Author Topic: How deep does this rabbit hole go?...  (Read 2784 times)
Offline Rapid
  • Moar pewpew
« on: Thu, 10 January 2013, 23:09:15 »
Hi there!
So I'm worried that I am getting myself into a bit of a mess here haha! I've been lurking the forums and literally decided to mod my keyboard moments after seeing everyone else's amazing setups! I decided to go with an unpopular choice (Razer Blackwidow Tournament edition) that has the MX cherry blue switches (love them to death). I modded the front casing white along with changing the "razer" logo from green to blue. Going for a storm trooper theme. Also on the way is my brand new keyset from WASD! :) I'll probably put up pictures when my "baby" is done! Hope to get to know you guys better here at geekhack and thank you for having me.
-Kris "Rapid"
Razer 'White'widow [Blue MX Switch]
http://geekhack.org/index.php?topic=39342.0
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
Re: How deep does this rabbit hole go?...
« Reply #1 on: Thu, 10 January 2013, 23:12:29 »
Welcome, sounds like you're off to a good start.
Offline reaper
« Reply #2 on: Thu, 10 January 2013, 23:25:02 »
It goes very deep, Kris..   very, very deep.  :-X
Welcome to Geekhack!  :)
Din Eli
Offline okooko
  • afk.
« Reply #3 on: Thu, 10 January 2013, 23:30:08 »
Well into your deep pockets from what I gather
Offline Rapid
  • Moar pewpew
« Reply #4 on: Thu, 10 January 2013, 23:46:19 »
I cried a little when I saw a bid for an "oktoberfest" keycap for 70 bucks+ on ebay
Thank you for the warm welcome :)
« Last Edit: Thu, 10 January 2013, 23:48:19 by Rapid »
« Reply #5 on: Fri, 11 January 2013, 01:01:28 »
There's quite a few Canadians around here these days :)
Ah, so you've heard of Clack Factory keycaps ("ClickClacks").  Yes, $70 is about average for a second hand one, although the rarer ones can sell for several hundred dollars.  If you are lucky, really lucky, you might be able to grab one at cost.
« Reply #6 on: Fri, 11 January 2013, 01:14:57 »
Quite a few Canadians...and me! Welcome to the party!
