Author Topic: GMK RGB samples over here!  (Read 14252 times)
Offline phetto
  • HHKB JP
« on: Mon, 21 January 2013, 07:38:19 »
This is what I understand from the translation.
GMK ****ed up the profile of the new rgb, the blue alt is the old profile in comparison.
EDIT: Found out that this is the sample they got and they are going to change it into the profile we are used to see these in.
« Last Edit: Mon, 21 January 2013, 09:01:15 by phetto »
Offline esoomenona
  • Gnillort?
Re: Looks like GMK made RGB DS for KBDmania, but in the wrong profile!
« Reply #1 on: Mon, 21 January 2013, 07:40:41 »
DS=doubleshot in this case, right? Or are those dyesub?
Offline phetto
  • HHKB JP
« Reply #2 on: Mon, 21 January 2013, 07:42:18 »
doubleshots
Offline tinlong117
« Reply #3 on: Mon, 21 January 2013, 07:48:12 »
oops.
Offline esoomenona
  • Gnillort?
« Reply #4 on: Mon, 21 January 2013, 07:49:56 »
So the taller ones are the "mistake"? Honestly, I like them. It seems they'd be the same height as the bottom row of the black on beige set I have, and they'd match well with the legends matching.
Offline inlikeflynn
  • file not found
« Reply #5 on: Mon, 21 January 2013, 07:55:55 »
Lysol has a better description of this somewhere, but I cannot find it
Originally Control/Alt row had its own profile, which is what the mistake keys have here.
Later cherry switched so that Control/Alt used the same profile as zxcv row, which is what we are all used to and expect to receive
Now it will be interesting to see what GMK does for Customer Service to fix this as you could argue that it is not their fault.....
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline phetto
  • HHKB JP
« Reply #6 on: Mon, 21 January 2013, 07:57:12 »
Interesting
Offline baldgye
  • Will Smith Disciple
« Reply #7 on: Mon, 21 January 2013, 08:02:34 »
And the many problems with dealing with people who are 'new' to this kind of scene begin!
Don't see it as a problem though, if the people ordering didn't specify you can't blame them GMK..
Offline SmallFry
« Reply #8 on: Mon, 21 January 2013, 08:05:30 »
Live and learn. I hope it was a prototype so they didn't produce 500 or whatever the MOQ is for GMK.
Offline phetto
  • HHKB JP
« Reply #9 on: Mon, 21 January 2013, 08:06:09 »
I just talked to the kbd guys and it's only a sample. They will try to fix the profile to the one we are used to.
« Reply #10 on: Mon, 21 January 2013, 08:06:49 »
Ahh thank goodness for samples
Offline inlikeflynn
  • file not found
« Reply #11 on: Mon, 21 January 2013, 08:07:07 »
[size=78%]Below is the exact post by Lysol. just pasted here for reference:[/size]
You have old Cherry A profile modifier, which was dropped a LONG time ago. Now bottom row is B profile same as shift row.
specification diagram from Cherry.
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline SmallFry
« Reply #12 on: Mon, 21 January 2013, 08:10:02 »
Well, its good that they have samples. Just gotta be patient since this isn't Melissa, and she isn't here to fix all our boo boos. :P Gotta give her props, she takes a LOT of crap from us/KBDMania/OTD/DT etc.
Offline esoomenona
  • Gnillort?
« Reply #13 on: Mon, 21 January 2013, 08:10:07 »
I wish I could get ahold of that sample.
Offline baldgye
« Reply #14 on: Mon, 21 January 2013, 08:13:29 »
might be an idea to change the title then ;)
Offline phetto
  • HHKB JP
Re: GMK RGB samples over here!
« Reply #15 on: Mon, 21 January 2013, 09:04:01 »
Title changed =)
Offline kaiserreich
  • HHKB Elite
« Reply #16 on: Mon, 21 January 2013, 09:34:03 »
If anything, I'd love the lower profile ones to better fit the white on black DS set.
Offline phetto
  • HHKB JP
« Reply #17 on: Mon, 21 January 2013, 09:41:19 »
same here
btw nice avatar
Offline Alessandro
  • The Price Is Right
    • Alessandro's Sweet Shop
« Reply #18 on: Mon, 21 January 2013, 09:42:26 »
GIMME!
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #19 on: Mon, 21 January 2013, 10:41:00 »
That ABS blue color is nice!
I don't think I'd mind the profiles that much unless I'm using zxcv profile 1x winkeys :)
Offline Glissant
« Reply #20 on: Mon, 21 January 2013, 11:01:13 »
Mmmm pretty keycaps are pretty. Posting to mostly lurk and post cats.
By the way, did Cherry ever produce rgb with white legends?
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
« Reply #21 on: Mon, 21 January 2013, 11:02:35 »
Actually, I'd prefer a set of the messed up profile ones since they match up with the Dolch and Black DS better
Offline SmallFry
« Reply #22 on: Mon, 21 January 2013, 11:14:20 »
Match up profile wise?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #23 on: Mon, 21 January 2013, 11:18:57 »
The ones with A profile would be more authentic technically. I would guess they send a picture of original RGB which are A profile control and alt and say we want this, so GMK gave them what they saw.
I've never seen Cherry RGB with white. Dyesub is most common, but there have been some sightings of doubleshots also with black legend.
