Author Topic: RGB Kits  (Read 12366 times)
Offline aesthetics1
RGB Kits
« on: Wed, 02 January 2013, 23:52:52 »
I recently ordered a set of WASD RGB mods and was unhappy with them. Looking for another set.
Regarding the Hashbaz's RGBY Kit - Does it fit properly on a Filco board?
Also, what is a ballpark estimate of a fair second-hand price on a set?
I haven't run across another white text on rgb mods - if another exists that I'm overlooking I'd appreciate a link :). (PBT, or ABS)
Home: Filco Majestouch TKL MX Red | Work: Ducky Shining (Blue LED) MX Black | Collection: CM Quickfire Rapid MX Red
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
Re: RGB Kits
« Reply #1 on: Wed, 02 January 2013, 23:56:29 »
There was an earlier white text RGB set from a group buy run by aggiejy.  They use the standard SP font though, as opposed to the Cherry replica font used by mbc's and my sets.
The aggiejy sets are typically $20 or $25, though they don't come up for sale very often any more.  I imagine posting a WTB thread would turn some up.
The Cherry replica RGBYs are usually more.  $30-$35 or even $40 is typical, I'd say.
Offline esoomenona
  • Gnillort?
Re: RGB Kits
« Reply #2 on: Wed, 02 January 2013, 23:58:44 »
If you're using the original Filco caps, they will be shorter in height. Aggiejy also had a white on RGB set. His blue was lighter. I think hashbaz had winkey and winkeyless sets. You'd need a winkey set. Someone else might help better with price, but roughly around $25-35 or so.
Offline aesthetics1
Re: RGB Kits
« Reply #3 on: Thu, 03 January 2013, 00:04:32 »
Thanks for the quick replies.
So the Hashbaz is cherry profile and sits a bit lower? That would probably bug me!
I guess I'd probably be after the aggiejy set to fit the profile of the stock Filco keycaps.
Appreciate the help.
Offline esoomenona
  • Gnillort?
Re: RGB Kits
« Reply #4 on: Thu, 03 January 2013, 00:06:58 »
They're both SP profile, which is similar to Cherry profile but with some differences. Either way, both will be shorter than Filco caps. For OEM profile RGB, the only I can think of would be NIQMODS and those won't have legends and will cost you more if you can find.them.
Offline hashbaz
  • Grand Ancient One
Re: RGB Kits
« Reply #5 on: Thu, 03 January 2013, 00:13:22 »
If you need to match the profile of your stock Filco caps, wasdkeyboards.com might be an option.  But the legends won't be white.
Offline SmallFry
Re: Re: RGB Kits
« Reply #6 on: Thu, 03 January 2013, 00:33:55 »
He didn't like the WASD ones Hashbaz. :P
Offline aesthetics1
Re: RGB Kits
« Reply #7 on: Thu, 03 January 2013, 00:39:43 »
Yeah :(. Unfortunately I wasn't really happy with the WASD keycaps. Really looking for white legends and something that matches the profile. Oi!
I might end up having to replace the keycaps, and then add some RGB later, haha.
Offline SmallFry
Re: Re: RGB Kits
« Reply #8 on: Thu, 03 January 2013, 00:41:13 »
Didn't like the aesthetics? (pun intended)
Offline esoomenona
  • Gnillort?
Re: RGB Kits
« Reply #9 on: Thu, 03 January 2013, 00:42:45 »
Oh lawd, it's a veritable punfest tonight.
Offline SmallFry
Re: Re: RGB Kits
« Reply #10 on: Thu, 03 January 2013, 00:44:10 »
Puns are my favorite type of joke, to be honest.
Offline esoomenona
  • Gnillort?
Re: RGB Kits
« Reply #11 on: Thu, 03 January 2013, 00:45:39 »
There really isn't anything like that awkward cheesiness.
