Author Topic: G80-8113HRBUS-2 eBay BIN 45+shipping  (Read 3399 times)
Offline precarious
  • LOOK MOM, I'M A DRAGONZORD! DOOOO DODOODODODOODOO
« on: Tue, 01 January 2013, 22:04:53 »
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Re: G80-8113HRBUS-2 eBay BIN 45+shipping
« Reply #1 on: Tue, 01 January 2013, 22:09:01 »
not a bad deal. Don't those have cherry mx clears?
-Enzo Ferrari
« Reply #2 on: Tue, 01 January 2013, 22:09:41 »
Either clears or browns. No way to tell without getting the seller to remove a keycap. :(
Offline The_Beast
  • I like wood ಠ_๏
« Reply #3 on: Tue, 01 January 2013, 22:13:26 »
Hey I  bought one of those ^___^
Offline SmallFry
« Reply #4 on: Tue, 01 January 2013, 22:35:55 »
Isn't that the only board to have a full touch caps lock that's Filco etc compatible?
« Reply #5 on: Tue, 01 January 2013, 22:43:42 »
I don't know if it's the only one, but it does have it. lysol would know.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #6 on: Tue, 01 January 2013, 22:59:06 »
Nope, spacebar doesn't work bro
everything else does (except the ISO thingy)
Offline SmallFry
Re: Re: G80-8113HRBUS-2 eBay BIN 45+shipping
« Reply #7 on: Tue, 01 January 2013, 23:03:59 »
I meant only the caps lock, I knew the space bar was off center stemmed.
Offline inlikeflynn
  • file not found
« Reply #8 on: Tue, 01 January 2013, 23:32:43 »
yes space bar is full touch center-stem so will work on FILCO
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #9 on: Tue, 01 January 2013, 23:38:26 »
Bottom row is center-stem?  Nice deal.
Offline inlikeflynn
  • file not found
« Reply #10 on: Tue, 01 January 2013, 23:40:17 »
just needs one of your remaining leftover Full Mod kids & a spacebar from else where and good to go :)
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #11 on: Wed, 02 January 2013, 11:37:42 »
Good price for sure. MX-8000 POS series is easiest to find fulltouch caps, but not the only. There is also really old ones from before 1000 series, POS 1000/3000 series winkeyless stuff, etc, etc. But many of these have even more interesting things than simply the fulltouch caps lock.
Not as good of a deal as the one I forgot about to bid on though... lol. There was a pair of G80-8200HUAUS-2 which have true ansi and usb, so congratulations to whoever won those for $40.
« Last Edit: Wed, 02 January 2013, 11:42:22 by lysol »
Offline precarious
« Reply #12 on: Wed, 02 January 2013, 16:04:43 »
yeah, i messaged taht guy about an offer on the other two, then he decided to change it to buy it now while i was asleep, ugh.  i had been watching that listing since he put it up, he changed it three times, f-----
« Reply #13 on: Thu, 03 January 2013, 01:10:02 »
The spacebar on mine won't (Stem (Grey) is under the N). Did cherry put out different spacebars on their G80-8113's?
« Reply #14 on: Fri, 04 January 2013, 10:50:27 »
The size is right 6.25, but no Cherry spacebar stem is always off center on any spacebar smaller than 7x that I have seen so far.
Offline inlikeflynn
  • file not found
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