Dolch is B profile bottom row, I have also never seen a black set with A profile either. B profile is by far more common on anything that is not beige.
Offline SmallFry
« Reply #24 on: Mon, 21 January 2013, 11:20:23 »
Chaos has sold the DS black on RGB doubleshots IIRC. He asked something crazy like $400.
Offline DanGWanG
  • Higher Standards
« Reply #25 on: Mon, 21 January 2013, 11:26:31 »
Yup!  Exactly what lysol said.  I'd be interested in a set of DS RGB in B profile to match Dolch and Black DS.  For winkeyless keyboards, it's not a big deal.  But when I use the DESKO RGB's on a keyboard that is 1.5/1/1.5, the 1-unit key never matches up if I use Dolch or Black doubleshots...
« Reply #26 on: Mon, 21 January 2013, 11:43:36 »
Yeah 1 unit A profile Windows or blank key is a real pain to locate... though I have some. B profile is much more pleasant to type on anyway.
Offline Jmneuv
« Reply #27 on: Mon, 21 January 2013, 15:42:27 »
Not the Aaaaaaaaa profile !!
i actually was afraid that this could happen, since original cherry ds equipment was mentioned..
good it's just prototypes
Offline singaporean123
  • I like keycaps and I cannot lie
« Reply #28 on: Mon, 21 January 2013, 20:22:02 »
Do people actually like the black on dark RGBs?  :eek:
Offline SmallFry
« Reply #29 on: Mon, 21 January 2013, 20:23:23 »
Well, people seem to like dye subbed RGB's which have black legends, so I'd say that people will like these also. :)
« Reply #30 on: Mon, 21 January 2013, 20:24:38 »
I have no idea why I get you and theprofofist(?) mixed up all the time!
I just feel that the colours look a tad bit dull :/
Offline SmallFry
« Reply #31 on: Mon, 21 January 2013, 20:40:55 »
I'm not sure why either. The colors look alright to me,maybe its your monitor or the photo not being properly balanced. I'm not exactly sure. It could also be personal preference:)
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #32 on: Mon, 21 January 2013, 20:43:54 »
Genuine Cherry RGB PBT's are black dyesubbed ;D
Offline phetto
  • HHKB JP
« Reply #33 on: Tue, 22 January 2013, 05:41:42 »
Doubleshots are also genuine and way more far between. xD
Offline Glissant
« Reply #34 on: Tue, 22 January 2013, 06:31:26 »
I am only wondering because I think RGBs would look great on sets with white legends, but right now my RGBs with black legends look out of place.
Offline phetto
  • HHKB JP
« Reply #35 on: Tue, 22 January 2013, 08:11:21 »
Thats exactly what I think too.
You see, if you have a white on black cherry ds set and use a white on red cherry esc it looks amazing.
But when the table is turned around and you try a beige/white cherry set and use the white on red esc it looks crappy..
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #36 on: Tue, 22 January 2013, 08:15:47 »
That's because they weren't meant to be on the same board :P
Offline phetto
  • HHKB JP
« Reply #37 on: Tue, 22 January 2013, 10:33:12 »
:O :D
Offline Supergleep
« Reply #38 on: Tue, 22 January 2013, 15:54:50 »
ok, gotta ask, is this a group buy that I can still get in on, or just samples for a closed GB? I'd love to get a set of Cherry RGB doubleshots.  *looks for the 'shut up and take my money' jpeg*
Filco Tenkeyless - Daily Driver  |  Filco Linear R - 87  |
Offline phetto
  • HHKB JP
« Reply #39 on: Wed, 23 January 2013, 03:34:39 »
It is a GB going in the korean community, not here.
Offline SmallFry
« Reply #40 on: Fri, 25 January 2013, 23:29:20 »
Is it going? I thought there was no GBs in Korean communities for a while.
« Reply #41 on: Sat, 26 January 2013, 01:55:12 »
GB or not, aren't the RGB at Originative these exact caps?
Offline SmallFry
Re: Re: GMK RGB samples over here!
« Reply #42 on: Sat, 26 January 2013, 07:04:40 »
I don't know, I never saw the site...
Offline phetto
  • HHKB JP
« Reply #43 on: Sat, 26 January 2013, 07:49:31 »
You been afk for the last 2 days smallfriez?
« Reply #44 on: Sat, 26 January 2013, 11:17:51 »
I don't think originative has 1.5 version of RGB which is what was in the OP picture.
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #45 on: Sat, 26 January 2013, 11:26:22 »
Sherry is selling both 1.5 and 1.25 versions. From the pictures they look like B profile keys
« Reply #46 on: Sat, 26 January 2013, 12:22:11 »
Ok, I only saw 1.25 version when I looked the other day.
Offline dirge
« Reply #47 on: Sat, 26 January 2013, 12:38:39 »
I prefer the old A profile.
Get the short left shifts made!
Thinking about things isn't the same as doing things. Otherwise everybody would be in jail.
Offline sherryton
  • Kībōdo
    • Originative
« Reply #48 on: Sat, 26 January 2013, 14:06:21 »
On its way!  I listened to lysol when it came to the Cherry profiling, and I am glad I did :)
Offline phetto
  • HHKB JP
« Reply #49 on: Sat, 26 January 2013, 19:34:01 »
What sherry, have you put an order for iso shifts?
