Author Topic: clear actuation point  (Read 2679 times)
Offline Kruen
« on: Wed, 09 January 2013, 10:19:13 »
Hello Geekhack
I've noticed that cherry mx browns seem to have an actuation point just below the bump, which means that when I hold the key down by depressing it and releasing it to the point where it hits the bump it does not reliably actuate. Do cherry mx clears have this same 'issue'?
Thanks
Offline absyrd
  • CPT HYPE PADAWAN
Re: clear actuation point
« Reply #1 on: Wed, 09 January 2013, 10:23:41 »
How long have you been using them? Took me a bit on browns to get used to "reliably" actuating the keypress without bottoming out every time. If you give it enough force to feel the tactility, then it should register. As for holding the key down, you should release to feel the bump and then just press enough to feel it again. It isn't going to register on the release bump as you describe it, but rather on the bump when you press down.
Clears are the same for me. The bump is just a bit more noticeable.
« Last Edit: Wed, 09 January 2013, 10:26:38 by absyrd »
Offline Kruen
« Reply #2 on: Wed, 09 January 2013, 18:23:47 »
What I mean is that when I bottom out the key and then release it until it rests just below the bump the switch it's not reliably actuated. It feels as though the actuation point is just the tiniest bit below the bump, or at least it feels that way.
Offline Saturn
« Reply #3 on: Wed, 09 January 2013, 18:32:37 »
You can see the force graph here:
http://www.wasdkeyboards.com/media/guide/graph-mx-brown.jpg
The actuation point isn't just after the bump, but after the dip that follows it.  It's possible to hover around the actuation point and double-tap there without ever going back above the bump.  Not sure if any of that helps; I found your post confusing.
Offline lazerpointer
  • ya gotta stay phresh
« Reply #4 on: Wed, 09 January 2013, 18:54:27 »
I can't make my browns do the bump without making a letter appear....
i type, therefore i geekhack
Offline xDezor
« Reply #5 on: Wed, 09 January 2013, 18:59:24 »
Brown's really suck for double tapping...
Offline rknize
    • metaruss
« Reply #6 on: Wed, 09 January 2013, 22:22:36 »
The back slope of the bump is what spreads the contacts apart when you release.  So if you stop just short of the bump, you won't reliably open the switch each time.  It has to get part-way up the bump.  Clears work the same.  Blues do as well, but it's harder not to reset the switch completely because the stem is in two pieces.
Seems like you might prefer a linear switch?
Russ
Offline Turbo Slaab
« Reply #7 on: Thu, 10 January 2013, 01:24:58 »
Ehh. Im going to have to beg to differ. I spam the "q" spot button in bf3 and can ride the actuation point pretty consistantly.
Looking for CC's!
Offline Kruen
« Reply #8 on: Thu, 10 January 2013, 08:12:35 »
I see, thanks. The graph certainly made things clearer.
Offline davkol
  •  Post Editing Timeout
« Reply #9 on: Thu, 10 January 2013, 10:03:44 »
Pun intended?
« Reply #10 on: Thu, 10 January 2013, 10:41:49 »
Agreed Turbo. I "double-tap" just fine. Actually I like browns the best of all switches atm.
Offline JPG
  • Model F is my new passion!
« Reply #11 on: Thu, 10 January 2013, 10:47:01 »
Have you tried ergo clears?
« Reply #12 on: Thu, 10 January 2013, 11:15:39 »
Not yet. Kind of scared to try soldering in new switches on my current boards XD I'll wait until WASD or some major company decides to put them in a board, stock.
