Author Topic: Left Alt malfunctioning  (Read 9337 times)
Offline theultrazord
« on: Fri, 28 December 2012, 18:41:19 »
Many people have reported that a certain batch of QFRs have a malfunctioning left alt. My QFR's left alt works when used alone however when used in conjunction with tab or ctrl+del it does not work. Is CM offering RMAs for malfunctioning keyboards and/or is there a quick fix that can be performed?
Re: Left Alt malfunctioning
« Reply #1 on: Sat, 29 December 2012, 02:07:42 »
Offline CM-Rajiv
  • CM Storm Rep
  • * Moderator
« Reply #2 on: Mon, 04 February 2013, 17:18:04 »
Someone created a guide to fixing the solder point (which is the root of the issue)...
http://geekhack.org/index.php?topic=39219.0
It's only small batch but still a priority for us to deal with.
Cooler Master USA - CM Storm Marketing Team - [CM Storm Trigger CherryMX Green Switch]
