Author Topic: Soldering opinion -- Rosewill RK-9100  (Read 2520 times)
Offline jamdox
« on: Sun, 30 December 2012, 22:12:08 »
Hey folks,
Got an RK-9100 backlit keyboard and I was wondering how its internals look.  I couldn't get a great picture because I didn't want to void the warranty and it has a screw sealed, but I was able to get the following:
11002-0
Looks OK to me, but I'm no expert.
Also, I found that the spacebar made clicking noises; is this normal with Cherry stabilizers?
« Last Edit: Sun, 30 December 2012, 22:15:36 by jamdox »
AEKII
Ducky Shine II w/ Clears
NMB RT8256CW+
Offline TotalChaos
  • Indy Game Coder
Re: Soldering opinion -- Rosewill RK-9100
« Reply #1 on: Sun, 30 December 2012, 22:53:48 »
When u press the key down once without releasing it, how many click noises does it make?
When u release the key once, how many click noises does it make?
Offline jamdox
« Reply #2 on: Sun, 30 December 2012, 23:02:47 »
There's one or two on the way down, depending on how quick I push it, and none on the release.  Although it's not consistent; there's sometimes more or less.
EDIT: I should mention it's a browns board...
« Last Edit: Sun, 30 December 2012, 23:30:50 by jamdox »
AEKII
NMB RT8256CW+
Offline TotalChaos
  • Indy Game Coder
« Reply #3 on: Sun, 30 December 2012, 23:29:18 »
You should consider a lube job.
Offline jamdox
« Reply #4 on: Sun, 30 December 2012, 23:31:51 »
I thought those were for squeaks?
AEKII
NMB RT8256CW+
Offline TotalChaos
  • Indy Game Coder
« Reply #5 on: Mon, 31 December 2012, 00:03:31 »
I said consider it, not necessarily do it.  :))
Offline Calade
« Reply #6 on: Mon, 31 December 2012, 13:37:49 »
Rosewills have Costar stabilizers as far as I know.  :) And at least my RK-9000's big keys make some clicking noises when I apply light pressure to them. I believe that it's normal.
Offline nullstring
« Reply #7 on: Mon, 31 December 2012, 14:10:19 »
RK9100 series are made by iRocks not Costar.
Do keyboards not made by Costar sometime feature Costar stabilizers?
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #8 on: Mon, 31 December 2012, 16:02:01 »
Yes, frequently. Remember that Costar is a DESCRIPTION of a stabilizer type and not a brand of stabilizer. Costar styled stabilizers are cheaper to manufacture than Cherry stabilizers. Costar doesn't actually make their own keycaps, so yes, it's not uncommon to find Costar style parts in other manufacturers.
The soldering work on this particular example is okay. I don't see any blatant spatter but the finish looks a bit uneven. Impossible to say what it's really like without opening the whole way and getting good macro shots of various areas.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline jamdox
« Reply #9 on: Mon, 31 December 2012, 19:30:48 »
It's a backlit keyboard, so cherry-style stabilizers.
And I wish I could've opened up the whole thing, but they put a seal on one of the screws.
AEKII
NMB RT8256CW+
