Author Topic: PCB mount vs. plate mount switches  (Read 6445 times)
Offline Kalmarauder
« on: Sun, 20 January 2013, 19:03:32 »
I am planning on building my own keyboard which I would like to be plate mounted. It appears to me that the only difference between PCB and plate mounted switches are the pins for securing the switch to the PCB. Am I correct in assuming that it is possible to use PCB mounted switches in a Plate mounted board? I think it would just require holes in the PCB to accommodate the pins. I ask because PCB mount switches seem to be more available and less expensive.
Offline Appeac
Re: PCB mount vs. plate mount switches
« Reply #1 on: Sun, 20 January 2013, 19:07:09 »
People usually clip the legs off, but if you were to design a pcb with holes in it, I don't see how that wouldn't work either.
FC660C
122 Terminal M w/ Soarer board
Online Leslieann
« Reply #2 on: Sun, 20 January 2013, 19:26:48 »
Plate mount's extra pins could probably give you a more solid keyboard if you took advantage of them, but you probably wouldn't notice a difference. It also means double the work when you go to change anything.
As for cost, it depends on where you get them, check Deskthority for 7bit's group buys, his plate mounted switches are cheaper by about 20 cents per switch.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline alaricljs
  • I be WOT'ing all day...
« Reply #3 on: Sun, 20 January 2013, 21:04:16 »
All the info above is correct, I've built pcb, plate and pcb switches w/ plate.  It all works but PCB and a plate make a very firm combo.
Filco w/ Imsto thick PBT
Offline Kalmarauder
« Reply #4 on: Mon, 21 January 2013, 05:25:16 »
Alright, thank you all for the responses.
I'm not sure if this was the right place to put this thread. I meant to put it in "Making stuff together."
« Last Edit: Mon, 21 January 2013, 05:27:21 by Kalmarauder »
Offline alaricljs
« Reply #5 on: Mon, 21 January 2013, 10:49:41 »
Oh hey, good point.  I'll move it.
