BETTER YEAH
sc00pz for life
« Reply #81 on: Wed, 09 January 2013, 23:18:19 »
I hope these aren't better only because I paid full price for the RF one and don't even use the RF cap. Hehe
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #82 on: Fri, 11 January 2013, 06:53:24 »
My body is ready and willing for at least one of these. Eagerly awaiting the next set of pictures. Maybe when this concludes I'll finally get to see what topre feels like.
Offline kmiller8
« Reply #83 on: Fri, 11 January 2013, 07:33:49 »
Don't hold your breath for the next set of pics... lets just say there were... complications with the mold, and it's in pretty bad shape, I'll have to re-make it :)
Offline linkz
« Reply #84 on: Sat, 12 January 2013, 08:47:55 »
 :eek: :eek: :eek:
I'm interested in getting one. Not that $60 realforce keychain though, lol.
Offline insomnesia
« Reply #85 on: Mon, 14 January 2013, 22:35:34 »
i'm in for a lot  :)
Offline Preach
  • The Insane
« Reply #86 on: Thu, 17 January 2013, 02:49:05 »
Looking forward to see progress on this. Interested
QFR - Browns |
Offline kmiller8
« Reply #87 on: Thu, 17 January 2013, 18:51:10 »
progress will be super slow on this one, I have too many other projects going on right now, and the school semester started, If i can get some free-time I'll try my darndest to get one prototype made this weekend :)
Offline kmiller8
« Reply #88 on: Fri, 18 January 2013, 10:25:42 »
THREAD'S OVER GUYS! MrInterface beat me to the punch!
« Reply #89 on: Fri, 18 January 2013, 11:31:25 »
It's ok, you can still do it!!
Offline TheQsanity
  • SmallFry Lovin'
« Reply #90 on: Fri, 18 January 2013, 15:20:23 »
He's got eu, you can get na!
SmallFry! <3
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #91 on: Fri, 18 January 2013, 23:09:10 »
Just because he posted a how-to doesn't mean it is over. I don't have access to a topre switch housing, rubber, and spring. You need to hook us up!
« Reply #92 on: Fri, 18 January 2013, 23:15:10 »
I have one of the switch testers coming to me, I'll see how well it would work as a keychain :D
Offline kmiller8
« Reply #93 on: Fri, 18 January 2013, 23:46:47 »
:o you got into the Round 3?
« Reply #94 on: Fri, 18 January 2013, 23:48:04 »
Snagged last spot! Almost backed down after I saw the cost, but I must try all the switches! And perhaps model m/f keychain swag.
« Reply #95 on: Sat, 19 January 2013, 18:38:09 »
He doesn't exactly explain where to get the Topres switches from, nor the clear plastic base, nor the rubber bit either.
Having a drill press would make it easier, but with a steady hand you could mount the housing in a vise and use a hand drill.
For anyone to attempt this we'd probably need to start by buying a Topre keyboard ...
Offline Shadovved
  • King of Stickers (and GBs)
« Reply #96 on: Sat, 19 January 2013, 19:53:43 »
Aw, have we not invented the way to get these keychains yet? ;D
« Reply #97 on: Sat, 19 January 2013, 19:54:13 »
Buy me a topre board shad, I'll figure it out for you hehe....orrrr just have a shiny new topre :D
Offline Shadovved
« Reply #98 on: Sat, 19 January 2013, 19:58:54 »
I should be grabbing a topre keychain, not confirmed whether its original or improvised, soon ;D
« Reply #99 on: Sat, 19 January 2013, 20:00:33 »
The blue/red ones that are big $$$?