Offline SmallFry
Re: Re: RGB Kits
« Reply #12 on: Thu, 03 January 2013, 00:46:50 »
Coming from Wisconsin... EVERYTHING is cheesy. :P
Offline esoomenona
  • Gnillort?
Re: RGB Kits
« Reply #13 on: Thu, 03 January 2013, 00:48:16 »
Eww...?
Offline SmallFry
Re: Re: RGB Kits
« Reply #14 on: Thu, 03 January 2013, 00:49:47 »
Eww...?
Well...maybe not everything. I can see somebody is watching the Spy though:P
Offline esoomenona
  • Gnillort?
Re: RGB Kits
« Reply #15 on: Thu, 03 January 2013, 00:51:09 »
I don't like the Spy. I browse Unread and I always open every thread that has new posts and read them.
Offline SmallFry
Re: Re: RGB Kits
« Reply #16 on: Thu, 03 January 2013, 00:55:23 »
Ah. Well. Well, we thoroughly thread crapped this evening/morning. Twas fun, we shall have to do it again:) I'm off to bed Moose, good night:)
OP, don't mind us... ;)
Offline gameaholic
Re: RGB Kits
« Reply #17 on: Thu, 03 January 2013, 12:31:50 »
Are there any OEM profile white legend doubleshot RGB sets?
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Offline SmallFry
Re: Re: RGB Kits
« Reply #18 on: Thu, 03 January 2013, 12:34:32 »
Doubleshot, no. Auto painted, yes they're called NIWMODS, but they won't come cheap.
Offline nullstring
Re: RGB Kits
« Reply #19 on: Thu, 03 January 2013, 12:38:01 »
I very much doubt it. I am not sure where they would come from.
You folks are probably better off buying a cherry/sp profile keyset first.
Offline esoomenona
  • Gnillort?
Re: RGB Kits
« Reply #20 on: Thu, 03 January 2013, 12:41:06 »
Are there ANY OEM profile DS keys?
Offline SmallFry
Re: Re: RGB Kits
« Reply #21 on: Thu, 03 January 2013, 12:53:09 »
If you count Click Clacks, there are triple shot OEM profile key caps. :)
Offline esoomenona
  • Gnillort?
Re: RGB Kits
« Reply #22 on: Thu, 03 January 2013, 12:54:40 »
Nope!
Offline SmallFry
Re: Re: RGB Kits
« Reply #23 on: Thu, 03 January 2013, 12:57:28 »
Offline hashbaz
  • Grand Ancient One
Re: RGB Kits
« Reply #24 on: Thu, 03 January 2013, 13:00:09 »
He didn't like the WASD ones Hashbaz. :p
fuuuuuuuu I feel like such a noob.  :-[
Offline SmallFry
Re: Re: RGB Kits
« Reply #25 on: Thu, 03 January 2013, 13:02:22 »
Glad I could help. ;)
Offline esoomenona
  • Gnillort?
Re: RGB Kits
« Reply #26 on: Thu, 03 January 2013, 13:03:39 »
Welcome to GH, hashbaz! I hope you enjoy your stay.
Offline SmallFry
Re: Re: RGB Kits
« Reply #27 on: Thu, 03 January 2013, 13:05:47 »
Welcome to WalletHack! :))
Offline hashbaz
  • Grand Ancient One
Re: RGB Kits
« Reply #28 on: Thu, 03 January 2013, 13:09:56 »
Can you guys recommend which switch is the best?
Offline SmallFry
Re: Re: RGB Kits
« Reply #29 on: Thu, 03 January 2013, 13:13:38 »
Brown....err...BLUE....ErgoClear! No... Topre, I can't decide!
Offline esoomenona
  • Gnillort?
Re: RGB Kits
« Reply #30 on: Thu, 03 January 2013, 13:57:13 »
Buckling spring. A mans man switch. Go BS or go dome.
Offline SmallFry
Re: Re: RGB Kits
« Reply #31 on: Thu, 03 January 2013, 13:58:54 »
Go BS or go dome.
