Author Topic: Tenkeyless with Alps Black (or similar)  (Read 3467 times)
Offline daerid
    • Rossipedia
« on: Sun, 23 December 2012, 15:10:41 »
Do they exist?
Since receiving the AT101 from Akimbo's tour, I've rediscovered my love for these switches. However, I'm not a fan of the huge footprint. Is there a board out there in the tenkeyless form factor with Alps black switches (or equivalent)? I can't say I've ever seen one, but that doesn't mean they don't exist!
Now that I think about it, this might be a good idea for a custom pcb mod project too
Offline absyrd
  • CPT HYPE PADAWAN
Offline FoxWolf1
  • 154
Re: Tenkeyless with Alps Black (or similar)
« Reply #2 on: Sun, 23 December 2012, 16:04:36 »
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #3 on: Sun, 23 December 2012, 16:19:03 »
http://www.mechanicalkeyboards.com/shop/index.php?l=product_detail&p=89
Not the same black Alps, though...you'll have to swap them.
Actually, I think what he's looking for is the Black<->White. The newest Fuhua Whites should be about the same as the Alps Blacks. (UP94-95/BB2 is simplified so Fuhua should feel about the same.)
Problem is that the only Fuhua White board I know of is the Matias Tactile. Nothing against Matias, it really seems like a great keyboard, but it's not what I'm looking for and I wish they'd not have eaten the entire supply of Fuhua Whites to make 'em. :(
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline pasph
Offline daerid
    • Rossipedia
« Reply #5 on: Sun, 23 December 2012, 21:45:44 »
I thought the 1087's were dogsh*t in terms of build quality though?
Offline Hak Foo
  • Make America Clicky Again!
« Reply #6 on: Sun, 23 December 2012, 23:53:32 »
I don't know what everyone is doing with their Duckies, but my 1008XM has been solid since arrival, as has the blue-Cherry 1008 I took to work.  The latter has a case-not-snapped-together-exactly thing going on, but it in no way affects functionality and could well have happened in shipment.
Maybe it's a silent-upgrade thing as their manufacturing or supply chain improves?  I do notice the keycaps on the Cherry 1008 were MUCH nicer than the ones on the 1008XM-- the laser etching being bright and legible instead of dim and faded.  Sadly, they only lasted long enough to be pried off for a CC&G set.
Overton130, Box Pale Blues.
Offline daerid
    • Rossipedia
« Reply #7 on: Mon, 24 December 2012, 00:07:44 »
Well, I ended up ordering a 1087XM w/ black alps (type IV) from mechanicalkeyboards.com
Only $50, and I can write it off, so why not. We'll see how it turns out.
Offline daerid
    • Rossipedia
« Reply #8 on: Mon, 24 December 2012, 00:15:05 »
Will do! Kind of excited about :)
Offline Burz
  • maybe get a blister on yo' little finger...
« Reply #9 on: Mon, 24 December 2012, 00:43:16 »
Oh boy... I hope it's better than what I've heard. Good luck!
And while you're at it, can you make a direct comparison with the Dell AT-101W you got from Akimbo?
If the Ducky is a disappointment and you still have your heart set on a TKL board, you could look for a Filco Zero. Beyond that, there are compact boards like the SMK85 and SiiG MiniTouch.
...As usual, typed on a Dell AT-101W.
Matias Mini QuietPro  \\ Dell AT101W - Black ALPS  \\ SIIG MiniTouch x2 White XM - Monterey  \\ Colemak layout.
Offline rootwyrm
    • My Website!
« Reply #10 on: Mon, 24 December 2012, 00:50:40 »
Then go find PBT keycaps for Alps so I can actually order one and not have to replace the whole thing every 3-4 months. ;)
Offline daerid
    • Rossipedia
« Reply #11 on: Mon, 24 December 2012, 01:02:42 »
@Burz: Yeah, for sure. I thought the Filco Zero was based on the Alps White (the clicky one)? I don't think I could handle the clicky alps. I like the feel of blacks too much (although I might just remove the tactile leaf on the 1087 when it gets here.. love that smooth buttery feel).
@rootwyrm: For some reason, shinyness never bothered me on my AT101Ws, so we'll see how the Ducky holds up.
Offline rootwyrm
    • My Website!
« Reply #12 on: Mon, 24 December 2012, 01:37:07 »
Problem isn't shine as much as destroying them. Grooving, peaking, complete annihilation of raised bumps, the works.  Anything short of the thick doubleshots does not last 6 months against my typing. The current Costar 'value' (i.e. not cheapest) ABS keycaps don't even last two months.
Offline daerid
    • Rossipedia
« Reply #13 on: Mon, 24 December 2012, 01:56:47 »
Damn. What are you doing? Pretending your fingers are jackhammers?
Offline Burz
« Reply #14 on: Mon, 24 December 2012, 04:08:36 »
You would have to replace the switches on the Zero, but at least the result will be a good quality TKL with the switches you want.
Offline AKIMbO
  • HHKBro
Re: Re: Tenkeyless with Alps Black (or similar)
« Reply #15 on: Mon, 24 December 2012, 07:26:10 »
My zero with complicated oranges is one of my favorite boards.  Matias filed an application with the FCC for a tenkeyless alps board.   The pics are out there if you look hard enough.  Just buy the Matias tkl when it comes out and solder in some real black alps.
| KBD75 (box reds)
Offline daerid
    • Rossipedia
« Reply #16 on: Mon, 24 December 2012, 13:31:06 »
I don't think I could do that, as I don't really care for the Matias TKL look (I've seen the pictures). There's too much extra space. If the 1087XM satisfies, then I'll be good to go.
Offline rootwyrm
    • My Website!
« Reply #17 on: Mon, 24 December 2012, 14:46:55 »
Three big things. One, 20+ years on buckling spring or other >70cN switches. And I bottom those out, so you can imagine what I can do to anything <60cN. Two, I type. A lot. Over 450 keystrokes per minute, 12-16 hours per day, on the same keyboard. So more than 90% of it is actually just normal wear and tear - compressed into a very short timeframe. Three, ABS keys just aren't nearly as sturdy as PBT, and I need that sturdiness.
I mean honestly, it's not just ABS that gets worn out. IBM PBTs also wear out, but they take a lot, lot longer - usually 1 to 3 years depending on batch and type versus 2 to 3 months to give you an idea of how tough dye-sub PBT can be made. (Remember that I'm impacting these keys with a lot of force and I also rest both hands on the keyboard so there's gradual friction wear as well.) And $30-50 every 2 years to extend the life of a working frame is a lot more tolerable than having a ton of essentially useless keyboards laying around just because the keycaps are toast.
Offline Burz
« Reply #18 on: Mon, 24 December 2012, 18:56:00 »
@rootwyrm:   YOU. Are. A. BEAST!!!
LOL!
Offline TwistedMentat
  • It is by will alone I set my mind in motion.
« Reply #19 on: Mon, 24 December 2012, 19:24:32 »
Each one of his fingers must be like a tiny Chuck Norris.
