Author Topic: Cherry blue, cherry keycaps, non sculpted and tenkeyless ?  (Read 1958 times)
Offline Calcifar
« on: Wed, 02 January 2013, 07:13:39 »
Does this specification exist ?
Can you recommend me good boards which have all of these requirements ?
Offline esoomenona
  • Gnillort?
Re: Cherry blue, cherry keycaps, non sculpted and tenkeyless ?
« Reply #1 on: Wed, 02 January 2013, 09:22:22 »
What do you mean by non-sculpted, if you don't mind my asking?
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #2 on: Wed, 02 January 2013, 09:27:13 »
Do you mean flat? As in there is no curved or slanted profile to the keycaps and board itself?
Offline Calcifar
« Reply #3 on: Wed, 02 January 2013, 12:45:51 »
Yes I ment flat, by which i mean no curve to the key - layout.
Offline Calcifar
« Reply #4 on: Wed, 02 January 2013, 12:59:13 »
bumpidy, still need those recommendations.
If flat is out of the question ill also happily look at curved layout- boards.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Wed, 02 January 2013, 13:03:21 »
There are very few MX boards without scuplted keycap. Deck and G80-3800 spring to mind first, there is other I think... but none tenkeyless that I know of only mini or fullsize. Also Deck don't come in blues.
Blues and tenkeyless is easy if you remove the keycaps requirement.
Offline Calcifar
« Reply #6 on: Wed, 02 January 2013, 13:42:39 »
Alright, so normal sculpted caps but cherry caps with blues at least.
What good boards am i looking at then ?
« Reply #7 on: Wed, 02 January 2013, 14:48:59 »
My main advice is get whichever tenkeyless suit you best price to features, then get nice set of Cherry doubleshots (or dyesub, blank, or laser whatever work for your budget) for it.
Otherwise if you don't want to have to get keycap seperate, tenkeyless board with Cherry profile is not a long list at all, Leopold FC700...
« Last Edit: Wed, 02 January 2013, 14:51:24 by lysol »
