Author Topic: How to block (hold in place) a mx switch stem ?  (Read 4578 times)
Offline Jmneuv
« on: Thu, 17 January 2013, 08:13:03 »
I got a key that's riding too high because the switch stem isn't fully inserted into the cap stem.
Now how the hell can i hold the switch fast to close the gap?
I thought about opnening the switch, putting the key on then just snap it back in place altogether.. i can't however since the switches are platemounted the 'conservative' way.
I'd be willing to open up the board to reach the underside if there's a way from below.
Any ideas much appreciated.
Offline absyrd
  • CPT HYPE PADAWAN
Re: How to block (hold in place) a mx switch stem ?
« Reply #1 on: Thu, 17 January 2013, 08:16:26 »
Wait... what? The stem will not go into the cap? Just push down on the keycap.
Or do you mean the switch housing is separated from its top and bottom parts?
Offline Jmneuv
« Reply #2 on: Thu, 17 January 2013, 08:21:29 »
It's a stepped capslock and it will sit on the switch casing before the stem is fully inserted, so i don't get further by just putting it on normally, i used a dental mirror to look beneath and i can see the gap. (lol)
Offline jeroplane
« Reply #3 on: Thu, 17 January 2013, 08:26:51 »
This is normal for SP-made stepped Caps Locks. The stem mount is shorter than other keys. They also sit just a tiny bit higher than regular keys.
« Last Edit: Thu, 17 January 2013, 08:28:27 by jeroplane »
My signature hasn't changed since 2012. I should really update it.
Offline Jmneuv
« Reply #4 on: Thu, 17 January 2013, 08:37:07 »
There should be enough room to fit though.
Offline Jmneuv
« Reply #5 on: Thu, 17 January 2013, 09:43:10 »
Ha! managed to get it in a little deeper.
.fiddle the needle in with stem half pressed
.release and turn pin to straight up position to lock
.put cap on
.turn pin 90° to either side
.gently press the key, this will eject the pin
(no spare switch, so can't demonstrate better right now)