I cee waht u did thar! Punny guy...
Offline aesthetics1
Re: RGB Kits
« Reply #32 on: Thu, 03 January 2013, 14:04:30 »
Super cereal derailment. I came back and was like "Wow, tons of replies!.." Psyche. Haha.
/munchpopcorn
Anyway, I'd be happy to take all of your SP white legend RGB kits off of your hands - Woah woah, not all at once. Haha.
Offline esoomenona
  • Gnillort?
Re: RGB Kits
« Reply #33 on: Thu, 03 January 2013, 14:12:05 »
Sorry, OP. I assumed you had already reached the only logical conclusion for someone who wants RGB: buy a Cherry/SP set and mate it with a RGB set in Cherry/SP profile. That left this thread open for the taking!
Offline aesthetics1
Re: RGB Kits
« Reply #34 on: Thu, 03 January 2013, 14:24:51 »
Haha, totally, that's why I was so surprised. lol.
Offline m_enanos
  • tbb
Re: RGB Kits
« Reply #35 on: Fri, 04 January 2013, 05:59:54 »
/munchpopcorn
Pm'ed :D
Offline The_Beast
  • I like wood ಠ_๏
Re: RGB Kits
« Reply #36 on: Fri, 04 January 2013, 06:31:43 »
You mean beery or DYIy or methy or mosts bars per capitay
Offline esoomenona
  • Gnillort?
Re: RGB Kits
« Reply #37 on: Fri, 04 January 2013, 15:20:11 »
Cheese? Mosts bars per capita!? Sounds like my kind of place
Offline SmallFry
Re: Re: RGB Kits
« Reply #38 on: Fri, 04 January 2013, 18:14:44 »
Meeces eat chease? Or is it Mooses?
Re: RGB Kits
« Reply #39 on: Fri, 04 January 2013, 19:55:58 »
MOAR BARS
Offline SmallFry
Re: RGB Kits
« Reply #40 on: Fri, 04 January 2013, 19:59:20 »
You're just stealing that from Boost! :P STEALER!
Re: RGB Kits
« Reply #41 on: Fri, 04 January 2013, 20:16:04 »
Hey SmallFry - nearly at 3000!
Offline reverkiller
Re: RGB Kits
« Reply #42 on: Fri, 04 January 2013, 20:17:50 »
I got almost a full RGB kit with my SP kit, just a Left Shift short (I have an ISO one though...)
I was surprised how much I liked how these looked on keyboards. I would buy another for sure!
Offline SmallFry
Re: RGB Kits
« Reply #43 on: Fri, 04 January 2013, 20:18:52 »
Holy... Seemed like yesterday I was at 2500...
Re: RGB Kits
« Reply #44 on: Fri, 04 January 2013, 20:19:46 »
2964 (5.409 per day) - soon adds up :)
Offline SmallFry
Re: RGB Kits
« Reply #45 on: Fri, 04 January 2013, 20:20:06 »
2965, do your math again! :P
Re: RGB Kits
« Reply #46 on: Fri, 04 January 2013, 20:21:23 »
My copy/paste is temporally challenged.
Offline SmallFry
Re: RGB Kits
« Reply #47 on: Fri, 04 January 2013, 20:38:56 »
Heh. Silly Rowdy... :P
Offline Leewei
Re: RGB Kits
« Reply #48 on: Sat, 05 January 2013, 15:10:30 »
imsto sells an rgby set that has decent colors, you can check that out. It is also cherry font with black legends.
Filco Majestouch 2 Beige TKL with MX Reds
Qsenn dt-35
Offline aesthetics1
Re: RGB Kits
« Reply #49 on: Sat, 05 January 2013, 16:29:33 »
Thanks for the tip. I am looking for white legends though. Another member on the forum actually saw this post and is selling me an SP set.
Thanks for all of the help everyone!
